What did you mod today?
Nice mod on the MCPCB Jerommel. It deserves a new led. :slight_smile:
FourSevens Mini AA Titanium
Looks really classy CRX! I read the build thread, nice.
Today I balanced the leds in the flashlight from post #2607 a bit better. The resistors are like this now:
Looks better now, but in reality what looks green is more towards lime andcwhat looks yellow is more orange.
i have been taking more steps towards casting my own aluminum stock… i am going to start a thread in the DIY on it…
A very fiddly driver spring bypass, and a rather severe grinding job on the retaining ring to increase the internal diameter:
Wired up my 219C triple…just need to attach the NTC resistor, once the silicone cures, and it’s good to go.
I wasn’t happy with the wire solder job, so I’ve since preheated the pill and resoldered the wires. It looks a bit better now.
Considering it’s my first reflow (using a clothes iron, no less…thanks lampyris!), I’m pretty damn pleased (and rather surprised) that it actually works. :smiley:
What driver did you use? Good job on the ring, I hate opening them up. The dremel and I always swap blood.
I can state success for the Narsil build with the E-switch plus forward switch
Tom E changed the code so that the light gets always in turbo mode when the battery is conected here
This is the same as it was in the Klarus XT11GT light.
the normal narsil is running on my mopdded Skilhunt H03R
also adjusted the thermal calibration, works perfectly
black and white goes to swich with indicator LED which is feed by pin 7 over a 4.7kOhms resistor
left with TA 21mm driver, on the right stock with TIR both with identical high drain cell
left 4.55A right 2.45A
Looks like one of led4powers drivers. LD-2
Yup, it’s a 12A LD-3.
Some copper tube
Thorfire VG10 quad with the new spacer from kiriba-ru I have version #1 see discussion here :
https://budgetlightforum.com/t/-/38581/721
Picture of the parts, I forgot to include the actual spacer in the photo :person_facepalming: :
The spacer and parts was a perfect fit and it all came together nicely.Setup : Nichia 219C D320 5000K and a MTN-17DDm driver with Bistro firmware.
The VG10 is build like a tank and handles the heat very well, I also have a Convoy M1 quad with the same set-up but somehow the VG10 seems more solid.
Another great spacer kit from kiriba-ru.
I bought a light off of taobao and modded it. Here’s the work I did: changed out the OP reflector to a dual stage smooth reflector (much like pflexpro’s hybrid reflector) (I had to trim the reflector shorter to fit in the light), mtn 7135+FET driver w/ Bistro, bypassed springs both driver and switch, blue tail light switch, xpl2 v5 4000k led, blue GITD led centering ring, and epoxied a magnet ring on the tail end of the light.
Finished putting my S2+ 219C triple together…again.
Learned a very important lesson in the process, if you’re soldering a Noctigon to a copper pill, check it in the host with the optics to ensure that it’s level before soldering the driver wires. :person_facepalming:
Managed to nudge one of the LEDs out of place in the re-reflow too…not my finest moment, but at least I got it back together and it’s working!
…a Jaxman E2L with 3000K 80CRI Nichia 319C’s. Not great, see a new EDC light of 2017- JAXMAN E2L - #277 by djozz
Latest ThorFire VG10 that has spacers under emitter to compensate for bad design.
Rebuilt this light using an M2 Convoy reflector left over from an M2 Quad build. While it does physically fit into the head of the VG10 with spacers removed I did have to file/sand the top of the M2 reflector for the thicker Noctigon MCPCB and reflector spacer used. Also the choice of O-ring will determine how much material need to be removed for the bezel to seat properly.
Used 20mm Noctigon with XM-L2 U4 1A and an A6 Fet driver.
If only we could compensate for all bad design in life by adding more spacers…
Eagle Eye X7 with Cree XHP50.2 5000K and this H1-A 20mm 3A 1-cell 5-Mode Boost Driver both from Kaidomain.
It’s a nice little pocket rocket, there is some tint shift in the corona, but not nearly as much as the XP-L2 in the same flashlight.
Thats a neat driver khas, Thanks.
X7 supply is getting spotty, need to get a coupe more. I like that light a lot.
Now that I’m playing with UV leds a lot…I hacked a few highlighter markers into a beautiful set of UV reactive ink today.
…that counts right?
Wow! That’s pretty neat Valor. I didn’t even know hilighter ink did that.
Very impressive picture. :sunglasses:
