This parts are ready. If you have reserved some of them, I will contact you today or tomorrow.
C8 aluminium kits are in work. Until I havent used all 35mm aluminium rod for C8 kits you can say if you want to have X6, X7 or F13 spacers made from aluminium.
Copper rod for Courui pills is ordered. Please give me suggest where else it (OD 45mm) can be used.
Hi, I’m interested in 2 shortened spacer for convoy s3 , mine is without pill, and 2 carclo optics also for convoy s3, I’m from the Philippines. How much will it cost? Pm me. Thank you
Well, Im not 100% sure.
Need to change smth because Im under zero for most rare parts and near zero for some difficult parts. I dont want to save situation when profit from one position compensates losses from other one. Without price increase Ill need to discontinue producing several items.
I think you are one from those who can fit any part to any build and they anyway will fit perfectly. In fact I have made some mistakes and this samples have little wrong dimentions.
Your photos are great as usual.
I will ask those who are interested in VG-10 quad to open your hosts and specify which version do you have:
Old version from one of chinese websites. Head internal surfaces are complete anodized (no shiny machined surfaces), o-ring between reflector and stock glass lens. Bezel is flat from bottom.
2)
Medium version from amazon deals. Head is machined inside, o-ring around glass lens (between bezel and reflector). Bezel have rim so glass enters inside bezel.
3)
Epic fail version from thorfire GB. Extra aluminium disc and LB pcb under main pcb.
