Convoy L2/L6 modding thread
977 posts / 0 new
vestureofblood
vestureofblood's picture
Last seen: 1 week 2 days ago
Lights-Out wrote:
SBT-70 in my convoy L6
! photo tmp_30300-IMG_20170130_183632288_HDR-732602422_zpsttsnbtiq.jpg!
Love that. I SOOOO wish there were more round emitters like that. Great mod.
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
Lights-Out
Lights-Out's picture
I have 30 of them Smile
vestureofblood
Mitko wrote:
Those warmer 5000k – HI tints tent to burn out kinda wierd and sometimes fast when harly overdriven…i dunno if its just my luck, noone shared a simmilar experience
Just now I took an XPL HI V3 3C and drove it to 7.4amps (4.4 volts) to see if it would survive. It did. I dont know output was any good at that current (didn’t test it), but in this one test it worked ok.
J-Dub74
J-Dub74's picture
Last seen: 10 months 2 days ago
Big Smile Thumbs Up
I love seeing stuff like this! Thank you for sharing. More details please!
KawiBoy1428
KawiBoy1428's picture
Last seen: 8 hours 12 min ago
The V3’s are tough been running 2 different UT02’s on the 20700A’s 26mmFETDDVishay sir404 FET’s with copper driver adapters and both V3’s are seeing over 6.6amps the V3 5700k is at 6.81amp hitting hard just over 7amps at start up and surviving, no problems so far!
In other news today, I opened up my options to 30mm (Noctigon that is) and have several candidates for thrower emitters now that the reflector minus the stand off at the base, can sit directly on the board, with the option to shim for focus. I have a several de-domed emitters to try, and yes even a couple OLD XP-G2’s that are pulling 6.04amps at start-up and settling down to 5.80 amps. Some de-domed XP-L V6-1A’s cause the XP-L V6 0D’s suck! And of course my beloved XHP35’s HI’s and a couple de-domed E2-1A’s that are just about ready, can’t wait to see the tint shift on these! Big Smile Thumbs Up
KB1428 “Live Life WOT
The_Driver
The_Driver's picture
Last seen: 8 hours 5 min ago
Which variant do you have? Standard cool-white oder maybe 5700K high-cri?
Mitko
Mitko's picture
Last seen: 3 months 24 min ago
You lucky then, presonaly i dont high drive those anymore, cant rely upon them, imagine if they start popping what would all those huntingfriends of mine think about me Smile
Without a spring bypass at about 5 amps…works for me, for the rest dedoming Smile
cold white tints are way more durable, in fact i dont recall seeing one of those with burns near the bond wires
Lights-Out
The_Driver wrote:
Which variant do you have? Standard coo.-wheite oder maybe 5700K high-cri?
It’s been awhile I’ll have to do some digging for the info but the one I threw in looks cool white
vestureofblood
Just now I had the chance to do some testing.
L2 *host, V3 XPL HI emitter, FET driver = *205,000 lux.
That is with the factory lens and not an ar coated. Also with the factor focus. I just popped in a ring. I was using a keeppower cell which are pretty good, but I think there is room for improvement there too.
To be honest I am pretty happy with that for something I just put together and spent no real time optimizing.
Anyone know if there is an AR coated lens being sold for the L2?
ZozzV6
ZozzV6's picture
Last seen: 15 hours 13 min ago
The L2 is sold with AR coated lens since a year. If your not support 17mm driver just bigger, 20mm if I remember correct it has to be AR coated.
DB Custom
DB Custom's picture
Last seen: 4 hours 42 min ago
It’s giving me the cold sweats trying to resist those SBT-70’s…. Ughh
vestureofblood
The one I got still fits a 17mm or 20mm (which I think is better), so I guess that would be the reason I didn’t get an AR lens with mine.
Lights-Out
Same here can’t wait till my parts comes in from Richard to finish my 2 builds
1. Will be in my convoy L6
2. Lumintop sd75
To be continued….
Tjhosan
Tjhosan's picture
Last seen: 4 months 1 week ago
Question about the “old” new L2 Banggood L2 host
I like the block style knurling on the tube instead of the new style. But what else is changed?
Is it 17mm driver hole in the old one or 20mm like the new?
Also there was talk of single cell tubes for the L6, what style of knurling is it on that?
Regards
Erik
J-Dub74
J-Dub74's picture
I like the block knurling better too, it just wasn’t very doable with the single-plus-extension approach as it’s nearly impossible to get the blocks to line up properly and Simon didn’t care for that aesthetically. He went with the “ring style” to avoid mismatched blocks. But to appease me and a few others he did make a single piece two cell tube with the block style knurling. That’s still available in the Convoy store as far as I know and the single cell block style tube will fit both the L2 and the L6 so that one’s covered. I imagine that new tube should be on sale pretty much as soon as the store reopens.
As far as what else changed on the L2 from the single cell version to the convertible (current model), the driver pocket went from 17mm to 20.5mm. The single cell version used the 17mm LD-25 driver and the current version uses the 20mm LD-29 driver that allows use with either one or two cells. Other than that the longer tube added the threaded tactical ring which can be swapped with a simple ring that just disappears and hides the threads for the ring if you don’t like the tac-ring. I think that pretty much covers the changes.
KawiBoy1428
Finally got most of rings, hazy fuzy corona out of the Convoy Test Smooth reflector L6 XHP35 E4-3C HD build! By diffusing the bottom shelf of the reflector from the emitter hole, up the side about 2mm! The Ole PFLEXPro Hybrid Reflector Mod,Thanks Randy! Thumbs Up
Now for the 4S 26500 battery tube mod. Used a fine wire, wire wheel on my DotCo die grinder to remove the non conductive material. Finally found a use for all those beauty rings I have laying around! Big Smile Now that don’t look too awful bad, now does it! It’ll work for me! 2S tube and the extension. Bro’s! In XHP35’s JAX X6 Hunter 3+ amps E4-1C HI and the L6 3+ amps XHP35HD E4-3C Looks pretty close to 3,000 lumens to me…
JasonWW
JasonWW's picture
Last seen: 46 min 52 sec ago
Excuse my noob sounding post.
I’ve wanted to bump up the power on my L6, but didn’t have a resistor. I started thinking about the stock FX30 driver I bought at Kaidomain. I had planned to swap it into my L6 and do mods to it, but decided not to. What’s funny is that it was supposed to come with an R100 and R082 resistor and is supposed to pull about 4.5 amps on high. Simon modded his drivers with a pair of R082 to bump up the output to 5.25 or so. I started looking at the stock driver and it’s not like the photos, it actually had a pair of R082 resistors on it. How odd. Maybe the manufacturer decided to alter them for a bit more power? IDK.
Anyway, I was robbed of an R100 resistor so I decided to pull an R082 off of it and add it to the Convoy driver. It was a pain working with something so tiny, but I had success. It works and no burnt smells. Yay!
I just bought a lux meter and measured the output from a ceiling bounce test. Turbo went up from 311 to 341 when measured at same voltage and after 30 seconds. I don’t know if that’s a big increase, but I can see less yellow around the hotspot. It definitely warms up quicker, but that’s not an issue for me as I use it for short bursts of 10 to 20 seconds mostly. Now to take it to work and use it normally for a week and see if I notice it’s brighter and if the batteries end up at about the same 3.6 to 3.8 volt range after the last day.
Click this to go to signature links.
Spud
Last seen: 1 hour 43 min ago
if i could ask, what would be the logistics of making an illuminated tail switch?
any interference with the UI?
DB Custom
DB Custom's picture
Not as much of a problem doing the illuminated tail switch on a single cell L2 as it would be for a 2 cell L6. No expert on it and haven’t followed Pilotdog on it so he might have figured how to do the 8.4V reliably, you might check with him.
Mitko
Mitko's picture
I`ve tested tonight L2 / XPL W2 1A@ 6.2 amps agains 1s L2 dded XHP35 E4 1A @ 1.6 amps, both emitters gave nearly the same output, arround or equal at 2000 lumens yet W2 is like 300 000cd and e4 like 215 000
Unfortunately my XHP35 driver fails above 1.6 amps( on a long term base, coil/heat issues) but i guess that at 2.-2.7 amps the XHP will perform kida equal: more lumens yet lower cds : a 2.5 amps driver XHP35 gives like 2500lm/250cds in the L2 host but with a different driver
Texas_Ace
Texas_Ace's picture
Last seen: 2 days 4 hours ago
The lighted tailcap works fine at 8.4V assuming the driver works with it. You just have to adjust the resistance for the higher voltage (takes about twice the tailcap resistance).
DB Custom
DB Custom's picture
Perhaps for you, but I’ve found the UI to be messed up when trying to use the lighted tail cap with a Zener modified FET. I had reduced resistance to 11K ohm on the tail switch lighted board.
I’d venture to say it’s not always going to be a straightforward or easy addition to a light. Don’t know if it’d work on the stock L6 driver at all without some modifications.
Edit: It’s MUCH easier to put a clear boot in place of the black one and install a tritium vial sideways through the post inside the boot. No drain on the cells, easy to find it in the dark.
Spud
i like the tritium post idea.
tryig to work out all the electronics hurts my head, but some of the boys on this forum do it with ease, bastards. Wink
still amazes me as to how far and how complicated some lights have become, seems like the battery and led tech has gotten to the point that only heat dissa[ation is the bottle-neck.Seems as tho the next generation of lights are gonna all posses some form of active cooling.
either way, very interesting.
DB Custom
DB Custom's picture
MRsDNF already built a large one with air cooling holes through the finned pill, the next step would be to install a small MCU controlled fan and link it to the temperature. With a lot of the drivers now going to ATTiny25 and ATTiny85, the storage space is there for programming fan controls I would think, so yeah, just a matter of time…
jdh00
jdh00's picture
I took off both R082 resistors and put a small piece of wire across the pads. The light still only hits ~5.25A on turbo. I have myself convinced that bridging the pads should give me all the amps the FX30 has to offer. What am I missing?
Texas_Ace
Texas_Ace's picture
What cells are you using? Bridging the pads should give you 9A+ with good cells.
jdh00
jdh00's picture
Unprotected Keeppower 5200mAh fresh off the charger.
Mitko
Mitko's picture
The bridge isnt good/ the springs are loose/ the spring/battery contact isnt good/ the driver ground isnt good/your MM isnt accurate or your MM cables arent thick enough….so many reasons…
Like TA said: arround 9 amps, pay attention that the driver could mallfunction with this mod( i have several friedalready) especialy on a long term base
jdh00
jdh00's picture
I’ve reflowed the bridge a few times, so I feel confident it’s good. The bridge wire is a solid piece of 22AWG. I’m measuring current using a clamp with a 3” piece of 16AWG between battery and tube edge.
Thanks for the heads up on how aggressive the bridge is. I plan to swap the driver out soon anyway, so I’ll probably just abandon this quest for now and focus on that. I want to move to FET based and Narsil for ramping.
JasonWW
JasonWW's picture
Has anyone here noticed that the stock L6 reflector seems to press down on the red and black wire insulation more than it presses down on the centering ring?
I can remove my centering ring and the reflector won’t go down any farther.
I’ve got an smo reflector now and I’m trying to think of a way to get it lower to improve the focus. Some have swapped to wires with thinner insulation, but why not just cut some small holes in the reflector base to clear the wire and solder blob. Then I can drop the reflector a lot more to see if it helps the focus.
