Wow! I've been out of the loop on flashlight modding (including keeping up with FW developments, but this sounds like some seriously great achievements. So many developments. I really dig that you have disconnected OTC performance from the various factors that influence the OTC capacitor's behavior.
Hope you are ok with me adding a link in the OP of the "25" thread to this thread.
Expect problems. There's a ton of new stuff. There's going to be bugs I missed. I've tested on a bench, which has some advantages as far testing layout cases, but also misses some of the experience of real-world use. Yeah, sorry about the fast write-up.
4 channels was requested (I think by DavidEF) for RGBW. No, at the moment there are no disco strobes or new ramping or anything like that. Yes the softstart code toy keeper wrote should be a solid starting point for ramps, but I think narsil is the ramping king probably. I knew someone would ask about party modes, lol. The main goal was to squeeze this into an an attiny25, although TA is now squeezing 85's onto smaller things anyway (I'm almost bummed about that lol). Setting this free onto an attiny85 would probably allow tons of stuff like that. I don't know how much I'll carry the ball forward with that kind of stuff either. Contributions are of course welcome. It's gpl.
LDO is, well some of those comments are for people pairing it up with new hardware. LDO stands for Low drop Out, but it means tiny voltage regulator on the input to the mcu. It's used for 2S etc lights as a better alternatve to a zener to power the mcu, and can provide a voltage reference to the adc. that's the only way to get voltage reading and power-off detection (and/or switch) onto the same pin in this firmware. But in an unregulated 1S build you don't need to. You can just use the Vcc-pin voltage reading.
Trippledown is as far as I can tell the original 3 channel version of bistro. Actually I kind of skipped that version and went from stock to TA version, which I think is based on trippledown. Three way, I was just referring to the short/med/long click options, that give mode reversal and hidden mode access, compared with short/long, that doesn't.
I think the most immediately-available test case for the biggest part of the code is probably e-switch lights. I kind of imagine DavidEF building an RGBW SRK or Q8.
Oh, one thing that's completely untested is the traditional divider voltage reading in the new parameterized form. I don't have a voltage divider on my test setup. I tested the Vcc method and that works for me, but not the divider. There is a hidden define in the voltage.h that unleashes the original ToyKeeper calibration table as a backup, but that's not tested either. It should work, but there could be a typo or two still there.
Oh, and I forgot to package in TA's build script. I'll add it back when I get a chance. It's useful for compiling on Linux.
Don’t be bummed about the swap to tiny85’s in the new drivers, we will still need the space at some point plus all the older drivers still use tiny25’s and this firmware should work for them as well.
Texas_Ace, do you have a new driver board for this firmware? I know you’ve been talking about new driver design(s) you’ve been working on. Is this it? I’d love to see the hardware released that utilizes this firmware.
A couple of notes for anyone looking at the code. The 4 channel stuff is mostly setup in fr-tk-attiny.h, init_mcu, and a couple of timer interrupts.
The OTSM and e-switch stuff is mostly done from PCINT0_vect, the watchdog interrupt (that does nothing), and some mild trickery with main_init and the early parts of main. All that is kind of together in bistro.c
I have a new driver that is almost ready from the hardware side, although the firmware is not quite ready yet but a lot of the features in this firmware came about for this new driver.
I am going to be calling the new driver the “Texas Commander”.
It will take advantage of the OTSM and PWM regulation among other software features but no 4 channel at this time, mostly because it is not needed with this driver.
Long term I would love to see bistro and narsil come together to make a single firmware for both clicky and eswitch lights that can be selected in the menu thus allowing for a single driver to be produced and work with virtually any light setup with little to no hardware changes needed.
Yeah, I'd veer more toward talking about 45's than 85's if OTSM is something that matters. We still have no datapoint of anyone having a late revision 85 where BODS actually works, and possibly three examples where it didn't. Who knows, maybe those revisions have only been sold through certain contracts and the retail supply has a 15 year production run of early revisions on the shelf. It does seem that on the other hand maybe almost every attiny45 in the wild is late revision and compatible (we don't really know). For use on existing builds, it's going to be a YMMV situation. For new builds you can at least look at the bottom of the chip and find out.
I want to add more emphasis of the credit to Flashy Mike and Mike C. Maybe it comes off like they did early test of my OTSM designs or something. Not the case. They made the first prototypes for hardware and software and communicated very useful results of that that heavily influenced this. TA also was very involved in helping to figure out what configurations we can actually get into a driver and DEL even chimed in with some useful contributions to limits on the electronics. A bunch of people put thought and effort into it.
As far as merging things. I think Tom E is probably the most consistently dedicated software person here, and don't expect that to change from my perspective. If some of this stuff just serves as a demo to get worked or reworked into Narsil, that's great, especially considering he will probably continue to maintain it. Much of it would probably have to be done very differently in Narsil though. They are just completely different animals at the program flow level.
Hmm.. I don't have a concept of a comfortable UI for that. How would it work? Already you can predefine combinations. Clicking into 4 different ramps sounds pretty uncomfortable, and distinguishing 4 switches on one pin with battery read and poweroff detection, is technically not quite impossible, but probably not going to happen.
This looks awesome so far. I’ve been pulled away by Real Life™ for most of the past 5 months, but I’m finally back to making my backlog smaller instead of larger, and I hope to catch up on recent developments.
Do you mind if I copy the code into the main repository?
Also, is there much interest in migrating to github? I personally prefer launchpad, but git is quite a bit more popular so it might be useful to move the repository.
Hi TK. Glad you like it (well, no real tests yet). I had a good starting place to work from.
Yeah, I'm a little likely to take a break a bit for real life. I don't have much opinion where you put it. Of course I don't mind if you copy it. probably should get TA's build script in there if you've got it handy. It should work as is from previous versions. I'll try to add it when I get around to it. I did forget to mention that my test rig is a very violated TA board.
It's got 30uA of capacitance on C2, nothing on the OTC. I think 22k on R1, but the value doesn't matter because there is no R2. I'm only using the voltage there as OTSM shutdown detection, which is why I haven't tested the voltage divider read option, just vcc read, and that's how would wire any 1S build.
C1 capacitance and the bleeder (total resistance of bleeder and parallel divider to be accurate) are important for getting OTSM working well because they determine how fast the power off is detected, and there's a bunch off-time power wasted while that's happening. I'm presently using 1uF C1 and 500 ohms bleeder. DEL likes 1uF C1 for stability against spikes, although 0.1 might do the trick. Lower bleeder is ok, unless you want heroic moon mode lifetime to survive the apocalypse. Anyway, I think after adding power saving in bistro, there's at most maybe 20% improvement to be had in off-time by going to lower values.
I'm buying a V-chip now and a couple of these caps:
It's quite expensive but being tantalum it won't lose capacitance with a DC bias or with high temperature(there is the whole explosion thing but that adds fun), and it's the best I can find in an 0805. I think TA is trying to make space for 1206 C2's on his new boards, and there should be some benefit from adding an extra cap in the OTC position if it's not otherwise in use, or even if it is (can wire a switch across the cap). I'll try to build it into a present model TA board and see how it goes.
I am about to take some time off for real life myself so I also understand the break. Thats why I have been trying to finish this last driver before life takes over.
I should hopefully have a hardware setup nailed down before long for people to play with for the firmware side of things.
Well, I’m not at all versed in firmware, so I can only say what I think I’ve seen/heard. If you’re interested, take a look at DrJones and tterev3 UI’s for inspiration. tterev3 even has R-G-B-W-UV working with e-switch. He uses PIC chips instead of ATtiny, but that doesn’t change the fact that he has an excellent single e-switch UI. I can’t remember now for sure if he has per-channel output-level ramping, but I think he has some kind of advanced color mixing.
Yeah, I know the RGBW firmware would NOT be Narsil or Bistro. I wouldn’t want a RGBW light to work like a white-only light. The “four channel” aspect of a Bistro or Narsil light is just a way to have more efficient mode levels. It’s the next step up from three channels, which is the next step up from two channels, which is a bit better than one channel. It’s almost like having a 8K television versus 4K versus 1080P versus 720P versus “standard DEF” in that it deals with “resolution”.
And it does open up the possibility of having multiple led outputs. Like an all red mode or an led on the side and front of head as I’ve seen in some mods out there. It opens up many more possibilities and is a step toward another possible color firmware.
Yeah, they’re designed for only one actual LED, or maybe one plus an indicator somewhere. Adding more channels to a one-LED light has diminishing returns. Here’s a conceptual comparison of 1-channel, 2-channel, and 3-channel drivers:
As far as I can tell, the Tripledown or QuadrupleDown (lol) method is how Zebralight and some other premium brands do their drivers. On close inspection, their medium modes have fast oscillations between two stable output levels… just like what Bistro and Narsil do. Not all premium brands operate like the led4power linear drivers.
The really interesting parts of having more PWM channels is the ability to do more than one LED. Like, RGBW or white plus an indicator or two, or multiple color temperatures for adjustable CCT, or things like that. Or use extra pins for extra I/O, like another switch or an external temperature sensor or a backshine/feedback sensor. Of course, those aren’t going to happen in most cheap hosts, so I expect the 2-to-4-channel single-LED drivers will remain popular.
