Lexel, I thought that I was the king of blackening dedomed leds in zoomies but I just found the master!
Wow TomE what a monster. I think RBD and Tom should’ve made separate threads.
I was also thinking Level did a good job on the black out.
When it’s done I will but for now it’s what I did today.
I like my Lumintop tool AAA because of the small light with clicky switch. I don’t like twisties. But for a magnetic tailcap I need to sacrifice the good switch. Then I putted 3 small neodymium magnets on the clip and secured it with heat shrink tube. Now I got clicky and magnet. Done
Haha little trick :+1:
Today was a GREAT modding day for me. My first two real mods came out nice. My first was a duel 18650 C8 knock off I got 6 years ago. I installed a 17MM FET driver and a XHP50 on a copper MCPCB to the pill. Did a spring by-pass. WOW! At 6.49 amps this thing is like a pocked search light! The Second was My SRK 6. I re-flowed 6 new XM L2 U2 emitters, installed a custom made 3/8th’’ copper slug to the bottom end of the MCPCB, had to bevel it so the switch wires cleared. Installed a driver from Mountain Electronics, 46mm - SRK V2 FET + 7135 Driver
- SRK V2 Firmware: SRK Spec. | Ext. Tem… - SRK V2 FW Stepdown: 90 Sec. - SRK V2 Input Voltage: 1S (~4.2V) added 4 Panasonic NCR 3400mah batteries and started to laugh when turbo came on. I LOVE THIS STUFF LOL. I am starting to have way to much fun doing this and have noticed a sizable decrease in the pocket book I must admit, the reason why I love modding flashlights is the same reason I became a welder 20+ years ago. It feels good to create something and then to sit back and say, I did that. I took my newly modded SRK 6 out and compared it with my X7 Marauder just a couple hours ago, like three times lol, and the SRK out threw the X7 by quite a bit! Another great thing is the people here at BLF. If it was not for Texas Ace I would have used the wrong size emitters. The knowledge that Texas Ace and Rufusbduck gave me made my new first experience fun instead of an expensive mistake. OK, lets see what else I can tear apart. That’s right, my new 76cc heads will be here for my 5.7l next week and I have to rebuild my engine. I’d rather mod a few lights.
Now for the cruel truth, ” beam shots or it didn’t happen”.
Great work Majorok, and indeed: pics or it did not happen, prefereably next to the X7!!
Another soul lured into modding flashlights :smiling_imp:
well, i finally took the plunge. I decided to try to machine a complete light up from round stock.
i remember someone here recently saying that when they build a light on machining? that they work on the HEAD, and the TAIL, and do the battery part last.
I went in for the battery tube, figuring once i had that done, the light will sort of “tell me” how to do the tail and head.
I made the mistake of just “going in” because i was waffling on exactly what i was gonna do.
shrugs
it was either a 12 or a 15 hour shift, i lost track. Back is killing me too, ha ha… i cant post pics yet, because I am in the middle of a “boring”, asd i dont wanna break centerline by unchucking it till at least thats done.
if i “epic fail”, i will dutifully report it for you to have a giggle…i figure if this first one “works okay” then i will call it a success.If it even looks half decent? i will call it a blazing success (and you will have to hear about it, i can about figure i could get like a little kid if i pull this off.)
it is fun though, diving right in, rolling with the punches.
Good luck sedstar, I will be enjoying anything that comes out of this
Mod my Convoy S2+
with UV LED from Aliexpress 3W 3535 High Power LED UV Light Chip 365nm (max 500mA)
https://www.aliexpress.com/item/3W-3535-High-Power-LED-UV-Light-Chip-365nm-395nm-Emitter-Diode-Ultra-Violet-DIY-With/32762365038.html
Aliexpress UV LED (1*AMC7135@350mA) + 2mm ZWB2 filter
Convoy S2+ Nichia LED from GB (2*AMC7135@700mA)
Datasheet http://forum.fonarevka.ru/attachment.php?attachmentid=185337&d=1489135806
Yes, I may have been guilty of mentioning the head first, tailcap secondly and the battery tube last but LTP didn’t agree with that either. Good luck on the build and give that back a rest.
@ Serp, So it looks like the Nichia has a sharp cut-off above 370nm and the aliexpress led has somewhat higher output towards the 400nm, so some purple glow is picked up by the camera (probably not visible?)
The output of the AE led looks pretty good!
Did the S2+ with Nichia have a ZWB2 filter too?
No
The burgundy paint is very bad (nose, beard on the first photo).
Without a filter a lot of extra light. I think nichia was better in this regard. I do not have it right now.
Extra glow removes the ZWB2 filter.
But, for its price it is a good UV LED
Low power at 350mA
I want to put LED in lumintop tool (or made Nanjg driver @500mA for Convoy)
That’s without optics. Naked LED on the radiator.
UV Lumintop TOOL
The same UV LED
with 10440 Li-On 500mA on the Medium mode
with 1.5V (laboratory power supply) - 300mA on the MAX
Nice!
Nice, now put a ZWB2 glass in front of that visible beam and you’re set !
If you are uncomfortable with sanding down 20mm filters (I still am) this might be an expensive solution:
http://www.ebay.nl/itm/2x-Sarin-Technologies-Diamond-Gemstone-UG1-Filter-Lens-Diam-12-5mm-Thick-2mm-/131671001813
But 12.5mm might just not fit?
So much awesomeness in one thread! Really inspiring to see the creativity and talent here, hoping to jump into modd'ing in near future but gonna be lots of baby steps to get there...
@lexel & djozz - forgive the ignorance but what's the purpose of blackening dedomed LED's? Wouldn't it be better to have a white/shiny surface for better reflection OTF?
@ZozzV6 - clever and elegant way to add magnets to a light!
I guess it is an autistic thing: a zoomie in spot modus must only show the hotspot and nothing else, no halo around the led, no rings. In actual use some stray light is often very handy but this is a compulsive thing and has not much to do with reality.
