Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17127 posts / 0 new
teacher
teacher's picture
Last seen: 27 min 6 sec ago
tatasal wrote:
Let’s assume the price is even made higher by $5 just to have ‘higher’ quality control, will it have the assurance of avoiding ala Cometa fiasco?
Good question. The Cometa was somewhat a “bait & switch”.
In that “group buy” gone bad was an unknown with the screen name “Cyberescudo” who was supposedly in charge. Then when it all turned to crap that person was a ghost. Facepalm … No responses for the most part & about ZERO support in finding a solution. For all we know it was a “setup” from the word go by this person.
What we do have going for us in this group buy is The Miller, an upstanding, outstanding, & long standing member!
He has been upfront & transparent about everything pertaining to this group buy. He has a meticulous OP & has kept it meticulously updated as well.
As far as all that goes I personally do not see how he could have done more.
It has been and is continuing go be….. stellar. Thumbs Up
In the very, very, very, very extremely unlikely case that this GB did somehow turn to ‘shite’, I DO NOT think The Miller would run & hide as the ‘Cyberescudo’ person did in the Cometa disaster. I think he would be leading the charge to make things right. Thumbs Up
The Miller & the way he has handled this whole Q8 project is why I personally trust it 100%.
Having a second set of “trained eyes” look at the Q8 takes nothing away from what I have said above or from anyone else. Many times a second set of eyes will see something the first did not. This applies to anything, not just this light.
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
Theodore41
Last seen: 3 hours 37 min ago
I like my Cometa very much.It is a very good light,with a good throw of 164Kcd with the original Jaxman aspherical lens which I have put on.
djozz
djozz's picture
Last seen: 20 hours 19 min ago
In my opinion, The Miller can not be demanded to make things right if this turns out to be a failure, all members of the Q8 team are thousands of miles away from where the Q8 is designed and produced, all communication is remote. There is only so much we can make happen from a distance. On top of that it is and must stay hobby for us all. I’m sure if failure occurs, he and we will do our best to turn it around into a succes, but if the effort becomes too large we will just have to accept the failure and move on.
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
teacher
teacher's picture
Of course The Miller would not be responsible for failure or “making it right”.
As far as I am concerned he has done & is doing everything that is humanly possible to avoid a “failure”.
What more could he possibly do??
Nothing as far as I am concerned……. Smile
teacher
teacher's picture
That is not the point. The Cometa was not as promised. It was a “bait & switch”.
I like mine Ok also…… after I reworked it.
fixed it
Last seen: 21 hours 15 min ago
The Miller wrote:
About this test
I was thinking a full ramp up and down.
Would be more then any groupbuy before and mean driver, LEDs, retainer ring are all mounted correctly and there is contact.
I don’t think we can ask for more or longer tests
Again building lights is what Thorfire does and they know good execution is important.
I agree that seems reasonable. Perhaps a hold it a few seconds on max to stress any really weak solder or component (if that’s any use, I’m really not sure). Then again, it’s unlikely all lights will be tested with fresh cells.
And yes, this isn’t Thorfire’s first light. The one I have from them is built just fine so I suspect they do know what they’re doing and don’t need to be bugged about every little detail.
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 59 min ago
It may not sound like much, but a quick smoke test goes a long way. Usually it’s a metaphor, but in this case it might literally be checking if smoke comes out. Smile
In any case, if we can get a basic “does it turn on?” test before shipping, that would put the Q8 leagues ahead of previous BLF projects. And if not, it’ll probably still be okay most of the time.
sac02
sac02's picture
fixed it wrote:
… … so I suspect they do know what they’re doing and don’t need to be bugged about every little detail.
You don’t work in QC, do you? Silly
It’s like baby-sitting 50 year olds. You would not expect Fortune 1000 companies to need that level of oversight, but they do. Small suppliers/manufacturers are sometimes very good, but often much worse.
DB Custom
DB Custom's picture
Last seen: 2 hours 12 min ago
With several hundred lights having come to me either by my own order or as a mod host I can say very few of them have had any real issues as made by the manufacturer. The HD2010 I got once upon a time was probably what started me into modding, not working right out of the box. This was an exception to the rule and I’ve seen very few lights come in that condition. So as long as Thorfire cares about their rep they won’t do slop and careless assembly. That all falls on them and there’s not much we can say other than it will not be accepted.
If indeed they turn each light on and make sure it functions then we will be in the “Good”. Wink
Jos, I think I may need to lower the reflector a bit… 20ga leads are too thick in the Silicone wrap variety so it might take some Teflon wires that are thinner. I’ll flesh it out and see how that changes things, could only be better. Smile
As far as QC goes, I’ve personally built hundreds of drivers… usually one at a time. I built an FET driver for my 5th scratch built light and danged if it would not work! Everything was on it correctly, everything tested, it got re-flashed and re-reflowed, nada. So I built another just like it and this one is perfect. Sometimes things just happen. The turn on and ramp up/down will show any such lemon and reject it back to the assembly line.
Dale
The Miller
The Miller's picture
OK let’s just look back a little
Almost all groupbuy projects result in darg fine lights.
Below is result of own conclusions, reading between lines and direct communication;
what is it, 4th run of nichia 348? taught me: make sure the proto is right before giving the OK. This may take several tries but when proto is good production should work out fine.
hugely successful A01 in several colors and copper at outstanding price, taught me: be honest and don’t get discouraged by what sometimes can feel like a clubbing by critical BLFers who want so much and specifically what hey feel is very important.
X5/X6 hugely successful taught me:
Don’t get commercially involved so you can stay in between manufacturer/vendor and BLF being on both sides. Don’t be nasty and don’t patronize real concerns.
Don’t over inflate expectations.
(Special note Toykeeper taught me, do your best and don’t feel personally responsible if manufacturer or vendor makes a mistake, girl you made it hard on yourself ;).)
Cometa (took me pages and pages of PMs to finally get to the bottom of that, no bait and switch, a proto was OKed that was not OK, simple, the OK giver didn’t even had a Z1 so could not know if proton was as desired.
Again a solid proto is key.
Also when it went wrong vanishing was a bad move.
Again, we have a different situation then being a customer ordering a batch of special things. We work with a professional party who knows good execution is important.
Yes communication is slow and tedious but most important there is good will.
It is important to understand BLf is a hard crowd to please, TF was not that keen on doing it, Jaxman took a lot of persuasion to make hosts available.
Dealing with us low price asking, nitpicking, coupon asking, flaw seeing and naming, in great detail disassembling and thus secret revealing, bunch is no pick nick Wink yet we bring lots of good to the table so still things happen.
Speed4goal
Last seen: 18 hours 40 min ago
Good post miller, you’ve done a great job on this project and I have no doubt my q8 will be perfect along with the others. Even a 1% failure rate would be acceptable in my opinion thorfire seems to care about their reputation on here and takes care of their customers. And finds a solution both parties are happy with. And they don’t overcharge for lights. Like the thorfire s70s was on sale for like 37-38$ shipped a couple weeks back 4000 lumens for $40 just like this light 4,000+ for $40. So they are still making out good building this for us. If the s70 still make enough profit at $40 this does to. And is soon as this is released they are making 40+ grand in a matter of 48 hours. Not to mention what the next couple years of sales brings probably with a higher price
Unlike the manufscter of the cometa, what basically happened there the prototype they sent out had all the right parts. Then when it went to production all inferior parts were used. And nothing like the sample lights sent out. Still to this day I avoid manker. They can’t seem to design a light without a lot of problems and ask to much for it. Light after light major issues. Name brand and contracted builds. And not the best support when issues arrise. But what makes the most mad. Is they cone on here with threads asking for blf members input and help with a design or things for a light. Build it and turn around and refuse to do a group buy for BlF when the community held their hand and basically built the light for them. Ok rant over now, sorry just gets me mad they screwed over so many members and didn’t even offer lube.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
DB Custom
DB Custom's picture
Since we’re all sitting and waiting anyway, replacing 20Ga Turnigy wires with 20Ga Teflon wires cost me more than 2A and 600 lumens. I got the reflector seated about 1mm deeper, which is all the centering rings in stock form are allowing. I found it interesting though that the teflon wires lost current, would have thought it’d be the other way around.
Dale
sac02
sac02's picture
Wow, that’s a lot. Maybe it’s not teflon vs silicone, but rather that the particular brand of teflon wire you’ve got just isn’t as high quality as the silicone wire? Smaller gauge wire sold as thicker gauge is way too common, as I’m sure you are aware. If you have a decent length of wire, you can figure out what the actual resistance of the wire is either by measuring it directly, or running a current through it and calculating.
DB Custom
DB Custom's picture
Sure seems to me that Justin (Old Lumens) had tested the Teflon wires on a big triple build and found they carried more current. There’s a pita to work with for sure, even stripping the Teflon off is a chore before you start soldering. Tough stuff, but such thick stout wires they can rip pads off a driver if you aren’t careful. I’ve had this Teflon wire for a couple of years, very seldom use it due to the stiffness. Not sure if it’s quality wire or not. The wire inside the Teflon is pre tinned, seems like each individual wire is silver coated, they’re not all soldered together. Seems odd to me.
Be nice to have a purpose built driver like the Q8 for the multiple emitters, I’m cramming triple wires on a single pad!
I had to inset the switch assembly deeper to facilitate button presses and the internal threads are shy of allowing the retaining ring to seat on the pcb the switch is on so I just picked up something to make it work, turns out to be a threaded piece of Titanium I’m using for that spacer. Probably losing a bit there, need to either re-cut the threads or make a copper spacer for maximum current path. That would matter on the lumens test, not at all on the amperage test as I’m doing that with the tail cap off.
With the reflector filed I might have room for 18ga leads, but then I’d have to drill the copper again for clearance for larger wires. Emitter mcpcb’s are glued in with Arctic Silver, so that’d get risky. Always something. Build a light from scratch then start modding it for mo powah! Hahahahahahaha
Dale
DB Custom
DB Custom's picture
Copper, love it and hate it. Replaced the Ti spacer with copper and am up to 9860 lumens. That’s the love part. Had a spacer finished and was parting it off when it, at the last possible second, flipped over and jammed into the parting tool bending it up like a smashed pretzel and shutting the 1 HP motor down solid. UGH! Started over. What else can ya do, right?
Anyway, the 20700B isn’t a top discharge cell so it’ll be interesting to see, like Tom has found in testing the Q8, just what cell works best. For those that don’t have a lot of lights to play with, it can be crazy finding the top performing cell… sometimes it’s not the one you expect!
Edit: With freshly charged 20700B cells I’m now seeing 10,448 lumens from the 3 XHP-50.2’s. That’s 10,005 lumens at 30 seconds. Doing something right somewhere.
Dale
teacher
teacher's picture
Tom E wrote:
What teacher is say’n is, at least used to be, quite common in the industry. Always helps to have someone there look’n over their shoulders.
Shocked … Tom E, is that the first endorsement of the “Send Teacher to China” campaign I am waging? Shocked …. Thumbs UpSilly
“Smoke Test”……….. I like that…. metaphor or not. As well as everything else you stated. Thumbs Up
The Miller, I pretty much agree with everything you say here except some of the Cometa statements.
I think the Cometa was a “bait and switch” for sure. It still, as of this writing; says in the OP of the first Cometa offering thread it was to be a “JAX Z1 host”. Here are a few lines about that copied and pasted below.
  • Original message:
    Hello to everyone, i am Cyberescudo a member of CPFItalia Forum.
    In collaboration with Banggood we have created a custom flashlight on Jax Z1 host with many upgrades including the FET + 7135 driver designed by BLF members.
    The name of the flashlight will be COMETA (the italian traslation of comet )
But, no use arguing about that and the how and why of it.
I call it tomāto, you call it tomăto. Wink
Either way the outcome was the same, a sad disaster of a fiasco.
And the saddest thing of it all, “to me”; was this ‘Cyberescudo’ person crawling in a hole & disappearing. Mistakes happen, but the disappearing act was deliberate… for whatever reason.
Which brings us to present time………. Smile
To date, it is impressive how “you and the Team” have handled this Q8 project. That is the bottom line for me.
Yes, even on the tightest run ship or manufacturing floor there will be some “lemons”. That cannot be helped no matter how tight the standards are… it is just the way it is. That is a given, whether it be lights, cars, dishes, do-nuts, or the space shuttle. Things can and do go wrong at times.
Personally, I think you & the team have done & are doing everything possible to keep manufacturing problems with this light to a minimum. But as has been stated aptly previously, there is just so much that can be done short of actually being there in person to see and check the production. That, in reality is not really an option. (unless of course you endorse the “Send ‘teacher’ to China” campaign, as hopefully Tom E has. Wink .. )
Aside from that, you all are doing all you can do to make this a success. Thumbs Up
If it were to go bad, which I doubt & can’t even imagine; it goes without saying it would be none of yours fault.
It would just be the breaks of the game……. simple as that.
Life would continue……….. Smile
I don’t see that happening, partly because of the things you stated above and then being able to see the way this whole Q8 project has been handled from the start. You all have been on top of it in a steady and methodical manner. No rushing, no taking shortcuts, no nothing except focusing on the task. Thumbs Up
I personally hope at least one other set of eyes trained in manufacturing examines the final Prototype. I just think two or three sets of eyes might spot something undetected. I have seen it happen to many times in other fields & instances. Something missed by one but all to obvious to another. Which is not to say that the first person missed something, not at all, But everyone looks differently at things and something may stand out to one that did not to another.
BUT, that is simply my opinion. Whatever is decided works for me. Thumbs UpSmile
Thanks again to you & the team for the manner in which this has been & is being handled. Smile
DB Custom
DB Custom's picture
Tried a pair of Sony VTC6 in the DBC-05 Triple, they give 21.12A on a rested pair at 4.13V. That’s good for 11, 696 lumens from the 3 XHP-50.2’s. I’ll see if I can get my hands on a pair of VTC5A’s…
The C6’s are some serious 18650’s to be sure.
The 50.2’s, adjusted in respect to the reflector, are showing just a hint of a spot in the center, with the cross radiating out from center on all 3 as situated. Probably more to do with this reflector than anything, but I’d say they’re capable and it may well be interesting to see what 4 of em would do in the Q8.
Dale
Tom E
Tom E's picture
Last seen: 1 day 3 hours ago
Here's the pics of the VTC5A test:
Updated:
SawMaster
Last seen: 7 months 1 week ago
Careful there young man- a lost workpiece is how I killed the mainshaft my hobby lathe Sad A 1/4 horse motor and loose belt drive was still powerful enough to cause damage, especially to my ego.
I think we’re on the right path with the Q8, and if anything were to be added at this point a full up/down ramping test might be asked for and gotten. Since they’re 100% testing anyway that’s only a few seconds more per light, right? Even when multiplied by 1000+ pieces it doesn’t seem unreasonable and it should go a long way to eliminating any possible DOA’s which will be very helpful on both ends of the deal.
Can’t compare this to other GB’s, the approach is entirely different because of the issues some of those had which have been analyzed and protected against much better here. That which can be done within reason is being done. The only thing I can see which could make a significant improvement is if there were someone who could bridge the language barrier better for us, but given electronic and engineering terminology that is a hope which will likely go unanswered.
Keep up the excellent work folks Big Smile
Phil
DB Custom
DB Custom's picture
I saw a place listing on a new Wuben light at Amazon that says Every light is 100% tested before being shipped. So maybe the idea is catching on. Wink
Young, not so much, careful, well I thought I was! 1HP, jammed to an immediate stop! Left hand went immediately for the kill switch. On another occasion, the entire head came out of the chuck when boring the driver bay deeper with the 7/32” holes for wires already in place in the thick chunk of copper, making for an interrupted cut on the boring tool. Left hand went for the kill switch, right hand went for the flying head… caught the head before it could hit concrete but missed the kill switch which didn’t really matter at that point as it was spinning freely. Big WHEW! on the catch and save! lol
Have to agree that a Mandarin speaking BLF’er that had the time and inclination to act as go between would be an ideal situation, but everything else is being handled as well as possible from what I can see. Other group buys have pretty much been on existing lights, this is ground breaking in the creation of a new species. Smile And the power level is also head and shoulders above what’s been accomplished before, another level to the new species chain. Gotta love it!
Dale
teacher
teacher's picture
Phil
I totally agree Phil… Thumbs Up
That is why I am waging the “Send ‘teacher’ to China” campaign.
A totally selfless endeavor (for the most part… Wink .. ) on my behalf to be present as a liaison at TF in China when these are produced. To insure, my very own feet on the ground there; that all goes as smooth as a baby’s butt with the Q8 production.
I even have a Passport, engineering drawing skills, blueprint skills – both drawing & reading, some machining knowledge & experience, and I am very fluent in using pictures – drawings – facial expressions – sign language – grunts & other guttural sounds to communicate.
And the best of all……….. I know Kung Fu, as well as a few other Chinese words.
What more could we ask for???? I’d be a natural……….;)
So come on man….. get behind this “selfless” campaign of mine and support it.
Wink
DB Custom
DB Custom's picture
Hahahahaha, Teacher, you probably know General Tsao and his chicken army too! Smile We could end up with little packets of soy sauce and concentrated chili pepper oil in the square to-go box our lights come in… Silly
Dale
teacher
teacher's picture
No sir, I would throw all the “concentrated chili pepper oil” in the trash immediately and eat the food (illustrated below) with the soy sauce on it. Wink
Nothing but Prime, Pristine, & Working Q8’s…. along with English instructions and appropriate spare parts bag would be shipped to your door. Wink
DB Custom
DB Custom's picture
Dangit! Now I’m hungry! Silly
<—- heading for Dynasty to hit the buffet for all-you-can-eat General Tsao’s chicken. Big Smile
Dale
teacher
teacher's picture
I am too, I think I am gonna hit the buffet here in a bit…… in preparation ya’ know. Wink
fuzun
Last seen: 55 min 2 sec ago
I want this really bad. Great project! Any estimate date for release? Also consider a zoomable version if possible Smile
The Miller
Let’s see how proto V2 is first Wink
Great fun getting a Uniquefire 1504 lens and a srk to play a bit
Not really a beam pattern to aim for though Smile
samnavy
Last seen: 6 days 11 hours ago
Captain Morgan and I have been telling tales all afternoon, so let me pontificate.
The average guy doesn’t have a clue about flashlights… especially if they grew up thinking Dads trusty 2D Maglite was “really bright”. I love whipping out my EagleTac D25C to one of my unsuspecting “gear guy” buddies and throwing down 700lm from a torch the size of a Chapstick. Bewilderment followed by disgust followed by envy followed by, “Where can I get one?”
I’ve got some other lights that have some “wow” factor, but I don’t think I’m really ready for sparking up 6000lm. My brain just isn’t able to get there. It’ll be like learning that I’m strong with the Force… that some Heavenly power to bring illumination to the depths of the Universe resides under my thumb… even Jesus took some time to find his groove.
And I have a feeling that when I’m not gonna be able to own just one… and that when I reveal the pricepoint to my before-mentioned “gear guy” friends, we will test the limits of the Chinese postal system.
Profound thanks to all who are making this happen, take as long as is needed to get it right… but remember that I’m freaking dying out here right now without one.
DB Custom
DB Custom's picture
Sam, you an the Cap’n just carry on with the pontification while these lights are being perfected, once you see it you won’t believe it anyway. I mean, when level 3 or 4 lights up the room with ceiling bounce you’re gonna be trippin. When level 5 and 6 blow forceful illumination you’ll be drooling yourself, but when you finally reach Turbo you’ll hear the Nirvana Choir kick in with the Angelic rythm’s that will certify you a complete and total flashaholic to the core.
Yes, I know, default is ramping, but you’ll be tempted to ease into it and creep your way up to Turbo, when all along it’s a quick double tap away from off… once you experience it and learn the rythm of it, you’ll delight in showing your buds the low mode then blasting them with an eye searing Turbo and hearing their quick intake of breath as they too delve into the depths of flashaholism.
Just remember, bear it and share it my friend, bear it and share it. Wink Welcome aboard! Big Smile
Dale
DB Custom
DB Custom's picture
Oh yeah, for the record Sam, the little EagTac D25C is capable of 1300 lumens like the Titanium version I just modded for my buddy. Wink
Dale
