Not intended to be a lighthouse. The 9050 219b’s are so wonderful, these must be amazing!
Hope so, i ordered 5 of them.
But a triple on 9x 7135 (3.15 Amperes) will still do a little over 1000 Lumen (before the optics).
thanks Texas
Seriously, since we don’t perceive light intensity linearly anyway I care less about max output. Tint and high CRI is what please our brains via our eyes every second we use our lights…
thanks Texas
Thanks for the test TA! So 700lm @ 4 amps is the max. Not bad at all, really…
Nice work TA. Thanks. :+1:
I just put 7 of the 219B 9080 LED’s into a SRK with the stock non-DTP mcpcb.
I can legitimately say that I am blown away by the tint of these! I have seen quite a few LED’s and this by FAR blows them all away.
These are the whitest, purest, most gorgeous LED’s I have ever seen! Keep in mind that over half of my lights are 90+ CRI.
Even compared to all my 219B 9050’s I have, these have no noticeable tint shift either green or red. Just pure amazing white. All my other 219b’s have a slight shift to either the green or rosy side.
I was worried when I saw these outside of a reflector when on the bench that they would be too rosy but seems it was just an effect of having tested the 319A right before it and that screwing my frame of reference.
Now I will see what it looks like tonight to get a better idea but at this point I am in love, I just wish that they had higher output.
A 219C 9080 would be perfect, if only they could put the Phosphor from the 219B 9080 on the 219C die it would be the perfect LED for all your CRI needs. Hmmm, maybe they would be open to a special run of these clemence?
Only downside is the low output but in triples and quads it is perfect. An M34 or M43 would be amazing with these.
Now on the down side, DO NOT use these with non-DTP mcpcb’s. I killed 3 of the 7 LED’s I installed in the SRK. I am not sure if it is a mismatch in the Vf or just not being able to get rid of the heat. Either way 4 are nearly dead and released magic smoke. I now have to run the light with only 1 laptop pull cell installed to limit current.
Later I might indeed build a M34 with these.
I hope you post some photos of your hand with various LEDs so I can see what you are talking about
here are a couple of examples of what I mean:
[QUOTE=twistedraven;5063099]
[/QUOTE]
I tried to get some good beamshots at one point but gave up after a few days of messing around turned up results that were far too inconsistent and almost useless.
The overall beam is hard enough to get but the tint is another matter entirely. I could never get something that showed the tint accurately without needing me to edit it by eye to get it to look right. In which case it was not accurate but simply as good as my editing could get it.
Too much variance for me so I elected to skip beamshots all together. I tend to get a bit carried away with details like this lol.
I agree it is difficult to get photos of a single beam, that matches what our eyes see, and like you I have zero interest in massaging an image.
Ive come up with some techniques that work with my iPhone, I do not edit or adjust anything.
so if you care to venture into some experiments here are a couple of suggestions
1. Beamshots of 3 lights side by side shooting at a folded piece of printer paper
very useful for comparing beams. one of the 3 lights should be cooler than the others, it fools the phone into setting itself to that “white balance”, so you can tell relative tint of the other two lights
examples:
2 beams does not work well: (light on left is 3000k XPG, light on right is N219b 4000k)
3 beams seems to be the sweet spot (same nichia, but in the middle now, light on right is an N219b in an Astrolux M03 that I guesstimate is over 5000k… Im just using it pull the white balance so the other two lights tints look more like what I see with my eyes)
2. Handshots
useful in comparing CRI
still just a cellphone pic, no white balance adjustments of any kind
this is a N219c 4000k (Manker Lad)
this is the N219b 4500k in my Copper Worm
this is the N219b in my Astrolux M03
fwiw, here is my Astrolux M01, M02, M03, all N219b, you can see a wide variation
you can see the 219c is obviously more yellow tinted than the 219b in the above hand shots
Im very interested in seeing your comparison beams of the 219c and 219b LEDs that you have
If I ever could get the $$ for a spectrometer, I’d totally be posting nice spectral charts with CRI, TM-30, etc…
Anyone want to front me a few thousand?
That’s a gorgeous LED. I would like to go put that in a very well diffused host for some work.
Check out the GB thread for these, the spectral results were posted earlier today.
I just noticed that both 219B and 219C exceed the rated lumen output
- 219C 9050 specced 240lm 700mA; Tex's test: ~255lm
700mA
- 219B 9080 specced 220lm
700mA; Tex's test: ~230lm
700mA
It’s a good thing
Yes, I think the D240 rated emitters are actually D260, the spec sheet says they exist.
The D220 are technically within the margin of error for a D220 IIRC but also keep in mind my sphere is not perfect, just as good as I can get it.
Hmm, yes, don’t trust our BLF calibrations. The limited chance I had sofar to compare different people’s calibrations, while I expected maybe 4 or 5, it was more like 20 to 25. A humbling find!!
Those were mentioned before but it was guesstimated they would be hundreds of dollars at the cheapest.
Let me check it. If it’s not that expensive, I might buy it. So you guys can passaround it to calibrate each sphere
I have been drooling over those when they came out last year
