From off, just hold your power switch down and count to ten or less. It will blink once or it will blink twice depending on which mode driver is in. This is how you get between program mode and regular modes.
You want to see two blinks to enter program mode. Once there then do the double click and cycle through to adjust Low, Med, High, Turbo
There was one time I tried to re-program mine with a fairly depleted NiMH and it would not program. I forget exactly what it did though. I useda fully charged 14500 and it worked just I describe above. So, with a fully charged and healthy NiMH it should work just the same as a 14500.
I believe it was cloned, not built by Manker. Although some of them seem to have the Manker brand on the internal components.
I have Xtar 14500 in mine and they fit fine. I haven’t tested run times. Mine had the bad switch also, the only thing gearbest would offer to do was a 50% refund, that was after they first offered a $3 refund.
Yes this works for me. Except I don’t think I’ve accessed the battery check.
So this method works with NiMH cell, at least to re-program the levels.
I was unable to discern any variation in the highest level though.
Still no Xtar 14500 batteries arrived. The flashlight arrived from China quicker than this.
The NIMH will not show variation in the highest level in my sample also. Normal, I should think, as the NIMH is probably not quite capable of the highet Turbo amperage that the driver demands. So it falls slightly short in that capacity.
However, the 14500’s should give you the flawless mode performance we all desire.
ETA: The programing modes are in this order. Strobe, sos, beacon, full turbo, battery check, and LMHT adjust mode. Full battery in battery check mode will give you 4 blinks. As battery discharges =’s fewer blinks etc
Most NIMH batteries do not provide the amps needed. I tried a few and the only ones of mine that work fine are eneloop (the white ones with blue printed name on it).
Yeah that’s what I thought too. Apparently returning a defective item for a refund is not an option either, at least not one they offered me. I may try and get the credit back through paypal instead.
Thats a sign of a depleted or well-used NiMH… that can’t deliver enough voltage under heavy load. On my lights there is a slight but noticeable difference between turbo and my next highest level. Its most visible on a ceiling bounce or outdoors. But then again, it needs a fully charged / healthy eneloop to achieve this.
My UT01 just arrived, and it’s very impressive for 1xAA. I really like the mode selection and it’s enormously bright on high even with just a AA. I ordered a 14500, so I’ll let you guys know how that works out when it arrives.
