Well said, I have more than 10 of Thorfire VG10 (including 4 on the way) for whole my family, will need a lot of time to collect them back and check all of them this weekend. The 1st one in my work space is OK. :person_facepalming:
I don’t think the average smoe on Amazon would ever notice it. Half of them don’t even know you have to recharge an 18650. “My light is blinking, I’m returning it” or they can’t find the batteries at Walmart, etc…
All these negative waves, man. Negative waves…
I thought I had the perfect light. Really hope all of mine aren’t as described.
I’m not looking for refunds (as I absolutely don’t want to return the lights!), but asked if they’d have something like a copper disk to fit between shelf and LED, or the right-sized reflector to just swap in. I’d rather keep the lights and just fix them, rather than send them back.
Figure something like that (a fix), made in bulk and dropped in the mail, would be cheaper in the long run than refunding people the purchase prices. I’d be happy with that, but can’t speak for anyone else.
Anyway, I’ll see what’s on the table when I get a reply. And will add that’s a nice move on TF’s part to just own up and offer to make things right.
Agreed.
Too bad about this little problem. i actually like this light a lot.
i don’t mind buying a defective product for cheap.
i just wish they are up front about it.
Not to minimise the situation, but sometimes, $#!+ happens. There’s pressure to get product out the door vs to lose sales. Someone comes up with a workaround, maybe a good one, maybe a crappy one. It nominally “works”. Products get refitted, and go out the door.
Take a voltmeter. The mfr can’t get the reference they want, so have to “make do” with a cheaper one, maybe a stinkier 5% tolerance instead of 1%. Most people poking batteries and AC outlets probably wouldn’t even notice, but those who need and want something more accurate (and are willing to pay for it) would be outraged.
Or a “lipstick” type power-pack that is rated 3000mAH but only has a 2500mAH cell inside. Most bozos just topping off their phones and mp3 players would hardly notice, but others who’d take it apart would flip out at seeing only 2500mAH.
So yeah, most schmos who’d buy a bright flashlight might not even notice anything’s off. LEDs are robust enough to take the abuse if heat’s not drawn out as well as a “good” host can do. But it’s still a crappy solution, going through multiple layers of dielectric and thermal-goop.
The problem is that someone at TF decided that was a good workable solution. I’m disappointed, absolutely, but the light’s not totally unusable. At worst, don’t swap in a FET driver that crowbars a high-amp cell right across the LED.
Like I said, I’d be okay with a fix, whether a “real” reflector replacement, or Cu spacer to clean up the thermal path.
Hi Lightbringer. I'm don't believe ThorFire will require or expect you to return the lights.
Hi Lightbringer. I’m don’t believe ThorFire will require or expect you to return the lights.
Yep, just got that in a PM. Will work it out through Amazon channels.
Even with the “wrong” reflector, they’ve got a great beam, so I can’t wait to see what it’s like with the “right” reflector!
Will have to figure out the dimensions of the stars+disc, try to whip up a Cu spacer on my own. Don’t really have the tools or a machine-shop, other than files and such to shape the critter manually (shaving it down if need be), so it might be a bit tedious.
I think the way to go would be
Get two copper DTP stars
Put a little solderpaste between them, and where the led goes
Reflow led and join the two in one go.
But I don’t have this light only an original second run bought from member X3 and I like it a lot
Would still have to shave off the dielectric, but imagine it’s less tedious than trying to shave down a Cu blank.
I was oblivious to the latest developments in this thread until just now. I ordered a couple VG10 during the group buy, I just checked tracking and they are scheduled to be delivered today. I’ll open them up and see what the guts look like, but I guess I should anticipate it will be :POOPEMOTICON: I will report back with my findings tonight…
But it seems like Thorfire is trying to make it right, which is what matters. For now I will give them the benefit of the doubt until proven otherswise. I will contact them and give them the opportunity if I have concerns.
There is a Bright side to the VG10’s that have the stack of crap under the emitter….
Parts for the Convoy M2 will fit. Here is my latest VG10 using the M2 Quad spacer from kiriba-ru. I have not tried the M2 reflector alone but will in a few minutes. Theoritically it should work and I have a couple spare reflectors from M2 quad builds. And just a heads up… I did have to reduce the OD of the brass ring that came witht he M2 quad parts to fit inside the head of the VG10.
Also I tried to swap heads onto a VG10 that did not have the crap under emitter with one that does and they do Not thread together… No-Lego.
Wowser! Love what you did there. Thanks for the lego info too.
Same as others.
- Spacers under LED star
- blemished reflector
- chipped lens
Any solution found for replacing that “spacer” with something?
I could always make something, but don’t have tools.
Already made solution would be perfect.
Despite the issues with the current batch, I still like the VG10 and would be interested in placing another order. If I placed another order before the GB closes on 3/21, would I receive lights from the same batch with the bad LED spacers? Or could it be confirmed that I would receive units from a good batch?
Just curious…
Has anything happened as far as those who ordered lights through Amazon? Last PM left off with me offering the 2 order-IDs from Amazon (because how else can they know who ordered what, naturally), but got nothing in reply since.
Am I supposed to grex through Amazon under “contact seller” or raise a complaint (“product not as described”) or something? (The latter sounds kinda negative, so I’d want to avoid that unless specifically told by TF to go that route.)
Only reason I’m getting antsy is because I just got a new fancy card in the mail with the chip inside, and has a completely different number and everything, so if the offer is to toss me some bux to the old card on which I charged the lights, that’d be defunct once I activate the new card.
Sounds like kiba-ru might be able to make a quick killing with perfectly-dimensioned and drilled Cu spacers!
Hope you get resolution soon LB. Please keep us posted.
Any solution found for replacing that “spacer” with something? I could always make something, but don’t have tools. Already made solution would be perfect.
You could get 2 or 3 pre-1982 US pennies, clean them and pound them flat. Once you have them to the diameter you want, you can stack them to see if they get you high enough. If they are a little shy, reflow them to each other and that will increase the height some. If you don't want to reflow, thermal paste should do. If too tall, pound them some more and file the perimeter to get to fit in the head again.
Good question. Also, maybe ofter the remaining lights for sale as hosts. They will sell fast if the price is reasonable.
