The problem I am having is that all of the cells seem to have to same voltage. Why? Because the higher voltage cells seem to lend their voltage to the weaker cells until they all balance out. All the cells show the exact same voltage regardless.
When I charge it then stop charging, it will keep dropping in voltage until it finally settles back at around 16.65v
But since it’s 12 x 1.2v cells, it should charge to and hold around 17.4v (which is actually about a 1.2v difference btw)
Taking the battery pack apart and resoldering it would be a major task.
Are you certain it’s possible to test individual cells that are in series?
So did you measure each cell voltage or not? It is possible to do this; just put your volt meter across a cell and it will measure its and only its voltage.
If you have just measured the pack voltage, 16.65V/12=1.388V seems like it could be a reasonable value for each cell. You might not actually have a bad cell.
How old is the pack and what sort of use has it seen? If all cells measure exactly the same voltage it’s a really good pack! It may just be that the cells are a little worn, or possibly that the charging current could be higher. What’s the capacity of the pack and at what current do you charge? With high drain NiMH, you need to charge at least at 1C.
Yes. Several times. They all measure within .01v of each other.
The voltage has dropped to 16.45 since about 2:00 this afternoon.
So 1.371v per cell now.
This is what I keep hearing….and all the batteries have almost the exact same voltage. I just thought it was because the better cells with higher voltage were pulling up the voltage of the weaker batterie(s) while the weaker batteries were pulling down the better batteries….making the whole pack SEEM like all the batteries had the same voltage.
Guess I need to study series battery connection science a bit more huh?
I know! See, you nailed it!
My thinking was…this is suspicious if ALL the batteries in a 12 pack had the exact same voltage….and pretty much they do!
These are sub C cells. Like $2.00 per cell. The claimed capacity is 3000mAh. (Probably less than half that in reality)
The pack has been used about 10 times and I just received the batteries about a month ago.
I charge them at ~400mA and ~17 - 18v using a CC/CV DC power supply.
Should I be using different charge settings?
Shouldn’t this pack be settling on full charge at about 1.42v x 12 = 17.04v ?
And your avatar……is that your pet or just an internet photo?
$2 per cell is suspiciously cheap so i wouldn’t be surprised if internal resistance is relatively high. (Years ago, decent sub Cs were $5ish each.) Fresh off the charger, a fully charged cell will be between 1.40V-1.45V however, the voltage drops a little initially. Mine (AAs) would settle at ~1.39V in a couple hours. 400mA charge current is low. A 1C charge current would be 3A for that pack. I can’t remember the correct way but do know that they are not changed the same way as LiIon chemistry ie CC/CV. Weather this is a factor in underperformance or not, I’m not sure.
Even after additional charging, the pack always seem to eventually settle back down to 16.45v total pack voltage.
So it seems 1.371v is their max charge capacity.
I also re-checked each cell and found each cell to measure 1.37v
Thanks to everyone for their help and advice. Great forum!
I think one thing I’ve learned is always check the batteries individually when I receive them BEFORE making a pack out of them.
Also learned a lot about testing batteries in a series pack.
I think these cleaning tools are the only things that take such a cell configuration and voltage.
Usually you will get the best battery longevity by unplugging the charger right after the light goes off. It seems if the battery lasts more than 18 months before starting to rapidly decline, you are lucky. I don’t know why Lithium cells are not standard in equipment like this. Maybe they don’t want the tool to last too long so they can sell you a new one every so often.
Did you build this pack yourself to replace one that failed? If so where did you get the cells?
Yes, I built the battery pack because we had a brand new one in storage but the battery was kaput.
The batteries were bought on ebay. (I know…bad place to get batteries)
I’ve never seen the green “full charge” light. I don’t think this battery pack reaches a high enough voltage to trip the green “full charge” light so I time it and then check the voltage.
Maybe they don’t use lithium cells due to the risk of fire?
