Manker E14 18500 battery tube
Went through one of these cheapie unbranded 18650 lights. Has a charge port but it is dependent on the charger or wall wart for the charging capabilities. 3.5mm power port.
Modes are H, L, Strobe on a softer remote SW feel. I do like these lights and have a few around the house. Snagged off ebay auctions for $1 or $2. They have plastic reflectors but offer a nice spot and no artifacts.
I swapped the 20mm MCPCB with an aluminum DTP Nichia 219B 4000K high CRI. It has a pressed in emitter shelf and that was removed, sanded flat and good thermal paste. Driver output was about 900mA on High and I stacked another 1R0 resistor to the existing 2 already there. I used the same value as the existing resistors 3X 1R0 is now 0.333 ohm from previous 0.5 ohm. Jumped the output to 1.3A and is a nice increase but well within reason for this light. Also replaced the wires and added some lead to the solder.
Others have emitter swaps but the results of this one turned out good. May go through the others to put the resistor into those too.
spacer looks like its not seated flat but it is, just shadow from the light I used for the pic. Reflector is actually shiny too and that looks dull, but its not.
little better in some ways…
This was a $1.75 light off ebay auction. Advertised as 12W but only drew 4.7W. Swapped all the beads to 3W WW 4000K and stuffed one of those 20W Flood light drivers into it. Had a few drivers and first used one I knew was going to deliver 20W. Ran the light about an hour and just thought it got too warm. Dug out another “20W” driver and gave it a test. 12.4W and it really is not noticeably dimmer than it was at 19W on the other driver. These 20W drivers should deliver 600mA with voltage between 24-38V DC, so the 9X 3W fall into the range.
This light has good bones… Good fins, good pressed in shelf for the board with descent thickness. Used a moderate anount of thermal grease spread evenly. Locked the shelf and MCPCB in better, 3 screw holes that were not originally used, with some Stainless metric socket head screws and washers… It’s tight now. There is also some added pressure from the outer bezel on the optics.
Not sure where I am going to use this but it was something to do today. Confident it could run 24/7 without issues.
Nice work vwpieces …
I modded an Ultrafire S5 some weeks ago , with a Nichia 219C 5700k 80+ CRI on Noctigon , flashed biscotti on a 7135x8 driver that i installed , and changed reflector for an OP reflector from Convoy S2+ .
One great light for 10$ …
Now i have still to mod the one you did too , i just have to get some Nichia’s (probably 219B) and some 16mm DTP boards .
I like to have the Lumintop Tool Copper with the electronic switch from the Tool Ti, here it is.
The whole story: Lumintop Tool Copper with electronic switch
Built up a tiny10 7135 driver(2 chip stack) with guppy drive and installed it in a BLF 348.
Modded a DQG26650 with one of Everett’s colour drivers. The only thing left is to order a lens for it.
Glad you saw the post. Was thinking of sending it to ya.
Wish I could program a driver… Still learning basics. I was proud of the resistor mod on that one because I was flying by the seat of my pants and generally copy what others do on electronics mods. May do 2X 1R0 stacked on the next. 0.25 ohm may still be under 2A, shooting for 1.5A to be safe.
It’s really easy to get into flashing firmwares .
If you want to , just send me a message and i think i will be able to help you .
Did another 18650 rechargeable. Added 2X 1R0 resistors and get 2.0A as I guessed. Some pics
Sanded the spacer and fitted
Double stacked resistors and the driver. This one had a hot glue Booger between the SW and charge port. Made it miserable…
Used a Jaxman Nichia 219B 4000K high CRI on a 20mm DTP aluminum.
Bypassed the driver spring… because I was in there and the iron was on.
Another…
Eagle Eye X7 XP-L HI 3A got some boost today. Killer 26650 light IMO.
MtnE 20mm Fet+1 and bypassed SW spring. Didn’t check amps because the tail switch assembly ring is difficult to get started and scratches get worse on the tail finish.
Ceiling shot of spot
I stripped for the first time today.
Stripped a flashlight, that is. I got this grey S2+ for like $6. But upon getting it, I couldn’t stand the color so it’s sat in its box for a month or so.
But I got inspired by vwpieces to strip and polish it. It’s not perfect, but much better than that ugly grey.
I like it. :+1: :+1:
Mine WAS Blue. Got it for the metal SW but couldn’t take the color any more. Tried to bake it and really got ugly, not changing color. So I went bare naked.
Most of the time I take pics of a polished light and see that I need to do-over. Back to 2000 wet and usually harder polish cause it’s late and frustrated. Worn 2000 paper will help also.
Grease the threads, and I usually wipe a thin coat of oil inside. Sometimes the Lye is not rinsed off good enough and white oxidization forms in a few days.
Thanks for the tips
I really like the metal switch, but that’s OK. Having the silicone one on this just means that it’ll get an illuminated tailcap soon. I’m thinking white or white & blue on this one, should go with the bare metal nicely.
Coffee is working this morning… Tiny parts.
SF348 got a new emitter. Yeah, another 219B 4000K High CRI.
Cleaned up the pill, removed burrs and flatened best I could. Opened the reflector a bit too much and got a couple scratches, but oh well it fits the emitter. There was no thermal paste on it. reflowed the emitter to the original 8mm aluminum MCPCB.
Bought it cause it was $4.50 but never used this light because it was an awful color. Now I may grab it on occasion.
Got tired of the SF348 screaming “Polish me, Polish Me!” Hope the voices will stop now.
Locator switch light on the S10R II i got from - X3 -
Sweet mod !
You like tinkering with small LEDs don’t you ?
TA driver, Bistro
Eagle-eye X7
XP-G3 5000K
more incremental work on my “scratch build” DIY-USB microscope project…
melted zinc, cast it in into a short piece of round stock, 3 or more inches in diameter… for inexpensive “practicing” making the general shape of something i will make later out of aluminum stock.
practicing the shape on aluminum would be cost prohibitive, lol…
