Is it just me or are the pictures in the OP gone?
gone for me too.
Yep , gone …
Fixed them last week and but it didn’t work …
I’ll fix them today , sorry…
Really disappointed with my UT01 and with Gearbest. I ordered and received the NW version. This could be a great light but mine came with the faulty switch, multiple presses and sometimes it works sometimes it doesn’t. Contacted gearbest about the faulty switch, they asked for a video but their site will only let you upload 2mb so not sure how that would work, I pointed them to a youtube video with a light with the same issue. Their offered solution was to either a $3 store credit, or a $3 refund. Still working with them on that. I also have a cool white version on the way, I hope it has a functional switch.
Hopefully they will resolve your switch issue promptly. It is a known problem.
I too am very disappointed with GearWorst. I ordered mine on February 13th. It arrived in the US on February, 23rd and hasn’t moved since. When I emailed them last week they replied with their canned response saying 30-35 days for delivery.
I have ordered from them many times in the past without issue. I was going to order a few headlamps and some other things but not now; not until this is resolved.
Saving $10.00 isn’t worth the aggravation.
Bob
Mine also had a faulty switch, worked fine for the first couple days but then it became a lottery whether it worked or not. Try making your own video showing your own faulty torch and upload it to youtube. I did that and gearbest gave me some full refund options (I chose store credit refund + extra points and kept the torch).
While I received mine without the switch issues, reading all the problems here makes me worried that it’ll die soon.
Loved the form factor though, and since I have a few 15400 batts around doing nothing I went ahead and ordered mine.
I highly doubt it. Switches are usually good or wonky or bad from the getgo. If it works perfectly first day or two…, it’s usually good to go.
Good to know, thanks!
I have to say i am quite pleaced/surpriced too with that tiny torch, and lately i havent been surpriced …
Great job they did realy, finaly somethign better than Olight S15…adn its quite easy moddable too
The cool white tint is lovely, white with a pink tint- the AA output is quite decent
It is my edc flashlight for over 3 months now. I modded mine with an xp-l hi v2 3b , and I’m very pleased …
Still works perfect and puts out some sweet light
I may have to do that as well.
I ordered a NW version and it is just much to yellow for me. Otherwise it is a great light.
Bob
Where do you guys get your xp-l hi v2 3b? Also what soldering tip do you use to solder/desolder the +/- wire on the mcpcb?
The xp-l hi v2 3b i think it was from my Blf X5 …
I use a bevel tip (hoof tip) for soldering wires in deep flashlights like the C8 , and chisel tip for smaller flashlights etc .
since i replace the fauly switch, it’s become one of my fav lights
honestly i can’t expect anything else from it at its price, many mode, hidden mode, work with both nimh and 14500
i will compare it with my arriving jetbeam e10r
Sorry if I missed it, but can the switch be easily fixed or not?
Thanks
Thanks
First , make sure switch is damaged . It could just be the driver misplaced , and you can easily check this by removing the tube and moving the driver a little right/left and see if the switch works .
If switch is damaged , you have to remove driver / desolder switch and solder another one .
The hardest part is finding the right switch
Replacing a switch is easy(quite tricky for new people)
The right switch - type TL3340.
Looking forward to your comparison and opinion of the JB E10R
