What did you mod today?
4876 posts / 0 new
EasyB
Last seen: 1 hour 26 min ago
Ha, nice. For a second I was afraid it was going to be a reflectorless mule. What do you have on there, S2 or so sized reflectors?
CRX
CRX's picture
Last seen: 2 min 27 sec ago
Tom E wrote:
Quick test on Sam 30Q’s as-is, calculating lumens, I got 34,200. It’s bright.
Well that’s an understatement Big Smile
Nice Thumbs Up
FmC
FmC's picture
Last seen: 2 weeks 3 days ago
Tom E wrote:
Not bad for an UltraFire. I actually beat the claimed lumens of 20,000
Very nice, Tom Big Smile
giorgoskok
giorgoskok's picture
Last seen: 5 hours 43 min ago
Noce work Tom ! I was waiting for this build since the day you mentioned you ordered the Leds Big Smile .
Probably stock reflector . Using S2 or similar reflectors would be awesome…
djozz
djozz's picture
Last seen: 5 hours 10 min ago
wow, extremely impressive Tom, looks like a very neat assembly, and that is 2000 lumen per led which is a big achievement for a relatively compact multi-led light.
Would like to see that beam in person Party
MRsDNF
MRsDNF's picture
Last seen: 2 hours 48 min ago
Tom. That is just plane nuts. What a fantastic effort and execution. Hope the driver problems get solved. Beer
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
Tom E
Tom E's picture
Last seen: 5 days 7 hours ago
Thanks all! I'll have to see what I can do for beam pictures. These are E2's, so 5700K or so. I'm gonna try to take lumens and throw measurements this morn.
steel_1024
steel_1024's picture
Last seen: 9 hours 22 min ago
烽燧 LiteFlux LF2XT
Cree XP-E Q4 Neutral white LED
Change to……
CREE XQ-E Hi R2 Neutral white LED
with XP-L Hi
pretty little LED
AAA (middle)
Sorry for my poor english.
djozz
djozz's picture
Nice to see a mod with the XQ-E ! R2 sounds like a good bin. That Liteflux flashlight is from before I was a flashoholic Smile
Tom E
Tom E's picture
They are actually bigger than S2 reflectors at 21.2 mm diameter with the total head width of 99.2 mm. S2's are about 18-19 mm. I used 16 mm Noctigons with only the 5 outer most needing a slight sanding to fit at the edge.
Measured throw from 5 meters: 155 kcd (787 meters)
So it's a thrower, I mean a flooder or throoder? This is why I wanted to go big with a head like this - I knew the throw would do well, but didn't expect to break 100 kcd. Ganging triples/quads is easy, like the Meteor or Vinh's custom 30K+ monster, but it's mostly a flood light then.
Enderman
Enderman's picture
Last seen: 6 hours 30 min ago
Why not just go with a single COB led and get the same lumen output from a single chip + large reflector?
Pretty sure it would be more efficient than multiple XHP50s, so less heat and battery drain.
Cula
Cula's picture
Last seen: 5 hours 32 min ago
Pretty impressive monster you got there Tom. Surprising results also for such a shallow reflector. Sheer power does the job. How much did it cost to build this?
Tom E
Tom E's picture
Enderman wrote:
Why not just go with a single COB led and get the same lumen output from a single chip + large reflector? Pretty sure it would be more efficient than multiple XHP50s, so less heat and battery drain.
Dunno much bout COB's. The voltage of XHP50's is perfect for the 2S3P batteries. I'm not an EE and can't custom design boost or buck drivers, for sure.
Most of the cost is the LED's - roughly $150 $140 for bare LED's, $22 for the Noctigons, ~$80 for the host (can get it for $62 or so now), maybe $15 or so for the driver and wires, so $257 total.
khas
Last seen: 1 day 9 hours ago
I just modded my perfectly working Utorch UT02 into a fancy paper weight.
I wanted to change the resistor to gain more output. First I had a hard time getting the driver out ( should have stopped there) found the resistor, it was so tiny (or stopped here). Then I remembered when I tried to solder moonlight parts on a LD-2 driver (definitely should have stopped there). When ahead anyway and ended up with a dead flashlight. So from now on re-flowing emitters and changing drivers is all the modding I will do, that is of course only until the memory of this failure have faded and I think “how hard can it be”.
vwpieces
vwpieces's picture
Last seen: 1 day 54 min ago
I think there is a what did you break today thread. If not there should be. I have a fair amount to contribute to it.
Don’t give up khas. Get one of these, changed my outlook on what can be done.
giorgoskok
Modded mine with dedomed xp-g2 and TA driver running Narsil , i couldn’t be happier … making 292kcd now Big Smile
Lexel
Lexel's picture
Last seen: 3 hours 53 min ago
Brinyte B158
Rufusbduck
Rufusbduck's picture
Part 3. Used 1” and 2” hoke saws wrapped with tape and sandpaper to ream the copper fins to fit and made a jig to sand the spacer rings down to an even 1.5mm (+/-.02mm). Just slip fitted for now. I also turned the wood down a few more mm.
Scott
MRsDNF
MRsDNF's picture
No? Yes indeed.
djozz
djozz's picture
Lexel wrote:
Lexel, I thought that I was the king of blackening dedomed leds in zoomies but I just found the master!
pinkpanda3310
pinkpanda3310's picture
Last seen: 38 min 37 sec ago
Wow TomE what a monster. I think RBD and Tom should’ve made separate threads.
I was also thinking Level did a good job on the black out.
Rufusbduck
When it’s done I will but for now it’s what I did today.
Scott
ZozzV6
ZozzV6's picture
Last seen: 6 hours 18 min ago
I like my Lumintop tool AAA because of the small light with clicky switch. I don’t like twisties. But for a magnetic tailcap I need to sacrifice the good switch. Then I putted 3 small neodymium magnets on the clip and secured it with heat shrink tube. Now I got clicky and magnet. Done Smile
Serp
Serp's picture
Last seen: 1 week 5 days ago
Haha little trick Thumbs Up
Majoroverkill
Majoroverkill's picture
Last seen: 1 month 1 week ago
Today was a GREAT modding day for me. My first two real mods came out nice. My first was a duel 18650 C8 knock off I got 6 years ago. I installed a 17MM FET driver and a XHP50 on a copper MCPCB to the pill. Did a spring by-pass. WOW! At 6.49 amps this thing is like a pocked search light! The Second was My SRK 6. I re-flowed 6 new XM L2 U2 emitters, installed a custom made 3/8th’‘ copper slug to the bottom end of the MCPCB, had to bevel it so the switch wires cleared. Installed a driver from Mountain Electronics, 46mm – SRK V2 FET + 7135 Driver – SRK V2 Firmware: SRK Spec. | Ext. Tem.. – SRK V2 FW Stepdown: 90 Sec. – SRK V2 Input Voltage: 1S (~4.2V) added 4 Panasonic NCR 3400mah batteries and started to laugh when turbo came on. I LOVE THIS STUFF LOL. I am starting to have way to much fun doing this and have noticed a sizable decrease in the pocket book Silly I must admit, the reason why I love modding flashlights is the same reason I became a welder 20+ years ago. It feels good to create something and then to sit back and say, I did that. I took my newly modded SRK 6 out and compared it with my X7 Marauder just a couple hours ago, like three times lol, and the SRK out threw the X7 by quite a bit! Another great thing is the people here at BLF. If it was not for Texas Ace I would have used the wrong size emitters. The knowledge that Texas Ace and Rufusbduck gave me made my new first experience fun instead of an expensive mistake. Big Smile OK, lets see what else I can tear apart. That’s right, my new 76cc heads will be here for my 5.7l next week and I have to rebuild my engine. I’d rather mod a few lights. Silly
Doug S.
Rufusbduck
Now for the cruel truth, “ beam shots or it didn’t happen”.
Scott
djozz
djozz's picture
Great work Majorok, and indeed: pics or it did not happen, prefereably next to the X7!!
Another soul lured into modding flashlights Evil
sedstar
well, i finally took the plunge. I decided to try to machine a complete light up from round stock.
i remember someone here recently saying that when they build a light on machining? that they work on the HEAD, and the TAIL, and do the battery part last.
I went in for the battery tube, figuring once i had that done, the light will sort of “tell me” how to do the tail and head.
I made the mistake of just “going in” because i was waffling on exactly what i was gonna do.
shrugs
it was either a 12 or a 15 hour shift, i lost track. Back is killing me too, ha ha… i cant post pics yet, because I am in the middle of a “boring”, asd i dont wanna break centerline by unchucking it till at least thats done.
if i “epic fail”, i will dutifully report it for you to have a giggle…i figure if this first one “works okay” then i will call it a success.If it even looks half decent? i will call it a blazing success (and you will have to hear about it, i can about figure i could get like a little kid if i pull this off.)
it is fun though, diving right in, rolling with the punches.
With enough black coffee and cigarettes? all things are possible…
I am currently still shipping… REAL GENUINE CREE xp-g emitters, the classic… brace yourself? as low as 20 cents apiece!! Check out the SALES THREAD, everyone is happy… then PM me
SALES THREAD:
http://budgetlightforum.com/node/52528
if you are into reloading? this is my site… I inherited the remains of what was once arguably the best reloading site on the internet… its the “BLF” of reloading sites…
http://reloadbench.freeforums.net/
if you think night vision would be cool? It IS… this site i am a member of, and its basically the “BLF” of home made scratch-built digital night vision. They are at the leading forefront of advanced DIY for digital night vision, and thats gun mounted or handheld… builds rival and exceed commercial offerings…
http://nightvisionforumuk.com/
djozz
djozz's picture
Good luck sedstar, I will be enjoying anything that comes out of this Smile
Serp
Serp's picture
Mod my Convoy S2+
with UV LED from Aliexpress 3W 3535 High Power LED UV Light Chip 365nm (max 500mA)
https://www.aliexpress.com/item/3W-3535-High-Power-LED-UV-Light-Chip-365...
Aliexpress UV LED (1*AMC7135@350mA) + 2mm ZWB2 filter
Convoy S2+ Nichia LED from GB (2*AMC7135@700mA)
Datasheet http://forum.fonarevka.ru/attachment.php?attachmentid=185337&d=1489135806
