It’s probably too much trouble to make press fit sinks, unless people have a way of sizing, and fitting the minor bore, and then pressing it in, with either with a hydraulic/manual press, C-clamp, Vise or bash it in with a rubber/leather mallet? Easier to make the threaded sink maybe? I have made a few, press fit, about 10 of them, out of copper and aluminum years ago, and copper was kind of over kill really. I press fit them into the minor bore and shouldered out on the ledge. I also made them 1mm taller then the stock shelf so I could put the reflector on the board. The 32mm Noctigon is really the only way to go for lead clearance! And you still have to clear the reflector bottom a bit, if you don’t use a centering ring if I remember correctly. I did make a print of the sink, I just don’t know where it is any more???
I’ll take a look around and see if I can’t find it?
Until connection is not electrical, there is no need in big pressure between connecting parts. With 0.1mms of thermal grease it will transfer heat same way as with high pressure press fit. I was not going to make press fit pill, it will have threads, Im just looking for other ways to improve heat transfert.
32mm boards does not look as best decision. I know that courui reflector is very wide from bottom and bigger board means less problems with wiring. But they are available in xp size only, also 32mm is to big size for straight wire holes drilling.
Guys, I cant make new parts with so few communication. I cant have all hosts in all configs, make several build a day like some members, so I dont know all reefs. Im try avoid spamming lots of extra letters here, but if I ask smth this means that I really need more information that I have.
Once again.
If here any need in copper pills for Courui D01?
Should they be extended height and as heavy as it is possible?
What driver and pcb would you like to use with?
X6 triple conv. is not very user-friendly. XP32 board dont fit inside head, and you have to sand it. I wonder how much users did this work with leds soldered. I have though that soldering leds at last is more simple way, and even made several spacers with soldered and machined pcbs, but fact that they still unsold means that I understand users preferences not so good.
Due this reasons, I have a poll about C8 triple set. Most or even all spacers will be made from Al (Cu version weights more than 100gr, if you still want it please let me know, I will think about limited batch), XP32 board will sit perfectly centered without any sanding, extra liner from Al with gitd o-ring will hold stock glass lens and center Cute-3 optics. After you know a little about this set, please choose one from next options.
“I would buy C8 triple set…”
bare set (spacer, liner, o-ring)
only if you will have cute-3 optics to ship them together
only if you will have XP32 bare boards to ship them together
only if you will have XP32 with leds to ship them together
only if you will provide full set with leds and optics
Not interested now , as i still have 2 or 3 full kits , but i’m just saying my preference .
It takes me some minutes to make the xp32 fit in the host , using hand tools .
Maybe you are right.
I still cant forget “custom” size P60 drop-ins.
Someone have asked me to make various of them, when they were ready most buyers didnt have host for it :zipper_mouth_face: , others have take sizes that could never fit (one half took 22.0 for use in 24mm 502b , other half took 22.8 and sanded it dozen hours to put inside their 22.0 Surefire :person_facepalming: )
Making several Courui D01 pills have paused because smallest amount of 45mm copper rod I can get will be enought to make hundred of them.
Any ideas how to use this rod? SRK clones shelfs?
I received a copper spacer for Carclo triple Convoy S2+. It is very well made and I installed with a Kaidomain triple 219C with optics and It works, but Kaidomain triple board is very thin and it is not flat and it doesn’t make full contact with the spacer.
I also received a Carclo optic and Noctigon triple board from kiriba-ru that seems very good. It’s really flat and It will make very good contact with the spacer. I will reflow leds and try it when I have some more time.
Thank you very much kiriba-ru for your products, your help and the advice to build my first triple.
I am already thinking about building my next triple (really a quad Convoy M2) and I am sure that I will buy the spacer from kiriba-ru
This parts are ready. If you have reserved some of them, I will contact you today or tomorrow.
C8 aluminium kits are in work. Until I havent used all 35mm aluminium rod for C8 kits you can say if you want to have X6, X7 or F13 spacers made from aluminium.
Copper rod for Courui pills is ordered. Please give me suggest where else it (OD 45mm) can be used.
