weird that there is so much variation. Still having issues since the A6 mix ups I guess.
I’ve sent EagleEye a message asking them to make an official one for their products. * fingers crossed *
Yep. As I noted at the beginning of this thread, we here can’t make a general, sweeping, “this fits that” promise to anyone else about budget parts
Because: much variation from one part to the next, even within the same product/brand. Some parts just won’t match up for some of us.
Do we feel lucky? Do we?
All this thread can promise is first hand “I have this and it fits that” information to suggest what MIGHT work for someone else.
Thanks to pilotdog68 for taking a poke at making things better (or, in this case, getting EagleEye to make things better)
I bought convoy 18350 tube to try on my EE XR2. The front fits but the tail switch part will not screw all the way on…. oh well!
Lumintop Tool … the head swaps with the Lumintop LYP365 head to make your black aluminum tool a 219B …hi-cri Nichia
At a minimum, the latest VG10 tailcap legos with the ThruNite TC12 V2. The tailcap innards swap between the caps too. Will check for other swappable parts and post some pics.
The Thorfire C8s tail cap legos with the Convoy C8, and the knurling even matches.
Jaxman E2L and Convoy S2/S2+ threads match nicely.
ThruNite TN11 tailcap fits a Convoy C8.
Indeed :
The Defiant Super Thrower, and the C2V3 26650 torch body, (both now very difficult to find) to make a 18650 or 26650 DST.
After buying a couple S41S heads in the 3/30 AliExpress sale, I thought I would try out some legoing. The Ultrafire and some generic 501's and 502's fit and work. I didn't realize until after uploading the pic that the middle one below was not all the way screwed on. Tail cap just about touches the knurling and head has a slight gap.
OdePro TM30 "legos" with Astrolux S1
HC30 Head, Eagle Eye A6 18350 Tube and HC30 Tailcap. The 18350 Tube came off a EE A6 Shorty that I got from DB. It does not work with the H03 Tailcap. It measures 2”5/8 or 66.675 total length.
Jaxman E2L Head, HC30 18650 body, Jaxman Tailcap.
HC30 and H03 Tailcaps also work but only as twistys.
This mini Headlamp fits better on the Xtar H2 Commander Head Strap.
Sofirn C8F and Convoy C8 clean version:
Hello!
Can anyone tell me does convoy’s c8 tail fits on astrolux s2 or EE X6?
I need pressure remote switch for astrolux s2 or EE x6,so i will buy one for convoy c8 if it fits!
I just checked and the tail of the C8 does not fit on EE6X…
Thank you chooma!
I think i will use universal pressure switch from BG but it replaces original 16mm switch board.
Convoy S2+ short tube on Sofirn SP32A head and tail (anodized threads upwards and non-anodizing downwards)
Sofirn SP32A tube on Convoy S2+ head and tail (works both ways works with the taller threads towards the tail)
Not sure anyone else will find this usefull, but X6 tube can fit in X7 retaining ring threads.
