Certification covers the knowledge you need dive safely. Breathing at depth causes nitrogen (70% of each breath) to dissolve into the blood and accumulate in soft tissues and repetitive diving increases accumulation. Coming to the surface too rapidly or getting on a plane too soon can literally make you fizz and die. Deep dives can cause nitrogen narcosis(a sort of drinker disorientation). Knowing how to monitor your nitrogen(or O2 if using Nitrox) along with hand signals covering different situations, proper use of boyancy control and breathing, what to do in an emergency, these all take some practice to become second nature and certification is a means of verifying you have it down pat. Not to mention you need to show proof to get tanks filled. Check your weight belt and turn on your air. Certification doesn’t expire but if you haven’t done it for awhile then a refresher is a good idea. New technology and changes in boat diving practices can take getting used to.
As long as current is past through the body it wouldn’t help. Current has to be isolated from all external parts. At 8.4 volts 3 amps you could probable see gas bubbles forming if done in still water like a fish tank. Simply having both contacts at the head and none of this would happen.
I doubt that’s because of electrical current.
The shell is (usually) negative and there’s no positive outside, so there’s no current through the water surrounding the body.
Let me rephrase:
There is current through the battery tube from tail to head.
But since the battery tube has very very low electrical resistance, there’s hardly any voltage between tail and head, so i expect electrolyses is negligible or just not happening.
The picture shows problems on the edges.
Probably damaged anodization, and so the seawater just has a go with the aluminium.
The result is porous salts which absorb seawater so that the process continues on dry land.
Those pics are from a 2012 thread. The damage you see is from galvanic corrosion and electrolysis when this light is submerged in salt water. Basically it forms a cathode / anode and the salt water is the electrolytic solution. It only happens when this light is turned OFF (IIRC) though because the electrical circuit when turned on becomes the current path of least resistance. The condition is worsened for spots where the anodize is scratched off or etched off. Thread here… skip ahead to page 5-7. IIRC a couple different members were complaining about the same thing.
Good read, and answers some questions I had about all this.
Specifically, even with a decent tailcap switch, if it’s tightly connected to the body, the only breakpoint is between the internal switch and the (-) end of the cell. The whoooooole head+body+tailcap should be one long electrically-conductive piece, all at 0 potential. So like a shielded cable, the entire length would be one long 0.
And unless you turn your flashlight into an electron-gun, it’s only 1 electrode in a salt-bath, and no fizzing should occur.
That’s why, a design like this one, no switch in the tailcap, screwed on tightly, no reason to twist/untwist anything, and a magnetic slider, nothing should make a 2nd connection/electrode. (Think of way bigger version of an Astrolux A01 1-piece body, only no twist-head, but one solid piece, internals (incl. battery) accessible only through the front bezel and lens, and an internal magnetic switch.)
That’s why, in the shown pix, what’s fizzing off of what. If it’s a 2-electrode system bathed in saltwater, 1 set of bubbles should be H2 and the other set should be O2.
By figuring out which is which, you can narrow down where’s the break in continuity, and see what can be done to fix it.
Point being, in a good solid conductor, there should be no fizzing of any kind no matter how much current is going through it, not unless the voltage drop is more than 1.23V.
There’s also the Ultrafire UF-S11 which looks like it might be a slightly more distant relative as it has similar proportions and a magnetic switch. Although it seems to consistently claim 3 modes instead of being infinitely variable: http://www.gearbest.com/led-flashlights/pp_576215.html
Back to the DV-S9. Does it take protected batteries and what is the beam spread like? Similar to the Starry Light DXM? How hot does it get if left along on maximum brightness?
Yeah, I got a protected 26650 that fits just fine. Big honkin’ springs on each end, so could probably take a ¼” spacer, too, and still fit.
Beam’s nice, pretty well-defined hotspot, decent spill, maybe the size of an XM-L in a C8. Wider than an XP-L HI C8, narrower than my (stock) VG10.
Bulb above my washing machine went out, had the DV-S9 tailstanding on full, using ceiling-bounce for light. Had it going about 10min straight, comfortably warm, nowhere near hot. It’s got a good amount of bulk to it.
Aha, it has a tailcap that acts as a twisty switch. I didn’t know that.
So, when it’s turned ‘OFF’ there’s the battery voltage between tailcap and body, and then electrolyses will happen.
I see i forgot to ask how the PWM is.
I assume they use PWM, and i know the big XHP70 diving lights with stepless slider is quite noisy (but not visible).
So how’s this one doing?
I like the concept.
Just received one of these. Looks decent to visual inspection and has survived a simple dunk+burn test. It has a low voltage cut-off and the light goes out suddenly and entirely with the battery showing ~3.2v after. It will not restart, even on low.
Light is a diffused focus similar in intensity and spread to my regular canister (4 LED, 2S2P 18650) dive light. Light intensity seems to stay decent down to cut-off.
I LIKE that the switch mechanism seems to be internal with just an external slider. First slider light I’ve had. I like it so far.
A bunch of the cheap dive lights with Hall sensors have external magnetic mechanisms with springs/magnets/occasionally ball bearings that are cheap steel and rust to garbage with saltwater use. They would be OK for shore use but are completely unsuitable for actual diving. Saltwater is death on them after awhile.
The 3xO-rings are good and seem to seal well. Hopefully the lens sealing mechanism is decent. It appears to be a single silicone O-ring which is typical of this price point.
I will be taking it for an empty test dive. If it survives I’ll put a battery in it and do a dive test. Then we’ll see if it can pass as a dive light.
