Thanks for this, the Thorfire is my favorit.
Thanks MILSPEC
i like both lights
L6 is more sexier whereas S70S have more features and performance
Nice
Can you measure temps of the Convoy too?
ok i will measure the temperature to stock light L6, modified L6 and modified S70S tomorrow.
In room temp without cooling the handle on my L6 gets up to 70 degrees in 20 minutes. Haven’t measured any further to avoid damage to the batteries. The head got to 75°C.
I didn’t realise you live next to me lol. I remember you told me but I thought you where joking. Where the gates around the loop closed? To many goofs hang out there. you should go to headland where the golf course is.
When I tested the L6 I went to kernell behind the refinary. No people at all.
is that the stock light L6 (no driver modification) you measured Maukka?
70 degrees is definitely hot to hold and seems unsafe for battery too.
Yeah i dont live far from you everydaysurvivalgear.
Lots of trouble makers at this location aspecially at night and i was lucky enough the cops were around the corner that night.
I will find another location for longer beam shots.
Yes, bone stock with Liitokalas and the 3A tint.
very good comparison!! Thank you
OK so when you are measuring, turn the S70S on at the same time, when it steps down, just put the L6 in high for a better comparison.
Good info, thanks for the review!
Great info. Looking forward to quantitative measurements as you mentioned (lux, temp, current)
I can’t wait to receive my s70s in the mail…
I added the temperature analysis graphs.
Please note that I bought these lights with my money and i didn’t want to measure to the extreme point as i’m afraid it will damage.
i will do further testing with time as i have personal commitments and i hope this help others looking to get one
Nice, thanks!
Nice, thanks!
Thanks for testing. At least Convoy does state that the light shouldn’t be left unattended on turbo for extended periods (“never turn on the turbo mode all the time”). When you’re holding it, it’s very clear when you should switch to a lower output.
Thorfire S70S have good temperature regulation and Im comfortable to hold the light at 50 degrees.
i will test long distance beam shoots mod L6 vs mod S70S next couple of days to see how they perform in real life
Nicolicous, thanks for posting this. I’m now more tempted to get the S70S after reading your review :person_facepalming:
Wait, thorfire’s lens is not AR coated? Too bad
