I do hope it’s silicon based. I spent several hours removing a LED star epoxied down to a light once, tried heat, freezing, and enough prying that I eventually split the star into 2 separate halves, both still epoxied down.
Aw, shucks. They designed it to be uninteresting to folks like us.
What, they can’t imagine a better emitter coming along anytime, ever, that we’d like to swap in??
Hm. Well, it’d be nice if they’d offer one that’s not glued down, for those of us who expect the improvements in emitters to continue over coming years.
I can see that they’d rather sell entire flashlights as new emitters come along.
If anyone need we use a silicon paste instead of the glue, we sure can do it for you .that is too easy .
but we will do it only our buyer reqire it.
To use a silicon paste is more easy and low cost than now.
You are right, for most users it is good to fix everything in place, it makes the flashlight more robust when it is dropped.
But here at BLF we are a bit different, usually we try to disassemble a flashlight even before switching it on :partying_face:
And only seldom we are happy with the leds, we want to be able to change them without damaging the flashlight.
It is very forthcoming that you are prepared to make a version of this flashlight without glue but normal thermal paste, thanks for that!
Parts would need to be packaged so that delicate parts like reflector isn’t scratched. This might seem stupid to mention but we’ve had manufacturers send parts all in a pile and reflector is ruined
Selling the host would be a good alternative also.
TIR is standard 10507 that we can supply easily, as well as triple MCPCB from Noctigon or whatever and driver will be replaced anyway for FET and so on…
Yeah, a host option would be great
