@Jaxman - re: the glue, the other thing to consider is that as shown in your OP, it's quite excessive. Unless there's some proprietary sauce in there that allows the heat conductivity to exceed (or even match) metal<>metal (in this case, I'm assuming Cu (300+ W/mK) to Al (200+ W/mK) thermal conductivity, only enough should be used to fill the micro gaps between the two mating surfaces. As a general rule re: glue, less really is more, and anything in excess is counterproductive for heat conductivity since even the best thermal epoxies (10+ W/mK) pale in comparison to the two aforementioned metals.
The E2L looks promising, good luck with the sales.
Hoosh, you’re new here, and being rather strongly critical of me (and others) who have been asking about the goop pictured on the flashlight.
Look back at your posts — you’re choosing harsh words to criticize us. This isn’t Twitter!
Folks who’ve been around here a while do recognize what makes a difference.
Flashlight makers get early feedback by coming here.
Jaxman did right by us by offering a host and understanding the comments made.
Notice how replacing the glue with silicone was suggested — and immediately flagged as a bad alternative.
Notice the information on thermal conductivity — heat transfer — and how thick — or rather, thin — the material ought to be.
You don’t need an engineer to know which way the heat flows.
Will the extension tube threads from the Z1 fit this new flashlight body?
I find it tempting to use with a LED and driver that will require using 2-battery cells
Can you sell me a light — neutral white — with NOTHING in between the LED and the shelf?
Or, if not, a host with no driver or LED at all would be ok. I do want a tailcap switch as part of a host.
Harsh? Hardly. I’m extremely critical of those that simply want to slag on a manufacturer simply because they don’t think a given manufacturer “put the correct LED in a light,” or “uses the wrong optic,” or any other nonsensical complaint about a light they probably have no real desire for anyway - except to try to reengineer that which is already working fine.
Even here on BLF, most people aren’t of the “let me get a light and change it before I even turn it on because I know I can make it ‘better’” mindset. I’d wager that the flashlight production field would be vastly different if all of these armchair engineers actually tried to produce a large production flashlight. Use FourSevens as but a single example of one manufacturer that initially catered to the fancies of the very tiny but very vocal minority and produced lights said people called for. Now what do they produce? Lights that most people actually want, instead of what the very few, but again, very vocal minority were - and still are - clamoring for.
My much larger but very clearly missed point was why slag on a manufacturer for not making the exact light that a few want when those few can simply go to Mtn Electronics and buy all the individual parts they want and then create until they can’t create anymore? They can be the flashlight engineers that the much larger - and, coincidentally, more successful - producers “aren’t.” I’m sure all their friends are tearing down their doors with wallets in hand ready to purchase such monumental engineering feats that the lighting industry could only one day hope to produce.
Besides, my opinion certainly won’t change the minds of the very few but very vocal minority that will continue to cry out to be satiated by flashlight producers.
To my point, I see you’ve already made your demand to Jaxman above on how you will build a much “better” light…
That’s why we prefer lights that aren’t glued tight. If you spend a little time here you’ll see that’s been an issue with several other manufacturers. Not just my issue.
I’m in no position to demand anything. I’ve asked Jaxman here in the past for a host and been delighted to be offered the opportunity to buy one (and Jaxman made hosts available to everyone here to mutual benefit).
Same situation here — they find out what we like because it’s useful for them to know, and we try to be helpful and not rude about it.
Hoosh, we are not so demanding with every flashlight, but particularly on this flashlight because it seems extremely useful as a host. Most of us modders can swap parts and many fancier things, but we can not machine the flashlight itself. This is the first flashlight that is in stock form build for triple optics and uses only standard parts and sizes. I’m sure for many people it is great as it is, but for the (pretty large) group of modders on BLF it promises to be a dream host as well.
jaxman, I ordered the EL2 last night, along with the higher powered UV light. Would it be possible for you to send me the EL2 in host form, unassembled? I have Nichia 219C emitters that I would like to use.
I already have 2 Nichia UV lights, one with the highest emmitter (NVSU333A) and one with the (NVSU233A), yours will round out my UV collection nicely and the black lens is really a nice addition, looking forward to that! I’m wondering if you might be able to help me source a 35mm lens in that UV pass type? I have the NVSU333A in a full Copper X6 at 3640mW (3.5Amp) and it would be really nice to have that specialty glass.
Now due to short of human resources, we have to sell only completed flashlights.
I think we must can sell host for dears like you. Pls give us some time.
Your package has been shipped out.Thanks for your appriciation.
I was wondering the same thing Glenn, enough to put some dough on the table. lol
At a glance, the $40+ price tag of this light might seem a bit much, but the Nichia emitter is a very big piece of that in and of itself. I know when I bought the NVSU333A direct from Nichia it was $108 and required a signed letter of release and my own business letterhead to buy it. It’s potent, no doubt about it. At any rate, the black lens and nice build of this one should give it an appeal for carrying to check hotel rooms/beds and the like.
When you go out to eat, don’t you ever wonder just how clean the bathroom REALLY is? (I know, sometimes it’s perhaps best not to know but I’m a very curious sort…)
I actually used one of those odd looking clear jellybean looking “optics” from Nichia on the NVSU233A that I have, it makes for a beam pattern and works pretty well but is rather odd.
I guess I should order a camera lens filter in the black UV pass glass and adapt it to fit my 35mm requirement in the X6/NVSU333A light. I might get lucky and find one that the glass fits, hope so, as I really do dislike grinding glass.
Thank you Jaxman, figured it was too late to ask about the order I’d already placed. Looking forward to future purchases with some flexibility. Much appreciate your insights and willingness to help us out here.
