Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
Please include me in as well
OP updated with:
Prototype 2:
looking sharp
better LED alignment
do we see cell polarity protection?
double springs!
HYPE
Awesome!!! Hope it’s as good as it looks… :wink:
crosses fingers that everything works as it should
I’m hoping that I’m seeing the light at the end of the tunnel. (pun intended)
OK, that proto 2 is VERY nice! :money_mouth_face:
So the lit switch is still happening?
Still there, so hoping so . It really should not cost them much more - it's a couple pennies or less for the parts: 1 resistor, 1 or 2 SMD LEDs. I kind of prefer the aluminum/metal switches though. I find dbl-clicks, triple clicks, etc. easier to do. The one in proto #1 has that little bit of softness (like most rubber/silicone switches) to it so it takes more thumb movement and more force to engage vs. a metal switch. I prefer to have the LED indicator next to the switch so you can see the blinks when you have your thumb on the switch, but under the switch is simpler, and of course makes it easy to find the switch in the dark. The harder activation of this switch will make it less prone to accidental activation though - probably what they are thinking. The rubber switch protrudes slightly over it's trimming, but probably needs force applied just below that trimming to activate.
By the way, the switch looks like a cleaner mount in proto #2 from proto #1 - the round trimming housing the switch is more flush now.
?? Boy, hope not… Pics look real. They told us they want to send it out to us asap.
Sorry, haven’t read all 171 pages, is there an ETA on this or is it just as soon as it’s ready…
This switch was chosen because better water proofing
The light is a bonus Thorfire put in.
And they must like the beacon function a lot since they implemented it in the S70S
Hype, certainly hope not.
Ahh true - forgot bout the water-proofing advantage.
No ETA. It’s just as soon as it’s ready…
Yes exactly :wink:
OH MYYYY! She's a beauty. Congrats Q8 development team. That looks like a real winner.
Please add me to the interest list for 1.
Thanks.
Ford Prefect
I have a question about the size. I know, I could do a bunch of research myself and find the answer, but maybe somebody could answer it easily and save me lots of trouble. Compared to “standard” sized SRK style lights, is the head of the Q8 a larger diameter, or the tube smaller diameter, or both? Because SRK’s are tube style, meaning there is not a head that is bigger than the body, rather all is the same diameter (Edit: or very nearly the same). I like the look of the Q8, so this isn’t a complaint. I’m just curious about the proportional size(s).
The head diam. matches a few SRK clones I have, so the head diam is definitely standard. As far as the battery tube goes, it's probably narrower because the classic SRK has these machined railings along the body with holes to secure a lanyard on. Those are eliminated in this design. If you look around though (like on eBay), the "new style SRK" looks very similar to the Q8, in that the battery tube is void of railings and has knurling. I like the new knurling style, both for looks and feel. Dunno who came first - the Q8 or this new style. I posted pics of my gold 12X SRK a while with the new styling:
Clearly on this one, the head is wider than the body/tube, but pretty sure the head diam on this one is also std size.
Here's another comparative shot:
Yes we took the widest finned of SRKs
But instead of just a few fins and then a narrower head the width of the Q8 head stays fatter to accommodate more mass and fins thus better cooling.
Okay, I guess I was just showing my ignorance. :person_facepalming:
Thanks for the explanations and pictures. :+1:
Nice! What is the estimated lumen output for Q8?
