Baked / Heat Colored Convoy Pictures
38 posts / 0 new
Justintoxicated
Justintoxicated's picture
Last seen: 2 weeks 2 days ago
Please post what you did to color it.
I did a blue in my electric oven on broil, it just became a more metallic lighter blue.
Picture (Black, Gray, Baked Blue)
Then I did a Gray in my electric oven on broil, it removed all the blue coloring from the gray light (Gray convoy S2+'s are slightly blue)
Picture (Gray, and Baked Gray)
I was kind of hoping the gray would turn that nice tan color I have seen others change to like this picture here:
Edited by: Justintoxicated on 03/09/2017 - 15:45
Bam35
Last seen: 7 hours 10 min ago
I like those results. How long and what temp?
MILSPEC
Last seen: 2 weeks 6 days ago
that is amazing. so you just put them in a hot oven and wait? looks fantastic, well done.
Justintoxicated
First, you have to remove all the guts and if it is a host, don't forget that spring and emitter centering thing they stuff into the tube) and give them a good wipe down with rubbing alcohol to clean off any oils. Don't forget the threads, I did on the last one and it smoked the lube. Makes me feel bad about boiling off whatever chemical/lube was on them in our cooking oven.  If you do that you should be fine and pretty much fumeless.  I baked mine with the 18350 tubes so I could watch all the pieces together.  On my blue light, I had to overcook a couple pieces to get them more uniform, so it's good to keep an eye on the parts.  For the gray, they all baked pretty even the first try, including the 18350 extension tube.
I just set the oven to broil for both and left them for about 1/2 hour or so (Longer for the gray).  YMMV since all ovens are a bit different.  I'd suggest checking every 5-10 minutes anyways.  The blue one colored shifted a bit as it cooled down.
I'll try to get a picture of the whole lineup I have acquired so far soon.  It is very addicting Smile  I think I will either torch my blue or bake a black next.
Lexel
Lexel's picture
Last seen: 6 hours 17 min ago
Black Convoy S2+ 365nm UV
C8
Streamer
Streamer's picture
Last seen: 4 hours 51 min ago
It matters what HA finish you are baking. HAIII finish will not bronze up like the HAI / HAII finish. It will only lighten up in color a bit.
RobertB
RobertB's picture
Last seen: 4 hours 8 min ago
Formerly Black. 550°F for 30 minutes suspended on a wire between oven racks. The room lighting makes it look almost purple, but it’s more of a rust brown in sunlight.
Henk4U2
Henk4U2's picture
Last seen: 21 min 53 sec ago
Part of my UV-squad. The one in the middle used to be a dark grey Convoy S2 Simon sold with a generic UV-led.
Baked 30 min at 300 deg.C in an electric oven. The color is a bit off. It’s actually slightly golden/brownish.
I always think long and hard before I say something really stupid.
RobertB
RobertB's picture
I have a green Convoy S2+. Wonder what it would look like after a bake. My luck it’d probably turn pea green
Cythras
Cythras's picture
Last seen: 6 days 5 hours ago
I am tempted to buy a bunch of the coloured extension (distension?) tubes just to bake then so I don’t ruin any lights. My grey Convoy turned that bronzey silver only at higher temperatures and after a bit longer. It originally just turned silver like yours.
Justintoxicated
Cythras wrote:
I am tempted to buy a bunch of the coloured extension (distension?) tubes just to bake then so I don't ruin any lights. My grey Convoy turned that bronzey silver only at higher temperatures and after a bit longer. It originally just turned silver like yours.
which convoy was it?  I'd be tempted to either re-bake this one, or buy another one to play with.  They are only $8-10 for the host Smile
vwpieces
vwpieces's picture
Last seen: 3 days 19 hours ago
I tried a Blue S2+ and it got crackly looking. As if there was a thin glass layer on top that broke. Couldn’t get it to change much on Broil close to the element. Had some others that each piece went completely different shades. All the Fails got stripped and polished.
My older Glossy Black M2 did turn out well.
RobertB
RobertB's picture
Just finished baking my Astrlux S41. I forgot all about the 350 tube it came with, and baked it with the optional 650 tube. It looks like the optional 650 tubes were possibly leftovers from the BLF A6, since the tail cap and bezel changed to a slightly different color. I will bake the 350 tube tomorrow and see if it matches. Either way, it doesn’t look too bad. If anything, the 650 tube matches the copper better than the bezel. I never liked the black contrasting with the copper anyway.
tekwyzrd
tekwyzrd's picture
Last seen: 6 hours 47 min ago
@RobertB What temperature and how long did you bake the S41? I should receive the one I ordered and 18650 tube in about three weeks. I ordered it earlier today with the intention of baking it. I hope for a closer match from newer stock but would be satisfied with results like yours. It looks good. The S2+ looks REALLY nice.
RobertB
RobertB's picture
tekwyzrd wrote:
@RobertB What temperature and how long did you bake it? I should receive the one I ordered and 18650 tube in about three weeks. I ordered it earlier today with the intention of baking it. I hope for a closer match from newer stock but would be satisfied with results like yours. It looks good.
550F on bake setting. (Thats as far as mine would go). String a bare wire from one end of rack to other, string the parts through and let them hang without touching rack. Put rack in oven and bake for 30 to 40 minutes. Let cool, put o-rings back on.
I washed the parts with dish soap, water and dried them off first.
tekwyzrd
tekwyzrd's picture
@RobertB Thumbs Up Thanks!
Majoroverkill
Majoroverkill's picture
Last seen: 1 day 2 hours ago
Wow! these look really nice. I think i’ll try this with nap gas. I have used ceramic header paint on projects and I take a torch with nap gas and heat the paint just shy of burning and the glassy colors are awesome. I love the heat baked look of these lights. Big Smile
Doug S.
The Miller
The Miller's picture
Last seen: 1 month 4 weeks ago
Nice nice
Have baked several but no Convoys Wink
I use the flames of gas furnace and it is done in a few minutes instead of pre heating oven and pit it in for a long time.
caramba
caramba's picture
Last seen: 2 weeks 1 day ago
!{width:70%}http://i.imgur.com/SAhtnR5.jpg!
Very nice brown color, just like the teriyaki Salmon I had for dinner.
How did you protect the “convoy” label from getting scorched?
Kenjii
Kenjii's picture
Last seen: 45 min 57 sec ago
!{width:75%}http://i.imgur.com/4sI2wEl.jpg!
40 Minutes at 250°C. The tailcap needed about 15 minutes more to get the same color as the battery tube.
Regards
Kenjii
RobertB
RobertB's picture
I didn’t protect it. It doesn’t scorch or change color
RobertB
RobertB's picture
Got the colors to match the tube better. Had to put the bezel back in the oven for another 10 minutes, and the tail cap in for another 20. Tail cap is still off just a bit, but close enough.
Yokiamy
Yokiamy's picture
Last seen: 7 min 26 sec ago
Ok, it is not my convoy light, but that was with a reason, i was afraid that i might destroy it. so after reading all this i thought, Lets do it!
I disassembled some unbranded cree Q5 led light and put it in the oven @275 deg. C. For approx 30 minutes
Look at the result! Beautiful! Nice gold/copper color.
Assembling went ok, everything went smooth, until i tried to remove the batteries…
Ahh, the horror!
Lucky me, that i did not try out my convoy!
What did i do wrong? I forgot to lubricate because i was to enthousiastic! Would that be the only thing?
Since all threads felt smooth during assembly i did feel confident that it would be perfect!
Well, now i know how to do it and not to do it, lets call it gathering experience
Thijsco19 wrote:
a regular symptom of flasholism Big Smile
“Flasholism is the most severe form of flashlight use and involves the inability to manage your flashlight use habits. It is also commonly referred to as flashlight use disorder. Flashlight use disorder is organized into three categories: mild, moderate and severe. Each category has various symptoms and can cause harmful side effects. If left untreated, any type of flashlight use can spiral out of control.”
Lightbringer
Lightbringer's picture
Last seen: 7 hours 4 min ago
Nah, and if it does, call it “khaki”.
BobbyMK
BobbyMK's picture
Last seen: 1 hour 34 min ago
Ive done some experiments with tubes but haven’t baked whole light yet.
Left tube was blue, right was black
And baked ring on L6
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
tekwyzrd
tekwyzrd's picture
Not a Convoy. Freshly baked S41. I decided to try using the old Toastmaster toaster oven. Set to bake at max which is a bit past the 500° mark and after 15 minutes this is what I got.
The 18350 tube is a bit darker but the 18650 tube is close enough to the tailcap and bezel I’m satisfied with the results. There’s more difference in the photo than there is actually looking at it up close.
Parts were prepped by gently scrubbing with a soft toothbrush and a dish detergent and water mixture, rinsed thoroughly, and soaked briefly in 90% isopropyl alcohol and hung on a wire in the toaster oven to dry. I used a heavy piece of copper wire bent to fit in the tray slots in the sides of the oven between the ceramic elements.
The color’s a bit off in the photo but I’d say in person it’s somewhere between pecan and syrup in the image below
Cythras
Cythras's picture
Justintoxicated wrote:
which convoy was it?  I’d be tempted to either re-bake this one, or buy another one to play with.  They are only $8-10 for the host Smile
It was a regular blue-ish grey S2+. Ended up looking like this.
tekwyzrd
tekwyzrd's picture
Recently received Convoy L4 baked in the toaster oven at 500°F. The head and bezel turned what I consider coyote brown after about an hour. The tube and tailcap are still a bit darker after an additional half hour but I’m satisfied with the result. Here’s a photo of the body assembled minus innards next to an unbaked L5 head. Will replace photo with one of better quality and edit post after assembly. Tube and cap in photo are a bit darker than real life. Waiting for an xp-l v6 3d on a 20mm mcpcb.
An example of Coyote brown (fabric).
edit: While visiting the Convoy store on aliexpress I see that based on the photo the color I got after baking the L4 seems to be pretty close to the color of the desert tan S2+
WalkIntoTheLight
Last seen: 15 hours 48 min ago
Does baking damage the threads, or have other adverse effects? I seem to recall when I’ve (probably incorrectly) baked other metals, it becomes kind of gritty. Probably an oxidation layer. Does the anodization protect flashlight tubes/threads?
tekwyzrd
tekwyzrd's picture
I’ve only baked two lights so far but haven’t noticed any grittiness or damage to threads. I’d imagine that residual grease could produce grit or charred deposits in threads if not thoroughly cleaned before baking.
tekwyzrd
tekwyzrd's picture
I re-baked the L4 to get the colors closer. There seems to be a bit of a pleochroic effect with the color changing depending on the angle. From some angles the head and tube are nearly identical and others the tube has a bit more of a copper tint. Here’s the L4 as it is now beside the same black L5 head and the S41 that was my first baked light.
