I’m down for a couple of those s2+ triple’s also will keep an eye on this thread
This parts are ready. If you have reserved some of them, I will contact you today or tomorrow.
C8 aluminium kits are in work. Until I havent used all 35mm aluminium rod for C8 kits you can say if you want to have X6, X7 or F13 spacers made from aluminium.
Copper rod for Courui pills is ordered. Please give me suggest where else it (OD 45mm) can be used.
Interesting stuff for C8.
What kind of kit?
Wondering if you make copper kit too.
Dont think so.
I still have one sample from Cu, it have little wrong dimentions, if you are ready to make little hand work you can contact me PM.
Hi, I’m interested in 2 shortened spacer for convoy s3 , mine is without pill, and 2 carclo optics also for convoy s3, I’m from the Philippines. How much will it cost? Pm me. Thank you
You mean higher?
So it’s get pricey on April?
Well, Im not 100% sure.
Need to change smth because Im under zero for most rare parts and near zero for some difficult parts. I dont want to save situation when profit from one position compensates losses from other one. Without price increase Ill need to discontinue producing several items.
Hi,
spacer for the Convoy C8 arrived and fits perfect. I put an 34mm x 1.5mm O-ring on top. The light is pretty heavy now
Regards
Kenjii
I think you are one from those who can fit any part to any build and they anyway will fit perfectly. In fact I have made some mistakes and this samples have little wrong dimentions.
Your photos are great as usual.
Everything fits … somehow
This is a great looking C8 Kenjii. What optics and MCPCB did you use for this build?
As you can see pcb and optics are same to X6 triple (xp32+Cute-3).
Now I see it, thanks. Not much experience with TIR optics from my side, sorry.
I just finished my new build using that copper rod that you sent me. Great stuff, thanks again Kiriba .
Candy Apple Red C8 Triple Nichia 4500K’s
Received S2+ copper pill and carclo optic. Very well packed and fast shipping. Thank you.
I will ask those who are interested in VG-10 quad to open your hosts and specify which version do you have:
Old version from one of chinese websites. Head internal surfaces are complete anodized (no shiny machined surfaces), o-ring between reflector and stock glass lens. Bezel is flat from bottom.
2)
Medium version from amazon deals. Head is machined inside, o-ring around glass lens (between bezel and reflector). Bezel have rim so glass enters inside bezel.
3)
Epic fail version from thorfire GB. Extra aluminium disc and LB pcb under main pcb.
- old version from one of chinese websites. Head internal surfaces are complete anodized (no shiny machined surfaces), o-ring between reflector and stock glass lens. Bezel is flat from bottom.
- medium version from amazon deals. Head is machined inside, o-ring around glass lens (between bezel and reflector). Bezel have rim so glass enters inside bezel.
- @#$% version from thorfire GB. Extra aluminium disc or pcb under main pcb.
Lol, I have # 2 and @#$% 3. Are you makings kits for all 3?
№1 and №2 have same spacers but different liners.
№3 fits spacer from M2 and (I hope) one from two first liners.
I think I will start with №1 just because it will be tested sooner than others.
Got some spacers last week. Well packed and fast shipping, everything fits perfect.
Thanks!
Big size rod in stock, dont miss oppotunity to order custom spacer for SRK clone.
