Thanks TA,
I confirmed the Nichias arrived in Florida, a couple more months and I will be back there.
Our appreciation for a job well done, mission accomplished.
Thanks Texas Ace for the quick delivery of my Nichia leds & all the good information on BLF.
I ordered 2 Jaxman E2L hosts to try making triples. I have just (2) 219Bs so considering a mix of 219Bs with a 219C in the Jaxman. New to modding & soaking up any info you or others post.
As Clemence posted above, unfortunately, the NCSL219B-V1 9080 is already cancelled because Nichia has no stock of them.
There will be a new group buy of 3xNVSL219B-V1 9080 but I have not heard of sw40 before.
Hmm, I feel bad I smashed it…
I also got some 3500K (sm355) Ra8000 319A for you here. Delivered much too late earlier. The 3 steps 319A is surprisingly 30% more expensive even it’s only Ra8000
My stash of leds will get to a next level once again.
I may not even bother building them in lights anymore, just keep them hidden in a small box and just look at them every now and then. Nobody will know!
I use most of my surplus LEDs to lights up the garden, the streets close to my house, even the sewer in my front yard. Still waiting for Sedstar’s package for the 4500K XPGs.
Just got chouster’s package in yesterday, so no. And I feel that Texas Ace has has already shown what the 319 can do, so there are no leds atm that I’m planning an output test on.
We’ll try to be better next time. No confusing reservations, long wait time, etc….
Hopefully we can get you less than 7 days delivery service after whenever you paid the order……worldwide (or at least in USA, Asia, and Europe).
I will try to test all the LED to Maukka first for less guessing and post purchase disappointments (it feels bad on my ends you know ).
Still trying to get cheaper pricing by collaborating with some big manufacturers here….
And to make everything much simpler, only one order page/front page for all areas.
219B and 219C were measured at 700 mA, 144 at 1400 mA.
I have tabulated the results using both a diffuser (Convoy) and a reflector (Reylight Pineapple one for the 219B/C and Nitecore TM03 one for the 144)
All the tints from the hotspot with a reflector:
219B/C from the hotspot and midway through spill (very small tint shift):
144 from the hotspot and midway through spill (clearly a larger shift):
Superbly neutral tints from all the emitters. The 219B sw45k R9080 is clearly more magenta but in real life it’s not bad, makes for very vivid colors (high TM-30-15 Rg index). Highest ever CRI I’ve measured from the hotspot of an led: CRI (Ra) 97 and R9 97.
The 144 are also very consistently amazing. Just pure white goodness. Even though the color temp shift is higher than on the single die emitters, the tint stays at the black body radiator line. Diffused they are absolutely perfect. With a reflector I measured significantly cooler color temps (about +700 kelvin) from the hotspot, but that doesn’t matter if you know what you’re getting.
I haven’t put any of these to a flashlight yet so cannot comment on the real life applications, but so far I’m very impressed.
Thanks to clemence and chouster for sending these!
