18650 for c8 convoy
G’day all I need some advice on the c8 I have in the mail . now before it gets here I wold like to get some batteries
for it and have read that the protected cells won’t fit so will these do http://www.ebay.com.au/itm/301835346061?\_trksid=p2055119.m1438.l2649&var=600645825584&ssPageName=STRK%3AMEBIDX%3AIT or do I need the one with the knob on top http://www.ebay.com.au/itm/262869333853?\_trksid=p2055119.m1438.l2649&var=561867879806&ssPageName=STRK%3AMEBIDX%3AIT .
I hope the c8 has low volt warning ?
cheers D
Convoy and thorfire c8 have low voltage protection. And just about any cell will work. If leaving stock Panasonic NCR B will work. But sanyo GA, Samsung 30q, lg hg2. Basically aby namebrand unprotected cell. Stock c8 only pulls 2.8 amps.
Edit just checked those links either of those will work. But for roughly the same exact price I’d choose the sanyo GA
so the Sanyo GA is a better cell , as I’m new to this I did some research on here and bought 2 chargers , I have a XTAR SV2 Rocket
and a XTAR VC4 coming .
thanks D
The ga is a better cell its a 10amp cell. The Panasonic is a 6.8 but doesn’t do well above 3-4 amps. Voltage sag is severe. With the ga cells if you ever get into modding or other high powered lights your already ahead of the game cell wise. The Panasonic’s have their place. I use them in powerbanks. And they are fine for under 3 amps. But for the same price the ga is the way to go
thanks this is the info that I was after
As important as the cell s also to reduce the resistance of the springs
Search for spring bypass
is that like the 2 convoy L6 I have coming
Yes, its a copper wire from bottom to the top of the spring
The resistance of copper is more than 10 times better than steel
With protected cells the spring is compressed often so much the windings short to each other, gold plating helps here a lot
But with unprotected cells the spring has its full resistance
I have Convoy C8 clear edition. It’s fit protected battery Panasonic, no problem at all. Since you don’t mention your C8, I’m not sure about the other model.
The default driver limit the current up to 2.8 amp. If you want little bit extra, get FET driver. I change mine to BLF A6 and using Sanyo baterai, the output is much better. But at the moment I changed the driver to DrJones for testing.
It depends on the C8. Some protected cells fit my new edition Convoy C8. A couple of Panasonic 18650Bs from Gearbest fit but are quite tight. We are talking about a few thou extra diameter making a big difference here, so it may vary from batch to batch. Unprotected cells are an easy fit.
As for low voltage warning, once again that depends on the brand of the C8. Convoy and Thorfire definitely have it. Generic ebay cheapies almost certainly won’t. I prefer to use unprotected cells in single cell lights and keep an eye on them with a voltmeter.
I think almost all c8s have spring contacts on the tail cap and the driver board, so flat top or button top (the ones with the knob on top) should work.
this is the one I ordered NEUE Grau Konvoi C8 XM-L2 7135x8 SMO integrierte Kopf LED-Taschenlampe Sale - Banggood Deutschland-arrival notice-arrival notice
The panny-B is probably the longest 18650 out there, at just shy of 70mm long. They fit all the C8s I’ve got (genuine Convoy to cheap-ass clones).
If I read the dimension, it’s same with clear version, so I assume it will fit Panasonic protected battery.
Additionally, Lightbringer said above would be enough information for that matter.
