I’d prefer to avoid focal lengths of 100mm or more. A 50mm focal length would allow a reasonably compact head . The 100mm lens with an 80mm focal length would be the next option. Wouldn’t the hemispherical reflector and the size of the opening also affect the apparent brightness and beam? This won’t be just a lens and emitter.
It’s not bad at all.
Most of the farthest throwing flashlights in the world use lenses that are similar to the one you’re looking at.
The DEFT-X, rev victor enthusiast, mjolnir, black bullet, etc… all use lenses that are ~75mm diameter and ~40-80mm focal length.
Not a “definition”, but the concept is that it’s how much intensity is needed, that when projected at a certain distance lights up an object enough to be viewable.
The farther something is, the narrower the cone from you to that object. So your beam (that cone) has to be intense enough to light up the object X amount. That’s why a “thrower” has a narrower tighter beam, vs a “flooder” that has a wider more spread-out beam.
Just gotta watch out for those clayheads, then.
well, my PROBLEM that gets me so hopping fired up from a mathematical point of view? now tat i calmed back down and literally chewed up several generic tylenol, and drank a pot of coffee, dropping numerous throat lozenges into the coffee to open up sinuses that are kicking my @$$ soundly… and VYING with the rotten TOOTH infecting off and on downinto i suspect perhaps past the gum and into my very JAW… i honestly dont know if my sinuses kicked the toothinfection off this time, or, of the tooth infection kicked up into my sinuses? all i know is i have chills and fevers, i am hot and cold all at once, i am shivering and sweating… i have no longer “just” yellow and grees goo coming out of mu sinuses and nose and up from my lungs and throat? the goo now has scabe and blood in it as well… i mean really when you are coughing up blood, that just CANT be good. but, the radiating pain is coming from the whole head, not just my jaw and tooth, and not just from my sinuses and head… they have all joined forces to whoop my butt. LMAO.
ahem
MY position, is that the F-number means something. that the RATIO of lens diameter to focal length? does something. that it does something useful.
it means something to an “old hand”, its EASILY demonstrable. NEWBS can understand it all easily. an equation is an equation. not only THAT, its accepted in camera lenses, its accepted by photographers SWITCHING lenses, that might vary in diameter and might vary in focal length, inorder to set shutters and irises properly.
not only that, its perfectly accepted in the world of projectors, which use the same f number, the same way. and the SAME camera lenbses can be used as projector lenses if you really want, and the same projector lenses can be used as imaging lenses, again if you want to.
to the WHOLE camera world? F number MEANS something… and it means “brightness”
thats not really “my” position, thats pretty much the whole world of cameras and projectors and stage lighters, everyone.
now, what my “problem” is? is that each and every time i so much as MENTION the concept of an F number as a useful handy guide?
as soon as its in the fladhlight world? i hear the following…
“no no no, you dont know what you are doing. focal length is useless. focallength only affects BEAM SHAPE… only the diameter of the lens matters.”
and? they state it AUTHORITATIVELY. as if F-number as a measure of a lenses ability to transmit light is somehow some wacky flat earth theory.
then they start in with surface luminosity, and they start “estimating” lumens and kilocandela and luxes and all this stuff, and they start shining their ligts into these cool little meters and everything… and they somehow claim to “prove”, that the ENTIRE camera, projector, and telescope WORLD does not understand the “concept” that is so superior.
i get tired of this “beamshape” stuff too.
thats WHY camera people HAVE the F-number, it relates the dance between focal length and lens diameter, each of which contribute as per their ratio, to the final product.
and that waiven collar? i dont undersdtand what that has to do with the lens… if your putting “something” over and around the emitter that makes it brighter or whatever? fine…
but, staying on point?
1) my position was that lens diameter, focal length… which is the f-number… “mean something”. that it is a useful mathematical unit to assign relative ability of a lens to transmit light.
2) “they” position… and i mean EVERY SINGLE TIME i ever mention the f number, on this and 2 other sites? it gets stated WITH AUTHORITY that focal length is “meaningless”, that only DIAMETER means “anything”.
now, someone up there started himming and hawing around and i did notice the words “focal length” creep into the explanation THEY offered. THAT would indicate they were claiming that “option 1” was right.
but, newbs walk away from all the megalux candelabra estimated meter illuminance “thing” with one thing and one thing only…
“oh! sedstar doesnt know what he is saying… i just need the widest lens i can find, nothing else matters. thats easy. nothign else matters. everyone says so.”
and it AINT.
why does the entire camera world, the entire projector world, the entire telescope world… suddenly become invalid, when its a flashlight?
why all of a sudden does “diameter” claiming to be everything, somehow magically spring into life. why all of a sudden does anyone get to claim that F-number means nothing and is somehow invalid?
i listed the 2 options… i am #1. easy is #2. EVERYone always “corrects” me on my “supposed childish stupidity” when i dare mention the f number as if its some archaic concept that has no application.
the “interim” explanations up there? they are CONTAINING the word”focal length”…
heck, while were AT IT ? i think it was enderman? said the best observable lens he ever saw? to date? was a plano convex 100mm fast tech lens. how can THAT be? because according to “coghlan’s laws… of absolute throw”? (movie: “cocktail” joke, lol)
—- aspherical are ALWAYS better than ANYthing else. never any deviation.
—- only lens diameter does A-n-y—h-i-n-g, focal length is irrelevant, it only affects beamshape.
and newbs walk away thinking they can ignore focal length and that f-numbers mean “nothing” and that any aspheric, as long as it has a bigger diameter? will A-l-w-a-y-s win the day.
then what do we all do in REAL LIFE? we all do the same thing, and we all know it…
we pick the biggest diameter lens we can comfortably fit into our existing light, or feel comfortable fabricating, because i admit, theres no replacement for displacement… its true. but THEN we “trial” different focal length lenses, and with the “lovely asphericals” which cant be FL measured (i can, mathematically too) we pick different lenses, with different FLs… and we see which one “does better” and we can “see further” with…
but… you have your diameter, you ave your focal length which to ME clearly does “something”… and that “dance” is simply the F NUMBER…
and everyone waltzes in and smugly corrects me that “only diameter increases throw”… which is crap.
see, here we go… lightbringer has stated…
QUOTE
ENDQUOTE
ohhhhh. see, everytime someone and it happens constantly, mind you… everytime someone smugly CORRECTS ME, and makes me look STUPID, as if my “wacky flat earth conspiracy theory” is so off the wall as to be childish? as soon as i mention f-number, i instantly dont know what i am talking about. THEY are dropping knowledge, to get the correct information out, that never changes: “only diameter increases ‘throw’ ”
now its not a definition, its a “concept”? and this “concept” seems to be, that when you want a brighter image at whatever distance, if you need more… you up the amps. i dont disagree with this “concept”. you can call it what you want, surface illuminance, megacandelabras,whatever… more amps makes more kick. i wrap my head solidly around that “concept”. I firmly acknowledge it.
okay, next comes the “beamshape” argument, and the cone of light, and the QUALITATIVE (not “quantitative”) words thrower and flooder always come out. again, i have no problem with the concept. i fully acknowledge it.
WHERE in this “concept”, is anything that says “only diameter increases the ability of a lens to do its job… and that focal length changes do nothing. you are WRONG to use the ”concept” of the F-number”
because THATS what i keep getting constantly “politely corrected on”,m and i dont findit to be a correct statement.
the technically vague and meaningless “concepts” of flooder, thrower, cones of light….?
you are doing nothing but describing, in qualitative terms, the exact same QUANTITATIVE notion of the “humble f-number”
hm. let me maybe state my argument another way…
i take a LENS out of my pocket. I toss it on the table in front of you. and you say “what can this puppy do? how good is it?”
now, no talk of any surface intensity, because I now have to describe the capabilities of THIS LENS to YOU. I can state that “this lens has diameter x”. i can also state that “this lens has focal length y”. thats all you need to know, to understand mathematically, the capabilities of that lens. The ratio of x and y ? its called the F number.
now, surface brilliance, and megacandelabras, and all the authoritative sounding use of words like flooder/thrower/intensity etc… none of that means anything. For all i care? you can use this lens to transmit the image of a blue fart out of a cow’s @$$ you just lit on fire with a zippo lighter.
because as humorous as that mental image IS? its very very accurate.
you can talk about all the “concepts” you want to. NOTHING else is describing this lenses ability to focus how much light thru it? other than FOCAL LENGTH and DIAMETER. you can talk about surface coatings, and style of lens production as slightly more or less percentage of efficiency? youre only scootching the numbers up and down.
and we really COULD be talking about how bright an image we can transfer onto a camera sensor, of a blue fart coming out of a cows $$... because the image of that blue flame shooting out of that cows
$$ will be BRIGHTER as the f-number goes down, and it will be dimmer as the f-number goes up.
period. end of story. no camera guy… no projector guy… no refractor telescope guy…not ONE of them will correct me, and tell me “no no, only diameter will increase the throw… of the image of a blue flame shootiong out of a cows @$$ onto whatever you wish to throw it onto”
i ask for a definition of “throw”, i get whatever i get
i ask for a mathematical formula? i always get that intensity formula… which means exactly SQUAT to the ability of the LENS to transmit a dimmer or brighter image of the blue fart flame coming out of the cow’s @$$.
now, i am correctly stating the lens’s ability to transmit how bright or how dim of an image? because nothing else in the way of a spec exists FOR THE LENS.
if you want to RELATE how many “moon bats” are going to be produced, per unit of time, per unit of area, per unit of whatever… all fine and dandy. But… i keep scratching my head, trying to understand how i am “wrong” using the f-number to describe the abilities of THIS lens o the table right here? before we build a light?
and everyone keeps CORRECTING ME, with the ring of authority… witha smug certainty they are conveying sage knowledge that i am too stupid to grasp? that “only diameter increases throw, focal length is nothing”.
which is DEAD WRONG, and i am DEAD RIGHT.
it doesnt matter how many “moon bats” ar going thru the lens out of the cows @$$… this lens, independent of WHAT you do WITH it? has 2 things that can mathematically describe it. The focal length, the diameter. period. thats IT.
the ratio is the F-number. done.
now… if you tell me the SIZE of the flame shooting out of the cows @$$? i can take the focal length, and tell you at what distance, exactly how tall and wide the projected image of that blue a$$ flame is… and with mathematical certainty. its not a “concept”… its a cold hard fact of geometry. Its honestly not open to mathematical argument.
the diameter and the focal length of the lens? and again thats all there is to mathematically decribe that lenses capcbilities… can be expressed AS a “numerical aperture”, and we can discuss what geometrical percentage OF the number of available moon bats get to fly thru the lens? but once again…
now… how in the &^%$ does it ALWAYS happen, that i get constantly CORRECTED, as if i am somehow WRONG… when i bring up the f number?
because you can make the cow fart harder and make the flame brighter. you can teach the cow to clench its @$$ cheeks together tighter? so the flame is smaller and more intensely bright of a blue flame… but… none of that has the slightest bearing on the capabilities of THIS LENS right HERE on this table.
i can accurately predict any number of things about what the lens can do, and it all flows from only 2 things… focal length and diameter. glass composition and shape are just scootching the percentages up and down a little.
because maybe the WAY you describe the “concept” of “what throw is” needs to be stated a little better… because ALL i keep hearing is “only diameter increases throw, dude…”. All your talk about intensity? is utterly meaningless.
i dont CARE how many moonbats you are making per square kilocandelabra, it doesnt describe the lens… you are describing wat you are going to shove thru the lens, and predicting how many moon bats are going to appear per square foot out the other end.
no one has said one single thing, that makes the f-number NOT a valid mathematical description of the lenses ability to transmit how bright of whatever image later when we build something with it.
and i’m sorry? but the following statement…
exactly WHAT impression is that supposed to make in the mind of the new guy? and exactly how am i “wrong”? because i keep getting CORRECTED… as if i am wrong,when i state the f-numbers…. because focal length only affects beamshape, dude…
well, i got news for you? “beamshape” is everything! the f-number is critical! i’m telling you i can geometrically predict all kinds of stuff everyone wants to know, i can relate different size emitters to exact size patches of target, i can adjust focal lengths to illuminate the same size patches between different size emitters.
i can even put numbers on 2 lens compound lens setups… easily.
and all i get is…
1) your WRONG duuuude…. only diameter increases throw, duuuude. Its, like, all about the intensity of the throw, duuuude. Your focal length? its… like… way wrong, duuuuuude.
2) and i got, like, seventeen different kinds of math to back me up? and to accurately predict things? and all i get is told i am wrong. and i really dont think i am.
3) now? its a “concept” not a Law, or an equation? what ARE all you guys SMOKING? I want some of the good stuff.
sedstar, I didn’t mean to disrespect you. Sometimes my tone can be misinterpreted when I write on forums.
All I meant was that the throw (candela) and light collection efficiency can be considered separately, not that the F number is unimportant.
Hey, I was just trying to help out, describing by analogy vs throwing out technical terms, equations, other technobabble.
If I take 1000lm and use the chip as a mule, it’s got all flood and almost no throw. I won’t be able to see something 100yd away, let alone 1000yd away.
If I take 1000lm and focus it to a pinpoint, it’ll have lots of throw. Something 1000yd out will light up nice and bright.
I didn’t mention reflector size, lens size, f-number, anything of the sort. I tried explaining “throw” as a concept. Shine a 1000lm S2+, and a 1000lm C8. You’ll know the difference between throw and flood. How would you define it, then?
I wasn’t trying to “correct” anyone in any way. You said you were still waiting for a definition of “throw”. Question is, will you accept one, or not? I’m not sure what kind of acceptable definition you’re looking for.
Fwiw, a throw of a measly 10yds can be a floody S2 with OP reflector and diffusion film at 1000lm turbo mode, or a dedomed XP-G C8 at 30lm low-mode. The only thing that matters is how much light is reaching the target at said 10yd away. No mention of reflectors, lenses, f-numbers, nothing.
I ordered the 100mm 135mm fl borosilicate lens from fasttech and will also order the 100mm 80mm fl lens elsewhere. The longer focal length will require a longer head but since it is a scratch build I’ll just make it a big tube with a handle mounted switch. The size will allow mounting of three 18650s or two 26650 across the tube side by side rather than the typical position in line with the head. Additional factors I considered were presumed refractive and thermal properties of the unknown (crown?) glass and borosilicate. Before ordering the 100mm 80mm fl lens I will contact the seller again to find out what type of glass it is. I will also search for a shorter focal length 100mm lens (50mm fl if I can find one) and order a double convex lens and do as sedstar has suggested. It will be interesting how the claimed and actual focal lengths compare. It may take a while before I have all of the lenses here. An ‘everything else being equal’ comparison of 100mm 50mm fl, 80mm fl and 135mm fl lenses would show the influence of focal length and the related ‘f’ values on the projected beam. Maybe I should add a 100mm 100mm fl to the group.
The focal length values above are info provided by the seller. The actual values will be determined by testing.
okay.
let me try a different approach approach to this.
is anyone saying that the f-number equation… is not a valid equation?
yes or no.
Valid for what?
A 10mm lens with 10mm focal length has the same f number as a 1000mm lens with 1000mm focal length, however the 1000mm lens will throw further because the delta of incidence angles is smaller.
I think you guys are forgetting that an LED is not a point source of light, and therefore it is also important to have the optic as far away as possible from the LED (in order to minimize the delta).
@sedstar Not me. I just want to check the accuracy of claimed focal length and show for a given lens size the effect of focal length (and related f number) on the beam projected. As a former calibration tech (metrology) quantifiable data and related testing have a special significance for me.
If you know the significance of the 4:1 ratio in metrology you get a cookie.
The relationship between lens diameter and focal length are in a way (to me anyway) similar to resistance and capacitance in an rc circuit.
FWIW, the first stage of my plan is to use a set diameter lens and a range of focal lengths with the same emitter. The second stage is to use a set focal length and a variety of diameters with the same emitter. Third stage is lenses with the same (or as close as possible ‘f number’. To minimize cost the head tubes will be rolled aluminum flashing sprayed flat black inside. I’m not wealthy so it will take a while to accumulate lenses to illustrate the relationship between lens diameter and focal length and the resulting beam.
You can also download a free ray tracing tool like * OpticalRayTracer Home Page to get a pretty accurate guess as to how the lenses will perform.
That’s assuming the lenses are sold with accurate characteristics in the description. Often these lenses are offered via sites that also offer 5000 mAh 18650s and 30k lumen latticebright powered flashlights. Establishing a baseline for comparison with real dimensions and values should be useful.
The diameter and thickness are pretty accurate, that’s all you need to know to replicate a lens similar in the software.
Playing around with the diameters and focal lengths and stuff you can see why it is better to have larger diameter and longer focal length.
The ray tracer emits all rays from a single point though, so to see the irl divergence you need to place the origin of the rays about 1mm below the x axis (depending on the led) and look at how much divergence the rays have.
The farther the optic is from the LED, the less the rays diverge.
try to appreciate, i spent most of my life relatively uninterested in photography, beyond if i needed to take apicture? i wanted a camera. i was always fascinated by japanese tourist cameras, as we called them in the old analog days… but, as a mechanical curiosity to me only. if you had one? i wanted to touch it, i wanted to play with the focus and be allowed to snap a pic.
i was always at these times, curious of what “the weird controls were”. its unexplainable to a complete camera noob. they would set the shutter and iris control? i was allowed to “play the focus” and snap my few pics.
then came the night vision projects? LMAO. i had to jump INTO this, and unfortunately? i suddenly hada burning NEED to understand as much as i could about the math of optics, if i was to design something, to uncover something. i had to “grok” the entire system in as much mathematical model as i was able to.
to be into night vision though? is to be into focusing flashlights, though. suddenly? i had to learn about “zoomies”. how to mod a regular zoomie into one. how to make it better. which lens to use… i devised strategies, both mathematical and practical hand tuning… to construct 2 lens zoomies. i can make a “true zoom” zoomie.
i can do those things back into camera lenses too… it all related and intertwined.
my background in computer science and mathematics in a former life? allowed me to do this, and in a deeper, fuller way than the guys just building builds…
but, i “See” all this… for lack of no better WORD… “how” i see it… and i know that the f-number relates image brightness, and the same way translates into PROJECTED brightness. i achieved what i set out to try to do, to make a infrared flashlight that put my emitter, same one everyone else was using… to a distance record at that time. i achieved something for myself in my hobby field. i ended up with my very own “build” and i got to name it.
visible flashlights? being here? was at first, just a fluke., i was into this, only cause i needed tobe… but, you know, had to get just one LED visible flashlight, LMAO… caught the bug.
i can mathematically model a second lens onto any lens, thats imaging or zoomie, and pick my f-number and focal length? practically at will… nd its only possible thru math, and an understanding of the importance of what an f number is, and how to use it, design wise.
look… i am starting to “grok” what YOU mean now? your recent post with the 10/10 and 1000/1000 lenses “both being f1.0” got me seeing a little from your point of view… but… if now YOU can try to see things a little from MY point of view?
a L-O-T of “flashlight people” were wandering into our night vision site? and i gotta tell you, they dont “grok” it completely the way YOU just tried to explain “what you meant”… what do they “know”? what do they take away from what you guys say? this:
1) to SAY the phrase “diameter is alllllll that matters! nyah nyah”
2) they actually believe, naively and incompletely? that we were supposed to choose out lens, to build our next better zoomie? simply by picking any, and i mean A-N-Y… larger diameter lens.
look, i asked the guy that “came to help us out, since we needed help”? i asked him this:
“sir? let me take out 17 different lenses. random focal lengths. all the same diameter. the individual lenses? they have focal lengths, ranging from as low as 10mm FL… up to one thats 1200mm FL… all of them, though, are 60mm in diameter… are you trying to tell us here, that ANY of those lenses, slapped onto our infrared zoomie build? will all work equally as well? just because they are all 60mm diameter? is that what you are saying?”
he said:
“yes, you finally got it!”
then someone (one of our “lens whores” as we call them there?) whipped up, for a joke… three impromptu zoomies, you know, workbench temporary slap togethers… all the same emitter, with 3 VERY different FL lenses, and showed him what he was implying we “should do”… when he finally SAW that the CAMERA SENSOR needed a certain S-I-Z-E of focused emitter to fill the screen
he went “oh……” and went very quiet.
all……he…… grokked……
because of HOW it gets stated? was that “bigger diameter is better! focal length is meaningless!” and we took him for, well… somewhat of a moron.
I suppose N-O-W i am seeing that in the flashlight world? ehhh. you just want a really bright light… a super charged emitter… and you place any lens over it. if its a flooder, its a flooder… if its a thrower its thrower… you can get USE out of it, no matter whether its a mule, a mid grade, or a pencil super thrower?
but… in night vision? the size of that projected emitter? better MATCH the camera view. you know what i mean? a flooder is useless, a tiny pencil mean is useless.
that guy had learned NOTHING about making zoomie flashlights? except to repeat the following phrase like a parrot:
“focal length doesnt mean anything…… only diameter has any bearing on anything….”
and honestly? theres a zillion peole running around the internet world, going off half cocked with this idea. it would be so bad, but… they CORRECT everyone having any discussion, as if they are sage wizards. and most of them cant build anything.
i was on a telescope building site? doing my duty for he night vision site, seeing what optics pros i could find and drag onto my site, to help us? i thought surely some telescope builder could helpus maybe, hey, i was trying…
the telescope guys told me about “some moron” who came to their telescope site? telling THEM that for astral photography? they didnt need to “worry” about focal length and f numbers, because… well, they needed to “understand the truth” that only lens diameter “mattered” for pusposes of getting more light thru the telescope system.
so, when i said i was there “seeing if anyone could give me any designideas for a multiple lens flashlight projecty” they eyed me with GREAT SUSPICION, as you can well imagine, their previous meeting with a “flashlight internet guy” having been so moronic. i had to “prove myself” with a few light math post discussions, before anyone wouldtalk with me about my project.
i’m not entirely sure, that you guys realize what impression this is leaving in the minds of people with no backgroundin math, in your hobby, trying to learn how you math guys do what you do?
all many of them are learning, is to repeat one single phrase:
focal length does nothing… only diameter makes it pass more light…
and they authoritatively are “correcting” people, having some air of grand knowledge…
am i making my point, of what i have encountered, better? people with no math to them (and there are many in the world) are learning to repeat the phrase, like a parrot… i think there needs to be SOME more ideas given to them. if you know what i mean?
eh?
i acted, like i acted??? i thought everyone was acing as if the f-number didnt exist and focal lengths were irrelevant.
for ME? controlling the exact projected size of the emitter (degree size, projection) isnt just a flood or throw “what kind of light do i feel like making today” kind of thing…
for a 3x night vision system? i need a specific FL zoomie lens, to fil THAT scope view correctly.
on 5x? i need a different FL
on 9x? i need a different FL
my focal length, on my IR zoomie? completely controls the size of my emitter in my field of view, expressed mainly in radians, and half angles, and projective geometry.
then of course, i want to pump as many amps thru the poor emitter as it will stand my build heatsinking without making magic blue smoke, lol…
in my design world? i dont have the luxury of making whatever “beamshape” i feel like making. so yeah, focal length and f numbers are critical. they are design criteria number one two three and four five and six.
are you now seeing things from my perspective? peolpe from flashlight sites were coming in and saying things completely backwards, IE, “bigger focal length makes a bigger emitter!” and we point out thats backwards? “oh well, it doesnt matter anyways! only diameter means anything for more throw!”
the night vision guys, and even the telescope guys on that site? we were all math guys, and we were wondering where these morons were coming from, that understood nothing, except to repeat that one phrase, like a parrot.
This may be of interest to you, my focusing freaks: Focus Tunable Lenses for LED Lighting by Optotune AG
Cheers
Sedstar,
Sunnranger(you know and most of guys here don’t know) is multiple lenses system illuminator(or flashlight) based on yukon night vision device 3x42, F1.4? (there is also bigger version ).
Plenty of guys on nvforum were comparing it throw to 67 mm aspheric (X searcher and T67) and it had beaten them in terms of throw but they did not take one important variable - they were not all build under same conditions (same driver, same emitter).
So with proper variables(all systems with same driver and same emitter) when we use SR with IR emitter (4715as for example) has spot size somewhere on half way of hotspot on 50 and 67 mm lenses and visually it really seems that it is out throwing 50 mm and very close to 67 mm one because it has ultra clear die projection I never seen in my life. I can’t measure invisible light…
But I’ve also decided to build fet driven xp-g2 s4 2b SR pill to convert it into flashlight and I really expected that it will kill at least 50mm aspheric and that it will be close(performance vise) to 67mm one since nothing in classic aspherical flashlight world has clearer die projection.
Seriously guys you’ve never seen clearer die projection than in mentioned Sunnranger system but when I put it on the lux meter it was total disappointment throwing around 10-20% less than classic 50mm ones :rage: so it has smaller die projection than 50 mm one and yet throwing less…
Now something good is probably happening when we use IR light source(or even red emitter source inside such system) since it seems that it is passing that light through system much better than visible white led light.
My thought is that special NV AR coating on SR lenses is killing white led light transmission by stopping of blue or other important color that needs to be projected through lenses to give best performance…
I want to say that this system has great potential Why? 42mm lenses that should throw close to 67mm lenses size which means more throw in smaller head diameter.
Hi Luminarium !
Luminarium is from my nigh vision site… we are all “zoomie guys: dyed in the wool… we have no choice but to be zoomie guys…
i was already wanting to make a multiple lens zoomie, and while i was arguing with everyone it was possible… look at my equations… (nobody will look at or cares about equations, by the way) so while i am aguing its possible, and its desireable? at the same time, they were all oohing and aahing over the light he is talking about!
i still remember seeing it, and realizing it was a multiple lens zoomie, and one guy said “good god, i was wondering when he would notice it”…
so, while everyone is telling me it wont work, or that its not practical? at the same time,they are all using it !! (kind of ironic)
also… i had gone and was making 2, then 3… and even one 4 lens zoomie setup… trust me, “the lads” on the site? will remember me and my software to perform the math so no one had to solve equations… not one download, but, they will remember me posting about it if nothing else
i was posting pictures and a short movie? showing MY light, with the same emitter? beating larger diameter “single lens” traditional zoomies. i had the same emitter, and either the same or less current driver… it allowed the lower diameter len SYSTEM to “punch above its weight class”
DIAMETER, you run into a wall… you cant get bigger after a certain point in a gun mounted system… which therefore limits you? adding a second lens behind it? i am able to DROP the f-number and change the focal length…
by running the equations at design time? i found i could pick my f-number and focal length of the system? practically at will…
diameter was NOT the only way to get more moonbats thru the lens… i simply added a lens, which dropped the f-number, and changed the focal length…
i am still the only one on the night vision site? that routinely adds lenses to existing imaging lenses? to change the focal length, and drop the f-number… driving night vision performance UP…
i might not still have the distance record? but i should check… even if i dont? i am not sure erveryone realizes my distanceswere achieved? with the OLD oslon emitter, and the wimpy 1A drivers we were limited to at the time… my high distances? were with half powerful emitter and lower amps than what they use today…
smaller diameter lens, less amps, still keeping up with the joneses !
(whos your daddy… smak-smak-smak, whos your daddy… smak-smak-smak)
