This looks awesome so far. I’ve been pulled away by Real Life™ for most of the past 5 months, but I’m finally back to making my backlog smaller instead of larger, and I hope to catch up on recent developments.
Do you mind if I copy the code into the main repository?
Also, is there much interest in migrating to github? I personally prefer launchpad, but git is quite a bit more popular so it might be useful to move the repository.
Hi TK. Glad you like it (well, no real tests yet). I had a good starting place to work from.
Yeah, I'm a little likely to take a break a bit for real life. I don't have much opinion where you put it. Of course I don't mind if you copy it. probably should get TA's build script in there if you've got it handy. It should work as is from previous versions. I'll try to add it when I get around to it. I did forget to mention that my test rig is a very violated TA board.
It's got 30uA of capacitance on C2, nothing on the OTC. I think 22k on R1, but the value doesn't matter because there is no R2. I'm only using the voltage there as OTSM shutdown detection, which is why I haven't tested the voltage divider read option, just vcc read, and that's how would wire any 1S build.
C1 capacitance and the bleeder (total resistance of bleeder and parallel divider to be accurate) are important for getting OTSM working well because they determine how fast the power off is detected, and there's a bunch off-time power wasted while that's happening. I'm presently using 1uF C1 and 500 ohms bleeder. DEL likes 1uF C1 for stability against spikes, although 0.1 might do the trick. Lower bleeder is ok, unless you want heroic moon mode lifetime to survive the apocalypse. Anyway, I think after adding power saving in bistro, there's at most maybe 20% improvement to be had in off-time by going to lower values.
I'm buying a V-chip now and a couple of these caps:
It's quite expensive but being tantalum it won't lose capacitance with a DC bias or with high temperature(there is the whole explosion thing but that adds fun), and it's the best I can find in an 0805. I think TA is trying to make space for 1206 C2's on his new boards, and there should be some benefit from adding an extra cap in the OTC position if it's not otherwise in use, or even if it is (can wire a switch across the cap). I'll try to build it into a present model TA board and see how it goes.
I am about to take some time off for real life myself so I also understand the break. Thats why I have been trying to finish this last driver before life takes over.
I should hopefully have a hardware setup nailed down before long for people to play with for the firmware side of things.
Well, I’m not at all versed in firmware, so I can only say what I think I’ve seen/heard. If you’re interested, take a look at DrJones and tterev3 UI’s for inspiration. tterev3 even has R-G-B-W-UV working with e-switch. He uses PIC chips instead of ATtiny, but that doesn’t change the fact that he has an excellent single e-switch UI. I can’t remember now for sure if he has per-channel output-level ramping, but I think he has some kind of advanced color mixing.
Yeah, I know the RGBW firmware would NOT be Narsil or Bistro. I wouldn’t want a RGBW light to work like a white-only light. The “four channel” aspect of a Bistro or Narsil light is just a way to have more efficient mode levels. It’s the next step up from three channels, which is the next step up from two channels, which is a bit better than one channel. It’s almost like having a 8K television versus 4K versus 1080P versus 720P versus “standard DEF” in that it deals with “resolution”.
And it does open up the possibility of having multiple led outputs. Like an all red mode or an led on the side and front of head as I’ve seen in some mods out there. It opens up many more possibilities and is a step toward another possible color firmware.
Yeah, they’re designed for only one actual LED, or maybe one plus an indicator somewhere. Adding more channels to a one-LED light has diminishing returns. Here’s a conceptual comparison of 1-channel, 2-channel, and 3-channel drivers:
As far as I can tell, the Tripledown or QuadrupleDown (lol) method is how Zebralight and some other premium brands do their drivers. On close inspection, their medium modes have fast oscillations between two stable output levels… just like what Bistro and Narsil do. Not all premium brands operate like the led4power linear drivers.
The really interesting parts of having more PWM channels is the ability to do more than one LED. Like, RGBW or white plus an indicator or two, or multiple color temperatures for adjustable CCT, or things like that. Or use extra pins for extra I/O, like another switch or an external temperature sensor or a backshine/feedback sensor. Of course, those aren’t going to happen in most cheap hosts, so I expect the 2-to-4-channel single-LED drivers will remain popular.
I had some similar experiences while trying to make bistro fit onto an attiny13 for biscotti. I hope to merge together both of our space-saving ideas soon, to make all the projects as small as possible.
I must admit I haven’t really made time yet to read through it, after barely a week of catching up, and I don’t have hardware to test it on. But it sounds like you’ve been doing good things.
Ideally, I’d rather curate people’s code instead of writing it. I never intended to write ALL TEH CODEZ, just to get it all together in one place and make it easier for people to collaborate. So, I’m really happy to see people making cool new stuff.
First folks should understand this is not a 4 channel firmware. It's actually many different firmwares programmable by the c-preprocessor options, and 4 channel is just one option. You can build it for only one channel or two or three, and you can select whichever of the 4 channels you want (although 1 and 2, on pins pb0 and pb1 are preferred slightly at least). 4-channel was really just a why not kind of thing after figuring out how it was possible. The Vcc-read and the eswitch ire probably the most immediately useful features on existing hardware and the OTSM will I hope be a great benefit in the very future possibly even on existing boards with some changes to the components. It also combines well with the other two features.
Color mixing was pretty much what I thought you were getting at David. But before someone can program it they'd need a vision of how it would be used. If you just want to set up some color for photography I guess it can require a little setup and several menus for each led to fine tune things. Using a standard UI I'd probably do color mixing at a medium brightness level in the hidden modes or just have a dedicated modegroup like that, just have as many preset mixes as you want. Then standard modes are just W or maybe equal RGBW, or anyway a fixed custom tint.
One thing I've thought would be nice though, similar to hidden modes, but somehow make it easy to switch back and forth between two or three mode groups. Not the full menu 5 thing, some kind of quick access toggle. It could be a short menu in the hidden modes. Then the user can define their 2 or three bookmarked groups from the main menu. For me I use my light walking and biking and indoors, and kind of want different mode groups for all three (but especially for indoor vs outdoor). I wouldn't mind if it even defaulted back to the indoor settings after an hour. (RAM actually lasts that long with these big caps, but without an eswitch there's no good timer and the RAM probably actually lasts too long).
Anyway, lots for room for creative advances still. I was kind of hoping to mostly knock out the real hardware-driver side of the firmware with as many configurations as can cram into 5 pins. Then the "application" side of the software can be developed more, but I'm sure there will be more ideas on the hardware side too. There already are a couple of ideas that fall in between, like pseudo regulated PWM, that aren't in here. If I do more that might be my next thing.
TK, you mention the possibility of using a second eswitch. Would this be a difficult task? E.g. One switch to brighten and one switch to dim.
Flintrock, I like your idea of creating a menu to form a custom color/tint to be used as the main output with normal output options. The way I like to use RGBW for 90% of the time is as a dynamic white. You really can get a very nice tint this way and some extra output for the white channel. Anyway, I’m glad there is a starting point in this regard. I’m also excited about the hardware changes. I’m not quite sure how to implement it all right now, it I’m watching as many of you understand it much better and will be posting mod threads soon;)
I missed this comment the first time. I already took your diff from the TA driver thread from I think sometime in Decemeber and merged it. It's the first thing I did. If there are newer things then I don't know about that, but much of it might not apply anymore. I did some pretty big reworks on a number of sections to get it this this tight, not that they weren't written well, this was just an extra push for space, but you can't do that kind of thing until you have a good working code to start from. I still feel like it should be possible to save a few more bytes in the strobes, but placing them in an array failed in one attempt at least, and trying sequential switch made different assembly, but about the same. I don't think there are any gains left there except maybe in assembly and then probably not enough to be worth it. Even with all this it only saved 15%, so it's not like it was bad to start with. But I squeezed in the new stuff partially by letting the sleep interrupt literally leave a path of destruction behind it before resetting everything anyway. :)
Well the eswitch code is mine so I'll comment. Basically OTSM and eswitch work identically now as it is, in fact that's why I went ahead and added e-switch. They both use the same code to look for pins going low, go into a sleep loop, wake periodically to count time and check for the pin comming back up. And basically that creates the clicky-switch/eswitch combo in OTSM e-switch lights as it is now. There are some technical differences, mostly put in on purpose though, but I'm not even sure any of those even as things are at this moment would prevent you from using two e-switches and no clicky.
However, on a 4 channel driver, there's only one pin available for doing switching* (I'll come back to that asterisks) because there are only 5 pins other than gnd, vcc and reset. Presently OTSM and e-switch (and voltage monitoring) can all exist on one pin. However, in that case it's not presently possible to tell the difference between one switch and the other. The only difference is that one will kill the power after a couple of seconds and the other wont and in fact I added a loop to make it burn up power for a couple of ms after the long press threshold, to kill it faster and make sure you don't wake into off mode with the clicky as you would with the eswitch. That's not a problem though because if it really was an eswitch, the couple of ms wouldn't do anything to it. But we do need to be able to tell which switch is which. I've had a plan for that for awhile, and it's not too bad. You need the eswitch to pull the pin down not to zero, but to about 0.5V and then use the adc to tell the difference. So that requires the right resistors on the switch and a couple of extra lines of code. Of course you might want two eswitches AND a clicky, for that we have to get to the asterisk.
So about those 5 pins. We discussed this some in the attiny thread and I don't even remember whose idea it was, but basically, you can put a switch on the reset pin. You would want to pull it from high to some intermediate voltage, or the other way around, keeping it always above reset voltage (which I recall is very low, like 0.1V, not normal logic low). That could be done with the right resistor combination and wouldn't be a big deal to add support for in software (except that the conditionals for all the combinations both in c-preprocessor and actual code, would be getting bogglingly complex to get one's head around, have a look at PINT0_vect, but it just takes a bit of thought). This probably wouldn't even require an ADC read like joining switches on the voltage pin does. I'm kind of starting to like it actually.
So if going with the reset switch, actually I think it's pretty easy if you don't need a clicky switch at all, and doable even if you do.
Thanks flintrock. I have a few lights that have two switches, mainly sunwayman and nitecore, but also some lumintop lights with large switchboots that could house two switches. I have not modded them because the idea of a “dummy” switch that does nothing or does the same as the other never felt right to me. Anyway, good to know it is possible.
I’m doing this in my OTSM firmware with a morse code like technique:
short-long for 1st mode group, short-short-long for 2nd mode group, and so on. Once you have the code for recognizing morse codes (convert a combination of long/short clicks to a single byte value) implemented, you can easily access all functions and setup options directly with a simple code. For instance my firmware displays battery status with a long-long click, does a lockout with long-long-short-long, turbo with short-short, tactical strobe with 3x short, bike strobe with 4x short. With little effort you might even let the user choose which click combination calls a specific option. No need for cycling through strobes and batt status.
Not my invention btw., Dr.Jones did a similar thing years ago, though only in setup menu, if I remember right. In my firmware the “morse” codes are functional at any time.
Nice. Most of the code is actually already in there. I only time the first click, but not a real big deal to time them all probably. Would need to time the on time's too, but I've got a global time counter commented out in the delay function just for that. Still some work to put it all together but many parts are there already. Anyway, not really something I'm jumping to work on real soon.
Your point is correct, but I just want to mention that the efficiency for the FET-only case is not as bad as the straight line in the graph. This is because there are 2 main contributors to lower efficiency at high current: one is the high current density itself and the other is the temperature. So when the PWM duty cycle is, say, 50, the temperature won’t be as high as it is at 100, so the light output curve won’t be a straight line. See here for some measurements:
