Congratulations to everyone involved! Awesome job!
@RH64 Well the main original goal, OTSM, has some problems still, and it's a mystery at the moment that I'm a bit stumped on. The debugging required to get the bottom of it is maybe not lightweight at all either (maybe needs custom hardware to time triggered shutdowns for example, a bunch just to debug).
@Lexel I think I misunderstood where you're coming from. You're trying to port the e-switch into Bistro-TA. That's your mistake. Bistro-HD is a not a specialty release like some previous ones. It fully includes bistro-TA, as well as bistro-trippledown and plain bistro, and I may even get a BLFA6 emulation build into it. It's just a matter of selecting the right config options. I'm presently working on separating pre-set configs out into separate files so we can just have configs like this laid out for custom lights and ready to go. It will be part of the next release. I don't know much about biscotti, but ideally that would be config options too. That may be unrealistic, not sure.
Anyway, what you need is just to go to fr-tk-attiny.h
Go to the trippledown layout section.
Uncomment this:
//#define ESWITCH_PIN PB3
That defines the eswitch as being on the traditional CAP pin.
Actually there should be no problem with me leaving that uncommented by default, but it wasn't. You don't need to uncomment the CAP_PIN either (if everything works right), and in fact you can use it for both.
Then go to bistro-HD.c In the top section the #define statements turn options on and off, until line 209.
then enable USE_ESWITCH. (un-comment #define USE_ESWITCH)
You will want to go down and look at the first boot options and set them how you like too. Memory is turned on by default I think which wasn't actually my intent, probably happened during testing (another reason to have custom config files).
Now comes the complicated stuff. Is it a 1S light? Does it have an LDO, a protection diode? If it's 1-S with no LDO, I would set READ_VOLTAGE_FROM_VCC and comment out READ_VOLTAGE_FROM_DIVIDER This frees up the voltage pin from complication. This only works if Vcc sees the battery voltage (minus possibly a small diode drop).
Now, what about your clicky switch? We can have it use the tk noinit method that requires no cap. gchart and I have been working on an upgrade for that in BLFA6 to address a fairly serious reliability issue. It's working there. It's not in here yet, but could be soon. You can USE OTSM, but it's not working right yet, and may never be low parasitic drain. You could use OTC actually. You would just put both a cap and a switch on the OTC pads. The switch will short the cap and bring it down. Might want a small series resistance in line with the switch to reduce the cap discharge current. I think this is a good option for now.
If you want OTSM, and you're using READ_VOLTAGE_FROM_VCC you'll want R1 to be 1/3 (no more, less is ok) of R2. And the total bleed resistance (R1+R2 is part of that, parallel to bleeder) is still a mystery. It should work with a total of 4k but there are question marks still.
If you're using READ_VOLTAGE_FROM_DIVIDER and OTSM you'll want the max divider voltage to correspond to Vcc, or maybe 5% less. If it drops too low it will trigger OTSM. In that case you'd also need to reference the ADC off Vcc and I think the option for that only exists in my un-released version.
Anyway, either enable USE_OTSM or USE_OTC, or neither to revert to the noinit method. I wouldn't go with OTSM at the moment unless you want to help fix it. Even OTC or noinit in combination with E_SWITCH are still very alpha and you should approach it that initialliy it can be a lockout and get the e-switch working. If it does more on first try, that's a bonus. These combinations were tricky to work out and still untested.
At some point maybe I can work up a config for your case and all you'll need to do is select the right config file. The danger with doing too much of this is it's more baggage to maintain if the configs all need some re-working. Oh well, if they weren't there, they'd need to be reworked too, just not by the programmer who broke them. It puts more responsibility on the development side.
Ok if I get the settings right I do need to compile the hex file
I did it one time with a narsil triple.c
But how do I get the attiny.h on the hex or MCU?
Do I only need to disable the one OTSM line or also lines like
#if define(USE OTSM) || defined(use_eswitch)?
As there is only one Bistro HD.c file in that download is it set to 3 channels?
Cross posted, see above.
You change the .h files and other configurations before you compile. These are all part of the program source. The compiler translates these instructions into two-byte machine instructions that form the hex file. So it will all be in there after you compile. But yes, you will need to compile. If you know linux, you can avoid atmel studio by using TA's compile script. I forgot to include it, but you can find it in the original TA-bistro code. It should still work. Haven't tried it in awhile though.
I should say, working with experimental features like this is probably not the best place to get your feet wet with these things, but if you're up for the challenge, it's all learnable. There's a bunch of information around here.
So If I use OTC I need to add a resistor like 1kOhms? between switch and Ground and add a 1uF OTC
Do I need to enable the lines for OTC when using this wiring?
OK i found the define to 3 channels is already enabled
I use simple 1S setup with Texas Avenger layout
Not sure what to modify to get low voltage protection with OTC working
In the .c file it says compile the fk-tk file so Its like you said just compile it
There is also a line says short medium and long press activated does that mean the light can be turned off with long press and short and medium to change modes?
I also found a line that I need to change as I am using Attiny 85? Or does it be ok when compile to set attiny 85
Also which fuses do I need to define for flashing?
I also want to change one or two modegroups as I like, where to start?
Ok, many questions...
I guess 100 ohms would be fine. 1k probably would too though, yes.
The default is setup for 1S TA. VOLTAGE_MON should already be defined, and that gets you LVP.
1S TA uses a diode so you can use READ_VOLTAGE_FROM_VCC. That's good and can simplify some other things. Also the voltage calibration should just work reasonably close out of the box then regardless what R1 and R2 you use, so it separates issues there.
Short/med/long is standard bistro. Short changes mode forward, med backward, med from first mode goes into hidden modes, long reset to first mode if memory is not enabled.
If you don't using an OTC the clicky switch will only get short and long.
You should use the 85 define if you're using an 85 yes. That's important.
The fuses are documented in the comments near the top. If you're not using OTSM you can be conservative with them in all respects.
To change modegroups go to modegroups.h and just edit them. It's pretty self-explanitory. All mode groups must end with 0. Note when setting the initial default modegroup in bistro.c, 0 means group 1. This is because C arrays count from 0 but menu flashes must start at 1 (0 flashes is hard to interpret).
So from the TA thread it's clear that you don't want off timing at all on the clicky switch. So you don't need an OTC cap. We just need to get the software to not fallback to noinit timing on the click switch. That's not hard to add, but it's not in there now. I could make it always behave like a long press, then a click off will either reset it to mode 1 or will do nothing depending on how memory is configured. However that option affects both switches.
The other two possibilities are I could just make it a separate option that just makes the click switch always do nothing (doesn't change the mode), or a separate option that just always makes the click switch come back in mode 0. (with reverse modes set this can be turbo). Then the memory option would only affect the eswitch then.
I actually need to review the code for noinit using two switches. I'm not sure it works. You can configure it for OTC (but don't need the cap) and modify this code though:
#elif defined(USE_ESWITCH)&!defined(USE_OTSM)
if(wake_count==255) { // so we had a timed out clicky press, must use OTC
// translate OTC readings to wake_count
// could simplify and do this for normal OTC too (adds a few lines, but for a simple build anyway).
uint8_t cap_val = read_otc();
if (cap_val>CAP_MED) {
wake_count=wake_count_med; // long press (>= is long)
}else if (cap_val>CAP_SHORT){
wake_count=wake_count_short; // med press
}else{
wake_count=0; // short press
#elif defined(USE_OTSM)
to
If you change it to always wake_count_med that will actually make it always a long press and it will follow the memory mode setting.
It seems clear that I should change the names of wake_count_med and wake_count_short to wake_count_med and wake_count_long, lol. There is history to this though. Whatever. The thing is these are the threshold values and in this implementation <wake_count_short is a short press and > or = is a med press.
I'm in the same boat as Lexel. Probably worse.
To me this is just part of the hobby and I want to learn how to make it work so, I'm up for the challenge.
I started a new thread and I hope you PROS can come over and school us... NovicesFirmwareGuide: learn to use existing code for your custom builds (WIP)
Merging biscotti
Ok, got around to learning what biscotti is. So it really seems likely biscotti can be merged back in with HD, and in fact I've probably mostly done it already. I started creating a "BLFA6 emulation" config, but realizing that there are many differences in BLFA6, it's become more like a BLFA6 approximation, which basically means bistro on attiny13 for nanjg layout with BLFA6 mode groups. Hey, that's more or less what biscotti is! Modegroups are now setup as separate config files that can be selected, and I've already one setup for A6 modes. It looks like the present biscotti code has a bigger mode group, but that's easy to add in too. I just need to see exactly what other options biscotti is using. Biscotti is for a single FET where BLFA6 was FET+1 but that's all just part of the config options now.
I'll need to look more. Maybe TK has stripped/simplified some code to get some of it back down to similar to BLFA6 (hmm, at least count modes is much simpler with no reverse and no hiddenmodes needed, and some other optimizations now in HD may have too much overhead to pay-off in a simplified driver). I think it's a simple matter, anyway, might be doable to get a biscotti config option in the next HD release or maybe it should be called "bistro-universe".
So I was able to get HD to configure down to a biscotti build and it fits (barely, but it's 1022 bytes, just like the real biscotti which is a little surprising).
So I went ahead and made a combinatoric makefile that can be given firmware config files, grouped by the minimum chip they can run on, and then it builds all valid combinations of hex files.
I think can say I've fully re-united the bistro family code base. I have not put in modegroup.h files for the original bistro mode definitions (done) or the original trippledown modegroups yet(done), but it's simple to do (done) and along with a configuration to match the original bistro build (done).
The Makefile works directly from Atmel studio and can be used by selecting it from the Project->Properties->Build pane. Of course, I'll have to post it up first.
At the end the makefile presently spits out this:
text data bss dec hex filename
Live child 01298C28 (sizes) PID 19451072
1022 0 34 1056 420 bistro-biscotti-attiny13.elf
1036 0 34 1070 42e bistro-biscotti-attiny25.elf
1040 0 34 1074 432 bistro-biscotti-attiny45.elf
1040 0 34 1074 432 bistro-biscotti-attiny85.elf
410 0 37 447 1bf bistro-battcheck-divider-attiny13.elf
426 0 37 463 1cf bistro-battcheck-divider-attiny25.elf
430 0 37 467 1d3 bistro-battcheck-divider-attiny45.elf
430 0 37 467 1d3 bistro-battcheck-divider-attiny85.elf
1748 0 42 1790 6fe bistro-bistro-HD-attiny25.elf
1752 0 42 1794 702 bistro-bistro-HD-attiny45.elf
1752 0 42 1794 702 bistro-bistro-HD-attiny85.elf
1732 0 41 1773 6ed bistro-TAv1OTC-attiny25.elf
1736 0 41 1777 6f1 bistro-TAv1OTC-attiny45.elf
1736 0 41 1777 6f1 bistro-TAv1OTC-attiny85.elf
1158 0 38 1196 4ac bistro-BLFA6_EMU-attiny25.elf
1162 0 38 1200 4b0 bistro-BLFA6_EMU-attiny45.elf
1162 0 38 1200 4b0 bistro-BLFA6_EMU-attiny85.elf
1696 0 38 1734 6c6 bistro-classic-attiny25.elf
1700 0 38 1738 6ca bistro-classic-attiny45.elf
1700 0 38 1738 6ca bistro-classic-attiny85.elf
1658 0 37 1695 69f bistro-trippledown-attiny25.elf
1662 0 37 1699 6a3 bistro-trippledown-attiny45.elf
1662 0 37 1699 6a3 bistro-trippledown-attiny85.elf
454 0 38 492 1ec bistro-battcheck-Vcc-attiny25.elf
458 0 38 496 1f0 bistro-battcheck-Vcc-attiny45.elf
458 0 38 496 1f0 bistro-battcheck-Vcc-attiny85.elf
So it's turning into a firmware factory. I'm not sure if there's actually any difference between the 45 and 85 versions. I guess I could diff them and see. There's no difference in the code (there is for the 25 though).
Updated: added battcheck builds to the list.
Come to think of it, actually the nice thing about having a real Makefile, is that you don't need Atmel studio at all, just the gcc-avr toolchain. This works from command line, or a batch file of course. This might simplify things for folks who struggle to get up and running with Atmel Studio, which is a bit of a pain actually for minor edits and compiling.
As Tom E made in his Narsil code, a minor change he got the function I wanted from eswitch light with forward clicky in tail
as simple he changed the startup to be on Turbo like it was in the original Klarus XT11GT light
Super. That should be a good solution for you. I'll probably look into these dual switch cases more soon though. They were the last afterthought in building HD actually. Anyway, your post and some others had me wanting to first organize things even better for many configurations. That's pretty much done. Making new configurations is relatively easier.
If you document those changes in a text file people can change the code themself as they need or add mire comments in the .c file
There's a whole bunch of comments already, more comments than code really, but almost any time I look at a code I read them and add more. I think the part of the code I pointed out to you is pretty well commented, especially being it's litterally the latest lines added to the code (that might not even remain the same), but suggestions for clarification are welcome. There can never be an instruction manual for everything anyone might want to do to a code. At some point you have to have look through the actual program lines and understand what they do. If you're not sure exactly what wake_time_med does, you press cntrl-f, type wake_time_med, and find every place it's used and see.
Anyway, this is more along the lines of something that I'll likely end up just including soon as a config option and possibly in a predefined build configuration. Most people will just use pre-configured builds or change a feature or two in the configuration. A big part of what I've done in HD is actually to make this all more clear and make the options all play well together again. Having the automated build helps keep that in control too, since the developer now sees immediately if one configuration fails to build.
I have two bugs/typos. That's good because it solves problems. One in particular may explain a bunch, certainly should break OTC in the original post. The error is
PORTB=~DDRB;
should be
PORTB|=~DDRB;
The difference is the first one disables OTC cap charging, which meant OTC builds probably didn't change modes at all, oops. I was only testing with OTSM at the end.
The other bug is
#define OPT_firstboot (EEPSIZE-1)
should be
#define OPT_firstboot (EEPSIZE-8)
could cause interference between reset toggle and muggle mode toggle. I'll probably post a bug-fix only build shortly, but I'm working on a much overhauled version with all new bugs ;) .. and need to get some of those sorted out, the ones I know about at least.
The OTC bug, may well explain the OTSM problems, as it means the OTC pin was floating, which can drain power during sleep, in random ways. It might explain it, or might not.
Well that did get the driver working properly in a normal OTC build, but it didn't solve the OTSM bug and in fact that code path wasn't relevant for OTSM. This really seems to be a hardware issue and is a mystery still.
At lexel, I've been working on a manual to go with the next release. This is a good process because it makes one think through things. I realized that actually you should get the behaviour you want just by building an e-switch only build, no OTSM or OTC enabled, preferably no off-time cap on the board. The clicking switch will obviously always "work" no matter what configuration you use. In e-switch-only, with a standard small C2 cap, the click time will always default to a long press on a full power-off.
If you don't use memory mode this means it will reset to the first mode, so you'd just want to setup the first mode as your signaling brightness. Or, you could turn on mode memory, and it will just always stay in the last mode, and you can signal in whatever brightness you want.
Normally many fast presses hit the menu, but that won't happen, because they will get interpretted as long presses. Only the e-switch will be able to access the menu.
Big new release coming soon with lots of good stuff, but I hope it's a little better tested this time (still will have much that isn't too though). I'll try to remember to include an e-switch only build for you.
Updated OP with new version.
Lots of new stuff including many build configurations (that you can pattern new ones off of) especially for all the bistro variants. Especially, it has a biscotti-HD build included with all the latest space savings and as a result some added features (specifically a more stable noinit method, and (untested) turbo timeout/bump-up, and room for you to configure in a couple more yet. More especially, at least some of it works this time. The TAv1-OTC hex and its battcheck are pretty well tested on attiny25 (everything except thermal calibration, haven't really tried to test that closely, but never messed with it much either).
I wanted to get the universal concept really flushed out and a bit more stable (many of the space savings techniques resulted in a bunch of changes to iron out) before pushing forward with advancing new features too much more, although there are some new ones.
