PKCELL
has anyone had anything to do with PKCELL and if so are they any good
I am looking at these but will not buy them unless I know they are any good
http://www.ebay.com.au/itm/4pcs-3-7V-26650-4000mAh-Li-ion-Rechargeable-Battery-For-LED-Flashlight-Torch-/122368654839?hash=item1c7dbd7df7:g:INsAAOSwjDZYmuf5
cheers D
forget those.
look for liitokala inr26650-50.
cheaper and possibly the best 26650
hmmmm bummer no one ships to au and there are none on evilbay
have you tried GearBest?
LiitoKala 26650 5000mAh 20A 3.6V Rechargeable Li-ion Battery
make sure you set your location (upper right) to Australia to check
I was just looking at these myself (for USA shpg, though)
Well, it’s got a lightning-bolt in its name, so I’d trust ’em! :smiley:
Nah, stick with LKs for 26650s. I got some from GB, US warehouse (as to not get raped on shipping), so check to see what shipping might be to the land of Oz, first, before putting in the order.
http://www.gearbest.com/batteries/pp_360842.html?wid=21
31.57 AU Dollars & 13 cents shipping to OZ for 4 so 15 AU Dollars cheaper & you know that you are getting good cells (probably the best 26650”s out there).
These cells are on ebay OZ http://www.ebay.com.au/itm/2x-ThorFire-3-7V-5000mAh-PROTECTED-26650-Rechargeable-Li-ion-Battery-F-LED-Torch-/311778670048?hash=item489774f5e0:g:3JkAAOSw-0xYd0cd
a little dearer than the Liitokala at nearly 40 AU dollars for 4 but these are good cells.
I have had some of them for a year now, test at the claimed 5000 mah & run an S70 fine.
A few other members also have these Thorfire 26650”s and have reported that they are good cells.
nope this is a copy and post from the sight …… Shipping Cost: Cannot ship to Australia ……
so it looks like the thorfires are it even if they have fire in the name :smiley:
You could try these for a couple of $ more, “MNKE IMR 26650 4000” better seller rating and free postage :money_mouth_face:
Cheers David
ooops the link http://www.ebay.com.au/itm/2-X-MNKE-IMR-26650-4000-mAh-rechargeable-Lithium-ion-batteries-tested-to-4350mAh-/281386305051?hash=item4183ee461b:g:LYIAAOxyi-ZTa2ci
The sellers feedback rating isn’t that good on the Thorfires….
But the seller on the 2 X MNKE IMR 26650 4000 mAh rechargeable is almost perfect.
I know who I’d go with.
btw had anybody already tested that PKCELL’s 26650?
afair PKCELL is not just some noname manufacturer and so might be quite good for its price.
The thorfire cells are good. And test at 5000 mah. I have those the liito 50a and evva 26650s any of those are good cells. I like the long runtime of 5000mah.
I don”t know anything about the seller so can”t comment but I can vouch that the Thorfire 26650”s are good cells, even though they have “fire” in the name”, several members have them & rate them highly.
I have no experience of the MNKE cells although HKJ has tested the 3500 mah version & states that they can deliver high current
“Conclusion
This cell has good performance also at higher current. The capacity is not much better than a 18xxx cell, but it maintains higher voltage during discharge.”
[quote=Speed4goal]
[quote]
Me too it’s why I’m looking as I am tossing up between the lumintop SDmini or the 26
and with the 4000mah it is just 500 better than my sanyo cells but if I can get reasonable
5000 26650 instead of $21 ea for keeppower I will get the 26.
Everbuying ?
http://www.everbuying.net/product1170667.html
I try to change the shipping to AUS and it just go’s back to the US
Anyway you can order from mtn electronics international website? Might be cheaper even with the shipping then getting domestic. Or maybe nkon.NL can ship to you
