There is a user video on YouTube of the DT70.
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
I recently received the Imalent DT70, three of the four LED’s work, one is dead. I had it tested in a well known calibrated sphere and on Turbo was putting 9,000 lumens out the front, this is with only 3 of 4 LED’s… unfortunately this defective light has been very frustrating and a lesson learned. No one will repair this light, not even some of the most recognizable modders…Return shipping ranges from $65.00 USD up to $175.00 USD !!! I would not recommend purchasing any Imalent light. They do a very good job of giving you the run around in hopes your PayPal escalating deadline quietly slides by…
I have pictures in the Dealers category.
Very upset!
LT
Did you contact the store you bought it from about it being defective? Sometimes they will fix the problem. Refund or replacement. Nevermind, I see your in talks with Banggood.
Or did you contact imalent for warranty work?
Your situation is what I worry about from other Chinese only companies that do not sell replacement parts for their lights. With companies like Eagle Eye and Convoy I can buy parts easily and fix it myself. Having to ship a light back to China, on the other hand, can be quite expensive.
Did you explain your problems dealing with Imalent in a thread? I’d like to learn more about how they treat their customers.
So far I’ve heard people say that both Klarus and Olight ignore warranty claims. Are there any companies that take care of their customers?
If all the LED’s are in parallel then it would have to simply be a lose solder going to one of the 4 LEDs. I would think it would be not too complicated of a fix. Getting to the LED’s may be a different story. Your neighbor over there likely not looking for a fresh can of worms to open. That’s too bad if you’re left little recourse for amending the situation quickly. I know that crap’s frustrating. I just put in an order this morning too. I’ll see how those dice roll.
Thanks for posting these issues.
I recently ordered the DN70 so these videos aren’t sitting well with me at all! :person_facepalming:
However, GB did take an extra 10 days to start shipping it so maybe they got in some newly revised stock that addressed these issues? dunno.
I’ll post my impressions and any problems encountered when I’ve had the chance to play with the light.
Here’s a good review of the DT70 by Charles BridgTec.
yeah, i had high hopes when they came out also
todds not the only one that ive heard of having issues
there have been several others
bad thing is how they are handling it
only takes 3 or 4 people with their dander ruffed up these days on the innerwebs, and a company could loose multi thousands of dollars
seems they would learn that ………
Having a lot of fun with my DT70, it’s definitely 15,000+ Lumens on turn on but ANSI would struggle to get that unless they measured it in Greenland. Here’s how it compares with my other small lumen monsters:
Comparative ceiling bounce measurements:
Nitecore Tip CRI
High 19 lux
Turbo 39 lux - 39 @30
Nitecore Tip
High 19 lux
Turbo 46 lux - 46 @30
Olight S1R Baton
Med 13 lux
High 53 lux
Turbo 86 lux
Turbo S 106 lux - 106 @30
Olight S2R Baton
Med 13 lux
High 66 lux
Turbo 119 lux - 119 @30
DQG Tiny 22650 3th NW
Med 46 lux
High 106 lux
Turbo 271 lux - 265 @30
Acebeam EC50 Gen II
Low 6 lux
Med 66 lux
High 159 lux
Turbo 291 lux - 278 @30
Thrunite TN36UT NW
Low 13 lux
Med 66 lux
High 205 lux
Turbo 636 lux - 629 @30
TN40vn Spec IV
5% 59 lux
15% 152 lux
50% 516 lux
70% 722 lux
Turbo 1027 lux - 987 @30
Imalent DT70
Low 19 lux
Med 132 lux
High 854 lux
Turbo 1620 lux - 1451 @30
Seriously impressive performance. Unbelievable how it humiliates the Thrunite… Also nice to see the more balanced beam profile with dedomed emitters… Thanks a lot for the video.
The Thrunite TN36UT NW’s output is no where near the claimed specs of the CW version.
2400ish lumen DQG hits 271 lux and the TN36UT on it’s 2500 lumen mode hits 205 lux. Fully charged hq cells and different bounce locations yield the same results.
The DT70 just kicks arse on all its modes, but I do believe they tested it in a cold environment to get high ANSI figures as it gets hot and loses efficiency fast. 1600 lux to 1450 lux in 30 seconds in my 15c kitchen. Be interesting to do the same test with the X45 and X7vn.
Perhaps nobody knows Imaplent …
Nice video comparison, KG_Tuning
Here is a second DN70 that is malfunctioning. It goes to strobe instead of 3800lm.
I think the problem here is the battery.
If you watch the video, at some points, voltage readings pop up on the display. When he first switches to 2500 lumen it is 3.51V and sinking fast. A moment later it is 3.48V At 3800 Lumen it would be even less as the load would probably be twice that of 2500.
I had to download the youtube video and afterwards I was able to capture this still from the video. At the point when this light was in “3800” lumen mode but was in strobe mode, the voltage was only 3.36V
Are you telling us this information or telling the guy in the video?
Tell him and if that fixes the issue, come back and tell us. :+1:
My voltage reading is usually 15v out on my DT70, if it says 3.95 on the torch the batteries will read 4.10 in my charger.
