Yes please
That anti vandal type switch is sexy as hell.
No XHP35 Hi ?
or change XPL Hi to XHP35 Hi.
I think that XHP50.2 would be a good led for a new Maxtoch light
i like the extender idea on the XP-L LEDs...
more runtime and 10% higher power
how big are the chances the driver is the same in all M12?
(maybe different sense resistors)
since it works 1 or 2S for the 3V LEDs and 2S for 6V
swapping to XHP50.2 ina DTP could be easy
Well….looks good yet i have a feeling for downgrade especialy about the Shooter…kinda wierd Maxtouch solution
If only M12 had a tail switch too…
Could you post the lumens for each mode on the lights above and the run times for each. Thank you. And great new line up. I had to miss the 2x group buy last time I was in it but lost my job days before the code went active. Maybe I can request one of these for my birthday in a few months coming up
Yes Please …
I`m interested.
Greets
Carsten
if you go to the shop (links arein the pictures) or to the manufacturer you will find that data.
Maxtoch does not tell a runtime in Turbo - maybe due to a stepdown?
could mean they are serious about runtime in the other Levels...
XHP70
XP-L HD (1S)
XP-L HI (1S)
Shooter 2X
Like the look of the XP-L HI, still looking for a really throwy light and this could be a possibility
Okay, I’ll ask the dumb question. How does adding a 2nd 26650 and the extension tube to the Mission M12 XP-L HD only increase the battery life by 50? It should double it (ie: increase by 100). Of course the runtime data in the chart shows it shortens the life. :person_facepalming:
Will any of these by offered in Neutral?
M12 XP-L HI looks like quite an impressive compact thrower!
Increased output with a second cell
Codes please
very strange the XPL ones with 2x26650 and the XHP 70 only 2x18650
Mission M12 is 2*26650 Xhp70.
That first flashlight
Where is the XHP35 HI version of Shooter?
Codes please
Codes please, mission 12 xp-l hi
