No offense to anyone who likes this light, but I think for ~15bux the UltraFire DV-S9 kicks its ass.
Diving light, magnetic switch (slider), you set the brightness like a wall-mounted dimmer switch to whatever brightness you want. As in instantly, no ramping up/down or anything. Want “turbo”, slide it all the way. Want almost-moonlight, just give it a small nudge. Damn, I love that…
It takes a 26650 (comes with a sleeve to take an 18650), is a rather beautiful deep indigo color, and is waterproof (being a diving light, well, duh).
I’m still waiting for my second one, as I liked the first so much I had to get a spare.
As for this unnamed critter, it sounds really nice and I’d probably get 1/more if (going on what other people said here):
• NOSTROBE (like seriously, why does every light have to have that accursed mode?!?)
UltraFire DV-S9 ………… :person_facepalming: :person_facepalming: Oh noooooo……… more temptation and very little resolve to resist. … :person_facepalming:
Thanks for sharing that one ‘Lightbringer’!!! It takes 26650’s also and I can always use another home for one of those.
But as far as you calling the light in this thread an “unnamed critter”, I must in good conscience inform you that back in This Post in the thread of his review of the light…… NikolaS did indeed name the light.
It was christened “CFG01 Cheap, fake and good”…………
Duly named & referred to thereafter for all eternity…… as the “CFG01”………… :+1: …
Yah, I read about the “CFG01”. I was just going by GB’s “name” for it.
No worries about the DV-S9. I posted a “review” or whatever a while ago here. I was floored when I got it, as it really surpassed all my expectations. And even though the temp’s on the cooler side, it’s nowhere near Angry Blue™, but is a rather nice(ish) color.
And I love the slider. 10mA parasitic, so yeah, do a TCLO when you’re not using it. ¼-turn is plenty.
I hear ya’ Lightbringer………. :+1: …
Thanks for mentioning the tint on the DV-S9 too. I had meant to ask but forgot. As long at it not “Angry Blue™” I am good with it. I like tints on the cooler side myself. :+1:
No worries. Was just shining it around, but it’s kinda hard to guesstimate in a vacuum the “exact” CT/tint. I usually compare with more or less “known” LEDs/lights.
As long as it ain’t green, either. Man, that’s an ugly tint…
I understand that on the tint and I totally agree with you on the “green”! I can;’t stand that, I rather have blue. :person_facepalming: And I don’t like blue either………
+1 to all of this!!! Especially the part about building or collecting cars………… :person_facepalming: … :money_mouth_face:
Good links and info! Thanks again Lightbringer………… :+1:
I posted this on the other thread about this light
“I have read Zeroair“s review of this light over on Reddit & although not disagreeing with his opinion of this light my opinion is that he is a little harsh on it.
At the end of the day it is a $10 dollar light with built in USB charging, & an illuminated switch that shows cell status & charging status.
It always turns on in high then ramps down to it“s lowest setting, flashes, then ramps back up to high, flashes, ramps back down to low.
At any point you click it off then back on & it will be in high.
My 2 don“t have to bad a tint or beam.
For what I want to use them for for they are ideal (actually they are mainly for my wife to use)
Yes they are cheaply made, yes the emitter is fake & yes the lumen claim is false but at the end of the day they are about $10.
Now you could get say an S2 for similar money ( I have a couple) which is a better made/quality light but does not have the features this light has & to me (especially my wife) these features are handy.
My 2 cents worth ”
The UltraFire 1L2 is rated at IPX6 only - not submersible “30m - 50m” as is the DV-S9, per their descriptions. Also the IL2 emitter is XM-L2 7000K at 888 Lumens, as compared to the DV-S9 running XM-L2 6000-6500K rated at 1200 Lumens.
Other small differences - it appears to be not the same light, but very similar form/function light; and OF COURSE, there’s the COLOR difference - who can resist the purple with red trim!?
I just peeked at the spring side. I can see the Hall-effect sensor sniffing the magnet in the slider, but that’s it.
Didn’t take it apart. Guessing everything comes out from the lens side, ie, twist out the (also red) retaining ring from in front, then out comes the reflector, star, probably a spacer, and finally the driver.
Can’t imagine having to install the driver through the battery-tube, and the head+tube seems to be one solid piece. Can’t find any seam, and “untwisting” accomplishes nothing.
I might be wrong, as I didn’t try very hard to disassemble it, but that’s what it seems like. And I like it enough as-is that I’m not even all that tempted to go swap the LED or anything.
I’d like to make sure the LED’s AS5ed in there (ha!) and not just pressed-in via the reflector or anything (most likely), but like I said, I don’t want to scratch it up trying to take it apart.
