Fasttech has the âraptor clawâ (PD) 7135.
MEL7135PG MICRONE(Nanjing Micro One Elec) | C80214 - LCSC Electronics
MEL7135PG MICRONE(Nanjing Micro One Elec) US$0.1292 - SOT-89 LED Drivers ROHS datasheet, price, inventory C80214
Not anymore!
I emailed fasttech about it, requesting to buy that one specifically (after I received the other from them) and they replied:
Since then Iâve been placing smaller test orders from various places. My first order of ten from fasttech was RC but the second was CS
Now thatâs some dedication !
I always admire your electronics skills man, good job !
Nice testing tterev3. :+1:
Interesting.
Thanks for the test! And your nicknames are great! They stuck with me right away. So when you replied with RC and CS, I knew exactly what you were talking about without have to go back and reference the abbreviations. Nice work!
Strange⊠When was this?
And did you look for 350mA or 380mA?
Recently got 100 of these 350mA:
https://www.fasttech.com/product/1124300
Look here for pics, also about sanding / filing down:
I did a driver mod. FET+1 modded to 19+1, totalling 20x 7135. Hereâs the pics: [image] Iâm just not a fan of direct drive, so the FET had to go. [image] Original plan was 12x or 14x 7135 for an Astrolux S3, but: [image] Inside a copper sheet 16mm circle 19 of them will fit. This will fit snugly in most pills for decent cooling (with some thermal goo). [image] Positioned them with grey epoxy before soldering them to the copper enclosure. [image] Added solder paste for âŠ
I got these:
(some are from an other batch)
I ordered 100 packs from them on 1/31 and 2/7, both were Crappy Sailboats. All 350mA
Hmmm⊠i ordered them on January the 7thâŠ
I donât want Crappy Sailboats eitherâŠ
Your pcb/ufo looks like it crash landed into your digital calipers trailing flaming led wires.
âŠso i search for â7135â on AliExpress, and most of the pictures show the Raptor Claw chipsâŠ
Iâll bet sanding the bottom layer would drop the top chip enough for bent pins to actually make contact making the solder connection much easier on stacked set ups.
âŠbut it seems âoriginal Addtekâ have the best reputation, they cost more tooâŠ
So what should i be looking for when i run out of Raptor Claws?
Easiest way to stack (for me) is removing centre pin and super-glueing one (with pins bent down) on top of another.
Then you donât have to worry about accidentally bridging pins and holding the 7135 in place.
Yes, thereâs still that tiny gap, but thatâs not a big problem.
It is for me. Having them touch so the solder clings easily to both would take care it. Iâm glad you do it well though.
I just received my last order of 100pcs of these regulators and i got âRaptor Clawsâ. I ordered these April 8th from Fasttech. So it looks like itâs a little lottery for what you get.
Thanks for the update, iâll put them back on my wishlist.
I found manufacturer of Crappy Sailbot. Itâs Chinese company QX Micro Devices Co., LTD
Here is product page:
http://www.qxmd.com.cn/en/?product/QX7135.html
Qrappy XailboatâŠ
If you want to buy original âraptor Clawâ
Nanjing Micro One produces them
I got 1000 ordered on Aliexpress and it came as reel
found also this shop who sells them whith guranteed no fakes
they also produce known Lithium linear charger ships
