[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
1608 posts / 0 new
djozz
djozz's picture
Last seen: 3 min 2 sec ago
clemence wrote:
djozz wrote:
My stash of leds will get to a next level once again Big Smile
I use most of my surplus LEDs to lights up the garden, the streets close to my house, even the sewer in my front yard. Still waiting for Sedstar’s package for the 4500K XPGs.
Have you tested any of the LEDs?
Just got chouster’s package in yesterday, so no. And I feel that Texas Ace has has already shown what the 319 can do, so there are no leds atm that I’m planning an output test on.
clemence
clemence's picture
Last seen: 12 hours 54 min ago
Yes, his test was great Thumbs Up . He did a great job.
But, I will need to test several special PCBs later. Can you help me?
Gunga
Gunga's picture
Last seen: 1 hour 36 min ago
Ouch. I’ll need to get sw40.
Geez. I’ve never chased new bins around before these groups buys.
djozz
djozz's picture
sure!
clemence
clemence's picture
We’ll try to be better next time. No confusing reservations, long wait time, etc….
Hopefully we can get you less than 7 days delivery service after whenever you paid the order……worldwide (or at least in USA, Asia, and Europe).
I will try to test all the LED to Maukka first for less guessing and post purchase disappointments (it feels bad on my ends you know Sad ).
Still trying to get cheaper pricing by collaborating with some big manufacturers here….
And to make everything much simpler, only one order page/front page for all areas.
Cheers,
Clemence
emarkd
emarkd's picture
Last seen: 1 week 8 hours ago
Yup, you made it easy for me this time — in for sw40 9080s… Smile
maukka
maukka's picture
Last seen: 3 hours 24 min ago
Here’s the data for the following emitters (links to a screenshot with lots of CRI data measured from the hotspot):
NVSL219B-V1 sw45k
NVSL219CT sm273
NVSL219CT sm303
NVSL219CT sm353
NVSL219CT sm403
NVSW219CT sm503
NVSW219CT sm573
NV4L144AME sm453
NV4L144AME sm503
NV4L144AME sm573
219B and 219C were measured at 700 mA, 144 at 1400 mA.
I have tabulated the results using both a diffuser (Convoy) and a reflector (Reylight Pineapple one for the 219B/C and Nitecore TM03 one for the 144)
All the tints from the hotspot with a reflector:
219B/C from the hotspot and midway through spill (very small tint shift):
144 from the hotspot and midway through spill (clearly a larger shift):
Superbly neutral tints from all the emitters. The 219B sw45k R9080 is clearly more magenta but in real life it’s not bad, makes for very vivid colors (high TM-30-15 Rg index). Highest ever CRI I’ve measured from the hotspot of an led: CRI 97 and R9 97.
The 144 are also very consistently amazing. Just pure white goodness. Even though the color temp shift is higher than on the single die emitters, the tint stays at the black body radiator line. Diffused they are absolutely perfect. With a reflector I measured significantly cooler color temps (about +700 kelvin) from the hotspot, but that doesn’t matter if you know what you’re getting.
I haven’t put any of these to a flashlight yet so cannot comment on the real life applications, but so far I’m very impressed.
Thanks to clemence and chouster for sending these!
tuelleric
Great results, maukka! Thanks a lot for your measurements, very helpful!
RollerBoySE
RollerBoySE's picture
Last seen: 1 hour 20 min ago
Absolutely fantastic results.
Thanks maukka!
I really want to get some of those R9080…
clemence
clemence's picture
GREAT thanks Maukka!! LOL
Looks very good. Especially the 144AM. I wasn’t wrong about them
Interested in testing the 319As and NVSL219B-V1 sw40? I’ll ask Chouster to send them to you later
EDIT: I’m not a fan of 219B tint, but I never thought the CRI result is super amazing. Now I know why this one is so special for you guys.
- Clemence
djozz
djozz's picture
Great data maukka!
Did anyone yet put a high CRI 144A in a flashlight with smooth reflector yet? My single sample produces an ugly yellow spot in the center of the hotspot, but it has a slightly uneven phosfor layer, perhaps other’s leds are better?
clemence
clemence's picture
djozz wrote:
Great data maukka!
OMD Jos, you use that egg yolk in your flashlight? Facepalm
I’ll get you a normal one later. Which CCT? Let me know
Cheeers,
Clemence
tuelleric
djozz wrote:
Great data maukka!
Is there a common way to test the LED without reflowing it? I do not want to start my reflowing career with this emitter… Power supply is available.
djozz
djozz's picture
clemence wrote:
djozz wrote:
Great data maukka!
Cheeers,
Clemence
No no, don’t worry, this is another led with a much better phosfor distribution. But even a slightly uneven distribution with the phosfor just a bit thicker (=more yellow) towards the center (my led) already produces the effect in a smooth reflector (have not tried OP yet).
clemence
clemence's picture
djozz wrote:
clemence wrote:
djozz wrote:
Great data maukka!
Cheeers,
Clemence
Ahhh, I see…
Yes, smooth reflectors aren’t the 144Ax mates. I tried them in my predator’s reflector, many narrow TIRs, big reflectors, etc…always a slightly yellow center spot. Fixed easily with even very mild 5 degree diffuser. All medium, wide, and diffused optics worked great. I’m sure OP reflector will do OK since this the artifacts in 144Ax are much less problematic than XHP50
chouster
Last seen: 13 hours 12 min ago
Very nice test, thank you Maukka!
Results of the 219B-V1 R9080 are stunning.
But all LEDs tested here perform well above specs. 219C sm573 even achieves R9080-specs, sm503 very, very close.
Jerommel
Jerommel's picture
Couster, i’ve got my LEDs in too. Thumbs Up
Thanks guys.
2Q19
Evgeniy
Last seen: 5 months 4 weeks ago
clemence wrote:
Yes, There will be NVSL219B-V1 sw45k AND sw40 9080 too
Nice.
interested for 6x NVSL219B-V1 9080 sw40
(or 3x NVSL219B-V1 9080 sw40 + 3x NVSL219B-V1 9080 sw45)
thanks, Maukka ! nice tests.
Flashlights : custom (Jaxman E2L with led4power LD-4 drivers and 3xOsram CQAR.CC), custom Skillhunt H03 with Osram 3К/4К, Zebralight {H600fc IV, Sc600fc IV, H600fc III}, Jaxman E2(N219b), Convoy UV.
Previous: Zebralight {H501, H600W, H600W II, H602W}, NiteCore TIPCRI, A A01, Fenix L2D CE/CEQ5.
Jerommel
Jerommel's picture
Aha, i knew i would have to order more the next time…
I’ll have to take 5 or 6 of the sw40 too of course… Party
it’s never gonna end, is it? Facepalm
2Q19
tuelleric
tuelleric wrote:
djozz wrote:
Great data maukka!
Ok, I just put the 144A in an insulation gasket and tested it with 50 mA from my power supply (sorry for not taking pictures, but I needed all of my hands):
- With aConvoy C8 OP reflector there is a very visible yellow spot in the center of the hotspot.
- With this 52.7 × 57 mm SMO reflector the hotspot is much more intense and there is only a little bit of yellow seen on a white wall.
I guess that the deep reflector directs more light into the hotspot and thus mixes the colors better. When you optimize the focal distance it might become completely invisible, only I do not have the equipment to try that.
My 144A shall go into a McR-27S reflector that I am currently waiting for. When it arrives, I will appentd my findings.
djozz
djozz's picture
Thanks for the report tuelleric, it is hopeful that the 144A works well in some reflectors.
goshdogit
goshdogit's picture
Last seen: 1 hour 31 min ago
Thank you to all the organizers/distributors for making these Nichias available! Thumbs Up
I missed out on the first sale, but managed to score a couple of 9080 SW45s and put one in a Zebralight H51 headlamp. It’s gorgeous!
Now I want to fill a Meteor M43 with them. I’m sure I’ll drop some into a few other lights as well.
I’ll need about 15 more 9080 SW45 emitters please! Big Smile
Texas_Ace
Texas_Ace's picture
Last seen: 1 hour 24 min ago
I see the m43 being the perfect host for these 9080 LED’s. That way you have enough of them to get some good output and it would make a truly amazing photo light.
I took a few pictures today with my triple 9080 and the color is fantastic. It really does make every other LED I own look bad.
Gunga
Gunga's picture
Got my LEDS today? A couple mods planned for tomorrow. Need to find a suitable host to try the 9080!
malkoffdevices
malkoffdevices's picture
Last seen: 5 hours 5 min ago
Is there any beamshots so far of 9080?.
Mine are going into a triple s2+
Thanks.
London !
clemence
clemence's picture
ZFL-M60 wrote:
Is there any beamshots so far of 9080?. Mine are going into a triple s2+ Thanks.
Check 1st page
tuelleric
Got my McR-27S today. The hotspot also has a light yellow center, but not as pronounced as with the C8 OP reflector. Maybe the XM-L gasket that I use does not adjust the 144A in the optimum focal distance. I still have to check that.
kaybi
Last seen: 2 weeks 3 days ago
I have not even gotten my leds yet, and I’m already planning what leds to buy on the next sale.
I’d say 6 sw45 9080, 6 sm503… and I’ll leave it at that for now.
I suppose we can’t actually make reservations yet, though, can we?
Also, thanks for all the tests maukka. That r9 value of 97 is insane.
Evgeniy
When you will receive these 9080 sw40 LEDs ?
clemence
clemence's picture
I really have no idea Sad
Just got a-not-so-pleasing info from Nichia:
- No stock for all Ra9050 and Ra9080 219B/C series. The lead time could be anytime between 1,5 – 2 MONTHS!
- Nichia headquarter decided to (temporarily?) stops the sw45k production. Don’t know why. 4500K has been a rare CCT in Nichia these days. My earlier sm453 9050 144A purchase delayed by almost a full month. Then I only got sw45k 9080 219B in limited quantity.
I’m still trying to get whatever stock left there.
- Clemence
