It’s definitely a good sounding method. Do you recall about how much space it takes up? For space-constrained applications, even doing that method with two bytes sounds far better than what Biscotti has.
I haven't actually implemented it yet. Just on my todo list.
I did work out that the check can look like if (a==b&c&d)
... but that's about as far as I got and actually while that looks tidy it probably doesn't optimize to much if any shorter than more verbose statements.
One trick I used to save some space is to declare a few key variables as global register variables. This avoids all the in LDS STS instructions for those data. If you do it too much (more than a few probably) it can result in more juggling instead of less though. I believe these are always noinit but I have no idea if they'd persist at all like ram variables.
As for two bytes, yeah, that's 1 in 2^8 so 255 for equal weighted bits. I started thinking this through with your idea first actually, then thought this other two byte trick, then figured, well, that makes it better but it will still be an actual problem so it needs 3 and might as well make it 4 (three would still hit someone someday). But three could be good for attiny13 if it will fit.
ah.. just realized that way of doing the check isn't as clever as it is cute. It's possible for that to pass with some not so hard to produce combinations of non-equal values, so it significantly weakens the check. Just have to do out long probably : if (a==b && b==c && c==d) Your claim of a weighted coin probably also weakens it.
I'm not quite sure what the main problem is, but if you're using an Attiny25, why not just use the EEPROM? This in conjunction with the RAM trick or an OTC would be very useful :)
Yes, eeprom can probably work too, but you still need a few bytes of noinit comparisson to reliably see the long press. Once you're setting a few bytes to the same value, might as well set them to the value that matters. If you need multiple sets of all bytes, like a clear and an increment, then maybe that starts to get a little more costly in terms of instructions, depending where it's done and if the variables are still in regeisters from the set when the clear is done(Ok, clear doesn't need the value but anyway some details may matter...) Of course a problem with any multi-byte thing is there can be interruption in the middle of it, but the odds on that are also pretty slim, and can be made slimmer with assembly programming, if one really wants.
Also eeprom is very slow (like multiple ms, which probably implies worse interruption concerns), and it has limited writes. Bistro adds wear leveling to anything written to on every single click (presently just the mode inex) to avoid writing to many times to a single byte. Maybe that's overkill, maybe not (100,000 writes max by spec), but you'd need more code if you want to do this to more variables as the wear leveling code isn't very general.
It's definitely option, and probably more than one way to skin this (including using attiny25's and OTSM) but each may have its own issues as gchart notes.
Very cool GC.
I can do the solder work but exactly as loneoceans posted above I need a translator most of the time.
BTW, I’ve got the multi-byte noinit stuff working just fine in the manner that Flintrock described. For proof of concept, I only used two bytes, but adding an extra one or two wouldn’t be a problem at all.
I need to remember to check and see how much extra space that takes up. I’ll report back later.
And yes, there’s all sorts of ways to address this. But I’d like to see it work on the typical nanjg drivers that are so prevalent… no OTC mods or anything necessary. Especially with the several reports of Biscotti acting funny due to the current noinit implementation, this should solve that.
But I got my 47uF tantalum caps and low leakage diodes now and will put together an OTSM build with bistro, of course not nanjg or attiny13.
Cool, yeah, the cap related comment was not aimed at this case.
Ok, I’ve done some initial fast_presses redundancy size testing. I can’t say these are the most optimized, but it should be pretty good. The code can be found here. I’m open to suggestions… looking at you, Flintrock You’ll notice I was also testing out your variable-length mode groups, FR. With the current mode groups set up, it was adding about 14 bytes. But if I wanted groups longer than 4, I bet I’d see efficiency over making all the groups longer.
No redundancy: 984 bytes (control program)
Using 2 bytes: 1010 bytes (+26 bytes from control)
Using 3 bytes: 1028 bytes (+44 bytes from control)
Using 4 bytes: 1044 bytes (+60 bytes from control)
cool, 60 bytes sounds reasonable to me. I was hoping for 50, but that was kind of just my guess. Yes the variable mode-group length has a little buy-in price. I haven't looked yet, will soon, so not sure how this translates to the tiny13 firmware, but the next biggest savings was probably all the array looping of the menu variable operations, save, restore, and toggle. The easiest savings were probably
a) going through every function and trying with and without inline as the compiler doesn't optimize this as well as you expect even though it's only supposed to be a hint, and it's not always as obvious as it seems which way is best.
b) Changing some key variables to register variables. (and it matters which register is used).
really it would be great if we could figure out how to include the attiny13 software as a subset of bistro(already setup that way in principle, but in practice may be hard now to get a small enough configuration). I might look at it. Then these changes don't need to be maintained in two places. But it's good this way too. It's not like it's a huge program.
Yeah, I just went thru the inline / no-inline exercise on every function. Can be a good amount of savings there. Now that I’ve refreshed myself on inline functions, I’m using them more to make the code easier to read. It had been about 12 years (college days) since I last used C for much.
I’ll have to take another look thru your code. I’m not real familiar with the register variables
One thing I was shocked about is how much space can be saved by using local variables instead of globals when hitting it frequently. Like in count_modes(), swapping out solid_modes for a local variable when iterating thru.
So bistro-HD seems to compile for attiny13 just fine and I guess the nanjg layout that I essentially copied over from previous bistro, should work. I see that there are some things missing for making it a true BLFA6 replacement, example timed turbo (attiny25 doesn't need it of course, so the opposite of your issue), and star configuration. I don't know if I'll get around to adding that or not, but I'm making a separated config file for a BLFA6_EMU build. Partially I wanted to start breaking out config files like this anyway, because it seems it will be useful for other various builds. I'm not sure how the size of bistro-nanjg13 compares to BLFA6 because the options are setup exactly comparably yet, but it's at least possible to get something working in under 1K.
deleted, momentarily confused. I saw OTC in blfa6 and forgot that you said you modified it specifically for not using that.
Local variables can be allocated on a stack frame, and then probably aren't really better than globals that need to be fetched from the RAM "heap". However, in my testing the compiler is pretty decent at keeping locals entirely in registers until you have too many of them. Then if they really are temp variables, there's no loading and saving them, so that saves some instructions.
This is the same reason why changing a global to a global register vairable can help. However, it reduces registers available for local use, so it can hurt too.
Looking at the A6 firmware now. Ok, I see, with so few modes and so few options, optimization is an entirely different story. It's just so simple and efficient to sort of hard code everything there as done. Probably many of my optimization ideas don't apply, and also the idea of including BLFA6 as a config option in bistro kind of looks hopeless. It's probably too much overhead to produce a relatively much simpler driver in so little space, which I guess is why TK didn't do it too.
So mine came in at 38 bytes. It seemed like getting this part right may be where some savings is:
inline uint8_t check_presses(){
uint8_t i=N_SAFE_BYTES-1;
while (i&&(fast_presses_array[i]==fast_presses_array[i-1])){
--i;
return !i; // if we got to 0, they're all equal
The compiler unrolled it being only three compares.
clear_presses() and inc_presses() are just simple for loops, so that's kind of all there is.
inline for inc and check but not for clear.
Anyway, it seems in HD this is presently only useful for the HD-biscotti build, but that has zero free bytes.
To me though it's better to have it stable and drop a strobe mode. Maybe I'll find 38 more bytes though. That's seeming pretty hard. I can imagine 20, and I can drop this to 3 bytes for the HD-biscotti build.
Because I started out with only a 2nd redundancy byte, I also checked to make sure they were <=15 as an extra failsafe. It appears that this was costing me more that I thought it would… around 14 bytes?!
inline uint8_t we_did_a_fast_press() { return (fast_presses == fast_presses2) && (fast_presses <= 15); }
If I remove that check (for all but the single-byte version) and convert them into array-style as you have done, I get these results:
No redundancy: 950 bytes (control program)
Using 2 bytes: 968 bytes (+18 bytes from control)
Using 3 bytes: 970 bytes (+20 bytes from control)
Using 4 bytes: 990 bytes (+40 bytes from control)
I’d call my +40 consistent with your +38. I’m not sure why going from 3 bytes to 4 costs and extra 20 bytes of code when going from 2 bytes to 3 was only an extra 2 bytes. Given that, I’ll probably stick with 3 fast_presses bytes… should be pretty safe with 3 bytes.
I also played around with the variable-length mode groups and got my count_modes function down small enough (only 6 bytes or so over static-length) that I decided to switch over to it. I don't know if this is any help to you, but I'll go ahead and share it. It doesn't account for hidden modes or reversal (I just have extra modes for reversed order), so you'd need to address that.
inline void count_modes() {
uint8_t group = 0, mode, i, mc=0;
uint8_t *dest = modes;
const uint8_t *src = modegroups;
for(i=0; i<sizeof(modegroups); i++) {
mode = pgm_read_byte(src+i);
// if we hit a 0, that means we're moving on to the next group
if (mode==0) { group++; }
// else if we're in the right group, store the mode and increase the mode count
else if (group == modegroup_number()) { *dest++ = mode; mc++; }
num_modes = mc;
