longest running AAA light?
I’d be more interested in max lumen-hours.
Any light can last forever if the output is low enough.
Also I’d like the light output not to vary over the lowering battery, until it has nothing left.
I can see that. I can only go by the advertised lumens of the LD01, and it ran for over 32 hours at 3 lumens. Since I am not sure when it started to fade this is just an estimate, but 100 lumen-hours with a constant output. Not too bad for a AAA.
Thrunite AAA flashlights are know for very long runtimes.
ThruNite Ti XP-L claims 115 hours with 0,5lm output.
Older models (Ti3) have even lower firefly mode around 0,04lm but also older LEDs so the stated runtime is 115h as well. With good alkaline, or better yet with lithium AAA cell, this runtime should extend further.
Disappointing result from the Thorefire PF03 with 750mAh eneloop, between 26 and 27 hrs before it was dead. I was hoping for at least a week, maybe it would run longer on alkaline batteries.
Now testing the Tools with the same batteries.
I thought 240hrs was too good to be true at that level. Thanks for sharing the data.
Google search “joule thief”. Can light an LED while running the battery down to ~0.3V, well beyond when it is “dead” in any other light. Can run for weeks.
Nice! Thanks for the tip. I now understand how changing the inductor in the link referenced in the OP changes the output. I will be gathering up some parts to make one of these when I return home.
The main problem is that at low loads the boost converter is not efficient anymore,
bacause the power to maintain it is not much smaller than the power needed to drive the LED,
So the runtime between 0.5 and 0.05 lumens wont be anywhere near 10 times longer
I bought at Thrunite Archer V3 a couple months ago, probably should have considered the one you recommended also. At the time I was looking for a AA light, now I feel a AAA would suit my general EDC needs better. Or a AA that is much simpler (and smaller).
70 hours into the test and the e+lite is definitely fading. Since I was traveling all day it is hard to say where between 56 and 70 hours it dropped off. But now it is just a bit brighter than the Manker E01. I was using the e+lite to read a map while traveling tonight, so it is still useful. Same brightness 78 hrs in.
And somehow the Manker E01 battery is still at 1.28V. I checked the light a few times today to verify it stayed on, but somehow it is bright as ever and no change in battery voltage. Not sure how sensitive the voltage of a eneloop is to temperature, but it is a bit warmer here than where I measured it early today, probably 5-6 degrees C. 1.27V at 78 hrs.
restarting the LD01 on an alkaline battery now, 11pm EST. Fresh battery measured 1.53V. 1.37V at 8 hrs into run with alkaline.
The aluminum version has expired between 23-26hrs, but my copper version is still running at 27 hrs. I believe the copper to be the ‘efficient driver’ per this thread Efficiency Copper Lumintop Tool, Worm, Maratac, ReyLight
When running them, I’m recording the time to when there is no light from the LED without interruption. I know sometimes if a light is turned off and the battery rested then it can give a little more, not sure about the science here but I’m sure someone does.
Thanks for the data! I have not looked up the tool output levels, I am curious to hear how it compares to the 3 lumens advertised on some version of the LD01. Likely not my version, as I have been able to find out very little about this particular emitter, the XP-E R4.
As far as not shutting of the light goes, I thought about that but decided it is a bit more real world than just leaving a light on until it dies. Also, I don’t have a way to quantify performance other than camera beam pictures, which are a bit of a pain to load on this site.
91 hours into E01 and e+lite runs. They are about the same brightness now. The E01 battery is still at 1.27V. If I was not measuring this myself I would not believe it. The light intensity has not changed from the test start for the E01. The LD01 is at 21 hours, battery voltage is at 1.28V. No drop in light output yet for the LD01. I hope to be sleeping at the 100 hour mark for the E01 and e+lite, which will be the 31 hour mark for the LD01. I suspect by the time I get up they will still be running though.
So the LD01 lasted 38.5 hrs on a alkaline battery. I took the battery to the meetings I was in for work today and peeked at it periodically. I was able to see it fully illuminated and then 10 minutes later looking dark. When I returned to the hotel in the evening I turned it back on and it produced full level low light for about 40 more minutes. It slowly died down to barely discernable light, and then I removed the battery and quickly measured. The battery had recovered to about 0.38V and rising. The review link below shows behavior of a version of the LD01 that looks very similar to what I observed. Operation down to 0.3V. I am thinking I don’t need to make a joule thief, I have one already in the LD01, which seems very efficient. I can’t verify the intensity level of this light but if the advertised 3 lumens is correct, then I got about 115 lumen hours out of a 4 year old alkaline battery. And the light does come back on at medium level resting during the time it took me to type this post.
I also did another voltage test of the E01 battery. It is holding tough at 1.26V after 116 hours. Just as a sanity check I put a new eneloop in to compare the light intensity which best I could tell had not changed since the test beginning. I can see that there is some slight dimming of the already dim light, but not much. The light is still useful finding your way around a dark room, still puts out enough light to read by, but maybe not fine print. I also found out that the mode memory timeout in the light is a function of the battery voltage, which is no surprise. When I took out the new eneloop and put ack in the old one, I observed (twice) that the light came on in medium mode with the old battery, and I had to switch to high then back to low mode. The first time I thought the light was just flaky, but after the second time I realized it is the short term mode memory. I tried two more times, both times waiting well beyond 10 seconds, and it came on at low in those cases. Also, it never came on above low when I put the new battery in. Fun stuff!!
I leave for the west coast way too early tomorrow morning, so I may not check any voltages for a day or so. I have no doubt the E01 will still be on, we will see about the e+lite, which continues to very slowly dim but is still putting light out.
The problem with those joul thiefs is they cant be run by NiMh without destroying the cell
Do you know if alkaliline batteries leak more if discharged so low?
I don’t know if leaky alkaline batteries is a problem these days or not. I have limited experience, basically this one cell, so far no problems.
I got even never used cells as backup for my DLSR camreas flash leaking 2 of 4 stored in my camera bag after 2 years
The worst thing is that you grab a light when you need it just to notice its not working anymore and the battery is glued inside by leaked electrolyte and battery contacts corroded like crazy
I would only put alkalilines in my 500€ flash or other expensive gear in an emergency situation and take em out after use charging my NiMhs
So what was the run time for the copper version?
200 hours 1.16V of light out of the Manker E01, test over. The light was still usable in the middle of the night for navigating around a dark house. I don’t want to keep discharging the eneloop, and also want to start investigating the current vs voltage profile. I put a new alkaline in it today and found that it is as bright as the AA Archer which also claims 1 lumen on moonlight. The eneloop was never that bright, so it seems that the output is not regulated on moonlight is the E01. Plan to upload some pictures now that this phase is over.
It lasted between 28-29.5 hrs until dead, so actually not a whole lot longer.
I tried the IYP head on the Tool over the weekend but it was dead by the time I checked it today, so all I know is that it’s less than 63 hrs. I like the mode spacing quite a lot, I’m tempted to keep it this way
Impressive time for the E01, I’m partial to click switches but that has me interested
