New member here, visiting from r/flashlight. I’m super interested in this thing. Could I please be put down for one Q8, and could somebody point me in the right direction to figure out how the group buy stuff works? When where, how do I pay, etc.
This is the photobook album on it. No mod thread unfortunately. It's all XHP50 K2 bin, E2 tint group (2A, 2B, 2C, 2D) on 16mm Noctigons - about $140 in LED/MCPCB's:
Longtime lurker, first-time poster… found the BLF A6 on Banggood and turned me on to this forum. Finally registered so I could sub this thread, put me down for at least 1.
Still there, so hoping so . It really should not cost them much more - it's a couple pennies or less for the parts: 1 resistor, 1 or 2 SMD LEDs. I kind of prefer the aluminum/metal switches though. I find dbl-clicks, triple clicks, etc. easier to do. The one in proto #1 has that little bit of softness (like most rubber/silicone switches) to it so it takes more thumb movement and more force to engage vs. a metal switch. I prefer to have the LED indicator next to the switch so you can see the blinks when you have your thumb on the switch, but under the switch is simpler, and of course makes it easy to find the switch in the dark. The harder activation of this switch will make it less prone to accidental activation though - probably what they are thinking. The rubber switch protrudes slightly over it's trimming, but probably needs force applied just below that trimming to activate.
By the way, the switch looks like a cleaner mount in proto #2 from proto #1 - the round trimming housing the switch is more flush now.
?? Boy, hope not… Pics look real. They told us they want to send it out to us asap.
This switch was chosen because better water proofing
The light is a bonus Thorfire put in.
And they must like the beacon function a lot since they implemented it in the S70S
