Those āmini COBsā look interesting.
Those E21A are very interesting. Imagine a 20mm triple under Carclo optics. Unfortunately this would need a special MCPCB. For good heat transfer a special AlN Board would be nice, or a direct cathode MCPCB combined with a special driver that switches battery+, so that the board wouldnāt have to be isolated.
3x E21A and Carclo 10511 should make a very nice beam, smooth but with some throw.
That beeing said, I would expect the NCSL219B-V1 R9080 to be quite similar concerning beam characteristics under those 105xx Carclos, but much easier to implement.
I just built up a Convoy S2 using one of the sm503 9050 219C. Looks pretty nice to my eyes, but itās hard for me to tell as Iām red/green colorblind. I wouldnāt mess with high CRI for myself, this is for a friend who will enjoy the CRI. It does appear to be a wonderfully neutral white though.
Thx for the AlN idea Chouster, will think about it.
Carclo 10511 designed favourably towards Cree XP-G in the first place (0,73mm focal plane). The rest of the emitters will need some adjustment in opticsās peg height. E21A paired with 10511 isnāt as tight as it potentially could. The problem lies in much lower focal plane in E21A 0,27 - 0,3mm +/- 0,05mm (height vary with different CRI). Compare this to 0,4mm in NVSx219C/NCSx219B-V1/NVSx219B-V1.
We all know that domeless emitter with the same die shape should have much tighter beam. But from this beamshots, the difference is only marginal. Approx. 1 degree tighter compared to 219C (the same die as E21A).
Cree XP-L HI usually have ~20% tighter beam compared to XP-L HD in any TIR optics.
NVSW219B
NVSWE21A
NVSW219C
Just my Rp 2
Just for fun....
Hi Clemence,
I appreciate your Rp 2 very much.
I read your thoughts about AlN in your VirEnce CDTP MCPCB thread, so you already mentioned it.
The beamshots and FWHM-graphs you posted are from Carclo, right?
I think their numbers are very much like I would have expected, with one big exceptionā¦
ā¦ the NVSL219B. I really think they mixed something up there. In fact, I have the feeling they tested a NCSL219Bā¦
All numbers would make perfect sense to me than.
EDIT: I just wrote them an e-mail asking for clarification.
Yes, I got them pics from Carcloās website.
I donāt think they mixed it with NCSL, itās what it is.
Beam angle order in 10511: 219B - E17A - E21A - 219C - 319A (weird huh?)
If we follow common sense based on die area geometries it supposed to be like this: E17A - E21A - 219B - 219C - 319A
So far, the only explanation logcal to me is in their focal plane (die height) differences. Anything lower than ~ 0,6mm - 0,73mm (XPG) will off focus. 219B, 219C, and 319A are all have 0,4mm focal plane. Thatās why their sequence looks OK.
Hi,
please take a look at the Cd/lm numbers of the 10193 optic.
- NVSW 319A Cd/lm: 9.5
- NVSW 219C Cd/lm: 12.5
- NVSW E21A Cd/lm: 20.66
- NVSL 219B Cd/lm: 23.1 (NCSL219B!?)
- NCSW E17A Cd/lm: 34
I really do think they mixed that up.
I donāt know. But that looks OK to me since 219B has smaller die than 219C. E21A and E17A could be close to 30 and 40 cd/lm if the height adjusted.
Also, why would the NVSL219B have so much higher Cd/lm values than the NVSL219C, when they have about the same die-height and die-size?
We were talking about 10511. And in that particular optics the cd/lm number looks normal.
The latter optics you posted indeed has too much difference for such a slight difference in die area (219C vs. 219B)
Yup, thatās right. Sorry, I was talking about the 10511 indeed. But when I looked at the numbers from other optics thatās when I realized that something isnāt right about those numbers. Not that clear when you just look at the 10511ās numbers.
Swapped xpg3 90cri out for nichia 219C sm503 in a triple x6 and it looks great with no green. As noted by TA, maybe slight blue if you are sensitive to CW but in general a very pure white.
The 4000k is just slightly warmer than I like and the 5000k slightly cooler. Iām going to try 2 of each when I rebuild my s41 and see how that turns out.
Thanks Illuminos for the report. I just want to know who else got the green other than Mustsimon.
How is it compared to XPG3 90CRI? I mean real world colour reproduction?
Got my LEDs Texas! Thank you very much!
Great!
In response to the request for sm503 impressions, I gave mine before, but Iāll add some white wall comparisons. I do like these emitters, but I thought I was going to love them. Iām not sure if itās just that nothing can compare to the 219B R9080, which is a warm fuzzy feeling turned into photons or if theyāre actually a little off. The 319A looks maybe a hair cooler, but no green. I think itās even a tiny bit rosy, but itās hard to be sure since itās behind an AR lens.
So hereās a 319A sm505 on the left and a 219C sm503 on the right, taken with my Nexus 5 with the white balance set to 6500K. Note that I donāt think the numbers indicated for the white balance correspond to reality - thatās just the setting that seems to produce images that match what my eyes see.
Hereās the 219C sm503 next to the 219B sw45k with the same white balance setting:
Chouster got my package !
Thanks for good delivery and all the work you put in.
Danke schƶn !
OMD! I thought you were jokingā¦.But when I looked at your pictures it is indeed!
compared to 319A sm505, the 219C sm503 looks so much better BUTā¦.when compared to 219B sw45k it turns ugly! :confounded:
Itās not only our eyes, even your Nexus agrees
Maukka is definitely needed now. I hope his package will arrive soon.
