I got BG to send a replacement reflector. Not only is this one free of speckle and slightly better machined, the pattern inside is much finer. My best guess as to the stuff is whatever was sprayed inside to make the pattern. Does not clean up or scratch off.
Ok, so its my first attempt at bending piano wire. Its not exactly perfect but its proof that it can work. The clip came out a bit shorter than I was trying to make it. But the up side is, now its easy to take off the tail to charge the battery and it doesn’t scratch the sides as you turn it. I think my second attempt I will try again to keep it about this short. I already like it more than the convoy S2 clip that I had on it. That damn thing wants to scratch everything that I walk past!
I used 1.2mm Piano wire. Generic stuff from ebay These M2 sized screws
and the M2 sized nuts to fit them.
Yes thats the tailcap off a BLF A6. I immediately gave it a polish as soon as I got it out of the box. It looks much better now. I just borrowed it since its one in the same as the S1 cap.
Can the NCR18650B battery be used? And will the Keeppower IMR 18350 flat top battery be used? Can you tell me which 18350 can be used for flash light?. If I use the olight 16340 , will the light’s performance be reduced?
Thanks!
