Very cute!
Pretty cool mod. I am looking forward to the details on the lighted switch mod.
Bob
Actually, my plan is just to swap the regular clicky for lighted tailcap switch . I’m hoping I can just swap it in.
I’ve tried one of those, seems to make the light next mode memory by itself.
That was on a MTN Fet driver and X2R.
I recall reading sometime last week that someone had tried one of these with an H17F and it sill worked perfectly. Guess I’ll find out when it arrives.
Hope it does, would save some muckin around.
Let us know.
That’s what I am most interested in.
Bob
Now this is what I call modding.
Nice!
I like making things smaller.
I have a blue host waiting for action too, but i noticed that ring (which i think is nylon) is not as translucent as i hoped it would be…
But i couldn’t get it out, but i think a more translucent replacement / alternative ring will help a lot.
Oooh! I’m gonna need to try something like this.
Can it be shortened to say 110mm without grinding the head threads?
Whst did you do to the tailcap?
Hi Firelight, sent you a PM. Thanks.
I need to do a search on the S1 18350 version modded to take a 18500 .. I just got Two blue 18350 versions in the mail today cheap off amazon .My 18350's are pretty old and I have too many 18500's unused just layin about.
For mine I cut the front off the brass pill and replaced that with some sheet copper totaling 2.5 mm thickness. Short springs, thinner brass button spacer(.5mm) with trimmed rubber cylinder, just the optic and no lens, 101.3mm wih 16650 2.5Ahr cell.
Do you mean 18650 ?
I would really like to see some pics of yours too !
BTW, nice work OP ! THAT is modding
Nope, I mean 16650. It’s a 4.35V Sanyo cell purchased from RMM. Now that it’s done I should really update that thread. The 16650 is used since a brass sleeve is needed both to carry current through an otherwise wood tube and for strength. Since the brass fits inside the threaded tube ends it reduces available ID in some cases requiring the use of a narrower cell. K&S Precision metals makes some great thin wall brass tubing but only thicker walled stock in this diameter. I can now make my own thin wall tubing but it’s not so precise. I’ve also reamed this same tubing enough for an 18650 but it still requires the narrowest of cells. I really enjoy seeing how others do mods like the one in this thread and what different approaches to shared obstacles are used. The length of threading in the heads of S2’s is what makes the mod here possible and fuels the imagination for other mods as well.
The new short head also works with the 18350 tube with an 18350 cell inside.
However, note the gap between the head and the tube. This is because I didn’t file off the threads on the 18350 tube as much as I did on the threads on the 18650 tube. This gap wouldn’t have been there if I hadn’t accidentally slipped with the grinding bit and ended up having to shorten the head a little more than I first intended. Also, in retrospect I don’t think I should have tried to shorten the tailcap at all. If I were doing this mod again I’d fix those problems so there were no visible gaps.
As-is, I might be able to fix the gaps on the current sample, but to do so I’d need to open up a little more room inside the battery tube. I should be able to get 2mm from filing down the top of the switch retaining ring and contact post on the bottom of the driver. But to get more than that I’d have to grind the pill flatter.
Here are some pics of the light with 18350 tube (it is fully functional with either length tube):
That’s awesome. With the new pics you can really appreciate how short you made it.
Very cool mod. Thanks for sharing.
Bob
Here’s a picture of the Shortened S2+ next to an unmodified S2+
Alternate shortened Convoy S2+ host in polished bare aluminum.
I soaked the light in Greased Lightning to remove the anodizing. Then to remove the final bit of green anodizing I soaked it in Clorox bleach for 6 hours. The bleach also turned the aluminum a dull dark grey. I sanded and polished off the grey from the raised portions of the light, but left it in the cracks as much as possible as it provides a nice contrast.
