Headlamp like a skilhunt H02 or H03, takes 18650 and cr123. It’s the most flexible light I can think of. It shines where you look at and fo traveling with a bike a headlamp is a must have. Try setting up a tent/tarp or fixing your bike in the dark while holding a flashlight: annoying as sh*t.
H02 review
H03review
I’m just saying skilhunt cause those are the ones I use(d) and liked the most but look around nd maybe you’l find some other headlamps that might suit u better.
Wow, just recced this light not 5min ago.
Ultrafire DV-S9. Waterproof (diving-light, so duh), magnetic-slider for everything from moonlight to full-tilt, 26650 but comes with a tube to fit an 18650, and you can get (but I don’t recommend) a 3×AAA adapter as well.
Nice throw, lots of spill, only is maybe 6000K if I had to guesstimate. A bit cooler than my 5000K EDC, but not as Angry Blue as cheaper lights. ~15bux at FT with BLF discount-code.
I’d also recommend a Boruit RJ02 from GB for 8bux for another few hours (flash sale). Amazing critter for the price. Ramps up/down in brightness, has a magic wave on/off if you need it. Great for supplemental lighting while the DV-S9 does the heavy-lifting.
My convoy S2+ with XPL HI and narrow TIR makes a great beam for biking. The reflector gives a nice beam with this LED, too. You can choose the driver and LED to get the modes and tint you want. This is what I would recommend, although it doesn’t have the ability to take standard AA type batteries. You will need a 26650 size light with a 3xAAA adaptor.
IMO floody 18650 head lamps do not have enough throw for biking.
Thanks,
I had a wtf moment with the skillhunts but then I realized how the odd design can be very useful. But I can’t see a way to mount them securely on the bike, you can’t buy batteries anywhere and it’s way over budget ‘_’. The light emitted was impressive though
I’ll check the ultrafire. I almost bought the boruit, loved the wave feature and the price was good. but I decided to not act on impulse, I’ve done enough lately and anyway I can always get it later for $2 more.
The photos I have seen from convoy s2’s and some others from the s series show a more focused beam. Have you used it with TIR riding a bike? Does it have enough flood? There are lights that combine 18650 with 3xAAAs tank007 tk737 is one of them. 26650s will need both the 3xAAA holster and a sleeve I think.
I think you can get the H02 for around $26 and for the H03 there’s a code floating around to get it at $29 if I’m not mistaken.but as easyB said maybe not enough throw? I gotta say I don’t have that problem when I drive my bike but I don’t drive on mountain paths or in dodgy woods at night. I don’t fix my skilhunt to the bike, I keep i on my my head but I can imagine that might not be all that when you go downhill on a rocky road. (How do you fix your light now to the bike? I would think you could use the same setup by just rotating it a bit)
I still would recommend you to get headband or headlamp. It’s really not a luxury thing to have for setting up camp, fixing your bike or just for cooking a meal in the middle of nowhere on moonless night and the extra weight of headband is negligible. A decent one can be found for around $5 maybe even less. But like I said shop around.
A latern is also nice but way to bulky and not really versatile so I always take some of these with me : film canister They are nice to keep small things dry (like medicine pills, matches etc) and if you can fix em over the head fo a light you get a great diffuser. I always have at least one with a lid and another one I stacked under it. I heated one up with a hair dryer so plastick got soft and then just pushed over the head of my NC MH20. It works like a charm.
Oh now, there won’t be downhill paths or fast woody trails, just travelling. Usually it will be asphalt but sometimes not. Also the asphalt in the balkan area, especially in smaller roads is not of best quality.
Right now I use a sigma quadro x that is only good to allow others to see you. It’s no good for you to see your way in dark places. It also gave up spirit and decides to turn on/off on its own leaving me moving like ninja biker. I haven’t started travelling yet, just planing ahead But I do use my bike as main means of transportation within the city and outskirts.
You have a point about the headlamp. I was thinking to overcome that by using a diffuser to save weight, something like that
The diffuser will work but you still got to fix the light somewhere and make sure it still lights the things you’re working on without you standing in the way of the light. I just use those film canisters cause they’re free and have double use.
I drive in the city and there are a lot of cobble stone roads here in bad shape, never head a problem with my headlamp on my head. But yeah a convoy is much cheaper and I think Simon (from convoy) cells good headbands cheap and thingies to mount the light to you’re bike. So you can go that way. Just fix the light to your bike and when camping put it in the headband. It still doesn’t compare to a good headlight that you can position and operate with one hand but it will be an enormous help.
Before I knew BFL I used to use dirt cheap 3xAAA headlamps, they are crappy and drain NiMH batteries in an hour or so but I still would not have traded them for a $50 light just cause they are so handy.
And for your traveling I don’t think you will be needing lots of throw, I believe the skilhunts have 120m throw. I think that will be more than enough.
One problem I have encountered is when it’s really foggy or the air is filled with light rain and the light from my headlamp just blinded from reflecting on the fog/rain. I think that if I had my light fixed on the bike it might have been less blinding for me.
Ah you use the film canister as a diffuser! Now I get it. Thanks for the tip on fog/rain I’d need to experience that, no way I could imagine it.
Yes 100-120m should be is enough throw. That’s why I was curious about the s2, from what I have read and seen it’s more of a thrower; not dedicated, but a thrower nevertheless. For example, I have a Varta/Rayovac Indestructible that is completely useless for the application, the beam is too focused
The S2+ with narrow TIR has a bigger beam than the reflector versions. This is because the TIR collects more of the light that would be just spill and puts it in the beam. So the beam itself is wider, but the spill directly from the LED is more narrow than a reflector light. There are also wider beam TIRs and elliptical beam TIRs made for biking.
It’s hard to talk about the narrowness of beams without comparing to lights known by both parties, but I measured the beam size of mine to be ~1.2m at 4m distance. The beam is perfect, IMO, for riding quickly on not-so-well maintained asphalt roads. Mine has a FET driver and does 20Kcd on full. I find that about 30-40% of that intensity is bright enough to comfortably ride quickly.
Here is a pic comparing the narrow TIR with XPL HI (left) with the S2 SMO reflector with XPL HI (right).
Ok the TIR one is clearly better but still both look too focused compared to a cheap zooming xml clone I have around
I’ll try to get comparison shots tomorrow, the only place I can do that is the bedroom and the wife will kill me if I wake her up for that :face_with_monocle:
That clone though, fully zoomed out, would give a ~2m diameter from 1.5m distance…
Not sure about S2, but Convoy S2+ is definitely a flood, not a thrower.
As far as lights that take 3xAAA as well as 18650, there is Anker LC40; however, you’ll only get about 250 lumens out of it when using AAA batteries (400 lm when using 18650). It’s got a fairly pronounced center spot, but decent amount of spill as well.
Uhh, no. Not sure about the S2 specifically, but the S2+ is definitely NOT a thrower. It’s a nice smooth floody beam which is great for close-in work, lighting up the walking-path in front of you, etc., but not for looking way down a trail to see what’s 100m out or even 50m out.
The lights I mentioned, and any decent P90 or P90ish light will have a nice hotspot for seeing far out, as well as enough spill to see what’s up close.
My own idea for a custom-built bike light would be to have at least 2 emitters, with TIR lenses, one “highbeam” and one “lowbeam”. A nice floody lowbeam for seeing up-close, and a nice throwy highbeam for distance. I’d rather go for 4 emitters, 2+2, for redundancy and switchable for “city” vs “dark”.
Well, EasyB above has a shot with an S2 creating a 1.2m diameter from 4m. Compared with my cheap zoomer that creates a 2m diameter from 1.5m I’d say it’s more of a thrower than flooder. I’m not sure I’d feel comfortable with that amount of flood. Is s2+ that much different?
The varta/rayovac indestructible on the other hand from 1.5m creates a hotspot of ~22cm and a (barely) visible circle of 1.2m. I definitely would want to use that
It’s a MOP reflector, so there’s no real distinct hotspot to speak of. But it’s definitely floody. Short of an aspheric, it’s the nicest flood-beam I’ve seen in a while.
Well, of course it will be less floody than a zoomie in mule-mode.
Only you can decide if a beam is wide or bright enough for your riding. But you can’t have a beam be both wide and intense unless you increase your total lumen output. For instance, your zoomie in flood mode will probably not be intense enough for fast riding.
I see. I also come across a polish forum with photos from almost the rider’s position. Indeed it looks alright, even too bright at 500lm. I have the S2+ 4c version it in the basket along with the 18350 conversion tube. But I’m still undecided, what if I run out of batteries? It won’t be possible to just buy, I’ll have to find a way to charge :person_facepalming:
Anyway, in the meanwhile what type of mount would you suggest? That should be easier to get out of the way. Velcro, fixed or elastic
The velcro one. I use this kind and it works great for S2 sized lights.
If you really want 3xAAA compatibility there is probably a suitable host available, but it would be a gamble whether it was a quality host, you would almost definitely need to mod it to make it suitable as far as modes and brightness, and the stock reflector would probably be a bit bigger in diameter which really might make the beam too narrow for biking.
Here are a few possibilities that are at least close to the right size.
https://www.fasttech.com/products/1601/10005701/4129505-singfire-sf-345-led-flashlight
https://www.fasttech.com/products/1601/10014338/6014600-1-led-3-mode-1300lm-diving-led-flashlight
https://www.fasttech.com/products/1601/10019443/4078502-samsun-bk31-led-flashlight-gift-set
There are small USB Li ion chargers around that are pretty convenient for travel. Like the Liitokala li-100.
Thanks. I have the liitokala li-202. I like that it also doubles as a power bank.
I saw that SingFire, there’s also an ultrafire that uses this host, it comes without the 3xAAA holster and a Q5. C13 I think is the actual model name but couldn’t find much info about it other than it’s modable
The link is here -> https://www.fasttech.com/product/1282903
I’ll try asking for some info on it there
I think I’ll go for the s2+ AMC7135*4 T6-4C. I need something dependable and cheap and that seems to fill that role but fall short on battery options. For that I’ll also get a UINFIRE B68 that runs on a single AA for those times. Sometime in the future I’ll probably get that nice boruit headlamp but not right now. The total cost is about $6 less than TK737 which isn’t that much of a difference, but I’ll save some weight and bulk in daily transportation and end up with two torches that are more easily modable, at least for a beginner.
Any objections?
I’d like to also order a TIR to try but I know nothing about lenses. What type should I get and what diameter? I’ll order the rest from FT, the prices are very good so ideally I’ll get the lens from there too
I haven’t looked at TIRs from fasttech, but ones around 20mm should fit. Go with the narrow beam variety. I have gotten mine from leddna.com.
These probably should work. You’ll have to remove the white plastic housing it comes with, and sometimes you have to get creative with the centering ring/spacer.
https://m.fasttech.com/products/1606/10007055/1574902-21-2-12-6mm-pmma-optical-lens-for-cree-xm-l-t5-t6
S2+ is a great all-around light. Note that if you get one with a domed LED, rather than an XPL HI, it will have less throw and a wider beam. I personally would go with more current than the 4x7135, but 1.4A is probably enough for most uses.
