It took me awhile to get a hold of how fast to click but it is not so bad once you master it.
you can also post in the commercial forum if you are interested in your own personal UI the way you like it.
The C8 driver only has fast click IIRC, which is super simple. You simply tap the power button till the light blinks off then release and it goes to the next mode.
If you really don’t like that then simply set it to 100% only mode, which will be on/off only with no other modes.
Thanks TA. I’ll add the fact that there are 8 mode groups that don’t have blinkies and they all function beautifully.
I do not mean to imply that I am in any way excusing the problem with the current drivers and I don’t have the E14 to compare it to. We are working on the driver issues but it will take time.
For most (certainly not all) the current driver will be at the very least, quite an improvement over the old 3/5 driver with the annoying blink in low. That said, “acceptable” is NOT acceptable to Convoy and I’m working with Simon on getting this issue resolved and moving forward to bring more awesomeness to the budget light world that this forum was founded on.
If you bought a new C8 and didn’t like the menu/UI, then you could always swap the driver for a new one from MTN Elec that has the simpler Guppydrv for like 5 bucks. A driver swap in the C8 is very easy, you only have to solder 2 wires on the LED.
Thanks a lot guys! That was very helpful. I may in fact pick this one up in another week or 2. I just ordered the XT12GT about 30 minutes ago so I would love to do a comparison with it and my old chinese xm-l t6 C8 as well as the UT02 and TM03 I just ordered last week. Just for fun, I know it’s not a thrower but it is about the same size.
Thank you Tom E for your discription in post #676. Wish I had read it before I ripped my SOIC8 clip apart and rewired it cause it wouldn’t connect to the ATiny.
After cutting the trace flashing a new firmware was no problem.
I’m in a hard decision now. Buy a C8 host and put in TA driver with OP reflector and XP-L2 now.
Or wait for the L2 little brother L1 which is not even has a separate thread. :cry:
I want to buy C8 (new) from GearBest but I do not know if it has this new firmware. Do you have any information about this? All new c8 contain new firmware?
