Review - KD Qualilite D81 C8 XPL-HI V2 4500k 18650/CR123 Flashlight
Thank you.
Nice review.
Hope you guys will enjoy it.
Nice review, good to see it compared to all those close competitors.
What I see as the main advantage over other C8’s is the reflector. Can you compare the beam directly to the other C8’s ? Is the hotspot tighter than average, is the throw better? If that is so, this light is worth the higher than average price, and the extra weight (that I generally see as a disadvantage).
Very nice review! Thanks
Thanks for your feedback. Next chance I get I’ll compare beam shots and provide some comments.
Thanks for the review Rolz. What was the diameter of the driver?
Thanks for this comprehensive review!
I’ve not removed the driver board, but just measured the diameter and it’s just under 20mm
Nice and very detailed review thanks, looks like a KD version of the XinTD C8.
I have two older KD light C8’s and have been pleased with the value of them. This one seems like they are stepping it up a bit with the Voltage range and new packaging . Good for them!
Thanks
I like it when a light incorporates the reflector (a chunk of aluminium) in the thermal path.
Let’s hope the ‘drop in’ is not glued together though…
…hmm… either way, it’s not cheap…
I agree totally. The driver pill is connected directly to the heavy thick reflector which results in improved heatsinking. The two combined components screw into the head of the flashlight again ensuring improved thermal transfer between the driver and the flashlight host. The added weight should assist as there is more aluminium to assisist wth heat transfer.
Beam Shots added to post #2 for comparison against other similar flashlights. I’ll try a scratch test too to see how strong the anodisation is on the D81
10x for the review
As for the BLFers, think about this one:
A well tunned BLF C8( dded W2/V6\ even dded xml2), dd driver , AR glass, springs bp est) would give you 1800-2k lumens and 150k candelas or 1300-1350 lumens/195k candelas using a good old s3/s4 emitter
Thank you Rolz
It makes me know more about the beam profile among different C8.
There will be more accessories for the D81 will be released asap.
Thank you
Rolz, very nice review. I enjoyed your analysis. One thing I noticed though. I believe you mixed up your Low and Medium photos for the 60m tree beam shot. The “Low” photo looks brighter with more spill than the “Medium” photo. Otherwise, a great review, thanks!
Thanks for the feedback. I’ve corrected the error. Somehow I missed it but fixed now. Thanks :slight_smile:
Thanks for the review!
So the reflector threaded screws into the pill in similar fashion to the Xintd C8?
Yes it does although I dont have a Xintf D8. As mentioned in the review the reflector is screwed in very tightly to the pill, so much so that I initially thought it was glued. I’ve not tried to remove with tools but others have managed to do so.
Scratch test to test out the HAIII anodization
Firstly a flourite rock. The head section was scratched with the rock
The resultant marks were simply removed with wiping
Next a harder rock, this time a Garnet. This has a MOH rating of around 7, diamond is 10.
The marks made on the head were not as noticable as those form the flourite.
After some wiping almost all of the marks have been removed. You can barely see the scratches on the head section below.
Overall an excellent result for the anodization. It’s of a high standard.
Thank you Rolz for the hardness testing :+1:
