Thanks HKJ, also to confirm me that it has 5A max input because somewhere it's stated 3A as the other ones.
I was also interested in YZ 1271 but i'm unsure if the extra input will be useful for me. Also some questions if you could reply:
Is this USB IF PD compliant? I've found it described just for 1271 version
Is this DASH/OPPO coding charge compliant? I've found it is in some chinese sites, i do not expect you to have OPPO/DASH compliant devices (obviously i won't) but maybe it would be nice if you have some insight, maybe from your seller
Can this version force fast charge as it would with the old yellow 1230 version
Yep!, Seems their top of the line but it doesn't matchUSB 3.0 standard, not an issue to me since you rarely will be using this to monitor current while data transferring, IMHO and even so you can get an idea with USB2.0.
I would have both the 1271 if it wasn't the most expensive.
I would thank HKJ for this review, once again, very often when i want to buy something to feed my geek instincts i found a nice review from him.
Also i would like to verify the VOOC/DASH charging thing with my OP3 once my 1273 arrives because in this table from their sit (at least what i think it should be their site) shows DASH capable. And since DASH has a max current of 4Amp, it could fit in their 5A version, but i guess on the other hand HKJ could have its point with the missing pins from the Type C connector. Don't know, I will check it out
The new digitally controlled dc load ZL1100 is also cool. I always hated the trimmer pot of the ZL1000.
edit: heh, you just added the ZL1100 link, oh well
edit2: Franky also has it listed on his ebay store I’d like YZXStudio to supply it with a serial logger program much like the EB tester software that is able to program their loads.
The ZL1100 looks interesting, but is sold out. I have a couple of the ZL1000 load and all is the version without trimpot, the only one with trimpot I have is the one I reviewed and I usual do not use that one.
Ok, I got few questions now, seems my unit is not able to set some of the parameters I have available in the options, to be more precise I cannot set any of the option from 14 to 19 (14 and 19 included) which are
14.Trickle charge current
15.Trickle charge delay
16.Over current protection
17.Under voltage protection
18.Over voltage protection
19.Over temperature protection
Withouth these the meter is just a normal meter with higher resolution
My fw is 3.30 Y1273 could someone check in his for me? Also if someone has the English manual and could share it somewhere would be great...
Now that i have my zy1273 i can say i like yours much more.
Anyway, if you have a decent multimeter and a USB plugs with terminals you could measure current and say which one is off.
Otherwise you could roughly say it by attaching an Android phone (i don't know anything about ios) with an app called Ampere or another called Accubattery, which measures fairly well (considering that is just an approximation) how much current it is flowing through the phone. This at least, considering the big difference in numbers will tell you which one to trust and which one recalibrate (if possible)
I don't know if yours can recalibrate i'm pretty sure 1273 is not thatconfigurable (pretty disappointed by it)
