I actually took the first steps towards actually having a small FOUNDRY on my property, lolā¦ I have no idea what the neighbors will think, and dont really care.
and by āfoundryā? I meanā¦ I melted the aluminum, I adjusted the MELTā¦ then cast it into the approximate shape I wantedā¦ THIS resulting piece of metal? was what i started machining on, in my attempt to make a flashlight from scratch.
I know when i started fabricating with hand tools, from watching OLD LUMENS pictures of builds? I felt sort of āmachoā. When i finally had my own āhalf a millingā setup going? Felt more āmachoā. When i bought a small lathe and started to use it for more operations? I felt even more āmanlyā and āmachoā.
but THIS? good lord, I am simply walking around sweating testosteroneā¦ LMAO.
its only baby steps in the right direction? Butā¦ if i can refine the operation and build a bigger apparatus I need? I might be able to cast a WHOLE LIGHT, ten machine out the insides, such that the entire light is one solid piece of aluminumā¦ that would be no pill to sink losses, no sink to light body lossesā¦ nothng. It should be, i am hoping if i can make it workā¦ other than opening the battery compartment to swap batteries? the entire whole body from inside to outside is the one gigantic āpillā and āheatsinkā in one piece.
the āmachoā aspect of this? It is highly labor intensiveā¦ I spent about 12 hours straight, working over a raging coal fire fed air to make it hotterā¦ giant burns and blisters erupt INSTANTLY even through the heat-proof welding glovesā¦ i get sunburn in the middle of winter from red-hot molten liquid aluminumā¦ i have any number of bad cuts on my fingers from sheet metal is sharper than it looks.
i am reminded of the members name āVestureOfBloodāā¦ IE, his name means he has āinvested actual BLOODā into his own modding and working on lights?
well, whatever āspellā was completed? I bled like a stuck pig into a vat of molten aluminum, and didnt dare drop it, because 10 hours in?? i dont want to lose all that work trying to accomplish this.
PS - this is in no way ācommercially viableā, by the wayā¦ the amount of heat, the length of time, burning straight thru solid steel melt-pots in minutesā¦ re melting mistakes over and overā¦ all before any machining starts?? it is in no way a commercially viable thingā¦ i am trying this just to see what its like to do itā¦ lol
(and i am sweating testosterone all week after doing it, lol, very āmachoā work)
