Astrolux S1/BLF A6 A17DD-L FET+1 on fw clicky switch
I have problem to make this driver operating on forward clicky switch.
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/view/head%3A/ToyKeeper/blf-a6/blf-a6.txt
Fast tap about 15 times untill light stops to come out, then fast turn on the light, and I have two times 2x blink, and I turn off the light after second 2x blink in order to select Group 2: low, med, high, turbo…
But nothing, I get back to Moon-Turbo-Tactical Strobe-Battcheck-Bike Flasher…
Can anyone help I want to select Group 2 : low, med, high, turbo with mode memory on forward click switch… ?
You do not click between the two 2x double-blinks but between the first 2x double-blink.
Blink-Click-Blink, not blink-blink-click-blink-blink.
1st Blink-Click-Blink to choose group mode.
Repeat the 15 clicks for memory mode, Blink-Blink, Blink-Click-Blink
Ok, for mode memory I understand and I managed to choose that, but for group mode I’m still not clear there are only 1x double click for group mode, how to choose between 4 and 7 modes, I can not understand that :frowning:
Group Mode programming
When the light is on
Fast click 15+ times or until the light turns off
blink-click-blink
Memory Mode programming
blink-blink-(wait for the 2nd double blink)-blink-click-blink
You must enter programming mode twice. It cannot be done in one go.
First of all on fwd clicky switches light can’t be on.
So you must do 15+ half press times tap when light is off then when light stop to come out you must fast push a switch to the end to turn on the light and then you have that two times 2x blinks.
I do first time when see your post on first time 2x blink, blink-click-blink and nothing… Then I do for mode memory and that works fine. But when I do first 2x blink, blink-click-blink nothing is happens…
So I have now mode memory on Moon-Turbo-Tactical Strobe-Battcheck-Bike Flasher, but can’t change to other groups. If someone use this driver with fwd click switch a help will be appreciated.
This is probably very faulty driver or it is not optimized well to work on fwd clicky switches.
After a 12h not using flashlight now mode memory won’t work anymore, even though it work well 12h earlier.
Now when try to set mode memory it just won’t work, skipping to next mode.
If anyone use it on fwd clicky switch please share your thoughts.
