Maybe a tad wider and thicker retainer ring?? I know it’s not that big a deal as is,
By the way Rey, just before you went on Holiday in Jan. you sent me some new drivers etc. are these what is talked about as the New 9 hz Driver or have I missed or misunderstood something, as usual…?
Might as well embarrass myself, but I am curious about the drivers you sent me in Jan. as I don’t recall what sort of voltage they can handle max. I have however found out how much they can’t handle, accidentally.
I Lego’d 2 pineapps together and was going to drop in some Eneloops but grabbed the 14500’s instead, wasn’t paying attention, Of Course :confounded: , well end of that story,
One other quick question while at it, Are you really considering a Version 2 of the Ti X6.?
Saw a poll and that was listed and really caught my attention,
I have your V1 and is my most prized light and would love to see and own a Ver. 2 so very very much,
I could only imagine what a Ti-X6 V.2 would look like if made today, with how much your skills have developed since that light was designed and built and now?
It would be an unbelievable light I am positive but maybe some rings around the tail-cap this time, instead of smooth, a crenelated bezel, hum sounds good to me anyhow… ha
Thanks Rey…!
Maybe making the tail end thread a tad shorter.
So that not using the clip doesn’t leave a gap…
RCR123/16340 version, please
Production can be finished next weekend. MD requested a sample before setting up the GB. This could take about another 5 days.
That’s the best I’m expecting.
@T18 PM sent about the driver. and YES, I’m wanting to make a upgraded version of Triple Ti I and Ti II (X6)
Back then I was not so experienced with the production. I really want to correct the mistakes, and make some better lights.
@Meich Yes, it is awesome. I’m also thinking to remove the hole for strip. Someone complained that it pokes the palm a little.
Maybe make a clip with 2 screws, which makes it higher class IMO.
@lumenzilla RCR123/16340 and even 18650, it will be on the waiting list.
Thank you guys.
Definitively classier - but not really good for those who don’t want a clip at all.
The new clip does look nice, However please make it so the light still stops rolling quickly
The anti-roll affect of the existing lanyard hole is important on a light this heavy
I would still vote for the the thru hole clip.
I never use clips on lights this small. Pineapple looks much better with no clip and no clip holes IMO.
Any updated info about the reflectors from the current stock at Banggood? Since i ordered a pineapple from them yesterday…
They have the 1st old batch. Got your pm and already replied.
Need a longer, stronger clip. Not that one. Too short and too weak.
Great, I can hardly wait
Gimme the Ti-lan please. This one is perfect with the upgraded reflector. Just give an option without any hidden carnival modes ;). Mine. Moonlight-low-med-high-(turbo). comes on in low or med. PWM doesn’t matter as long as the frequency is high enough for the PWM-Taliban not able to detect it without camera settings etc ;). CRI doesn’t matter much on this kins of light as long as it isn’t obviously reddish (mistaken by some for “high CRI”, the CRI Taliban). Just 5000-5500 proper “natural white” LED please.
What about a clip like the Lumintop Woorm 4th?
https://www.google.de/search?q=lumintop+worm+4.0
It would fit well
My Pineapple doesn’t work with Olight’s 14450.
Tried wire jumper and it worked.
My suspicion is something about springs on its tailcap, will investigate it later after office hours.
Please kindly update.
Olight’s batteries are protected as far as I know. The Olight 14500 might be too long for the pineapple. Try a standard non-protected 14500
It is designed to take both protected and unprotected, as long as it is less than 52.5mm. Most protected batteries are 52mm.
