pressure switch for a C8
allcool we cull thousand’s of kangaroos every year around here and some nights some blokes shoot 150+ a night
it makes for a very long night and yes it is all out the window as there isn’t any other way as they are too quick
for a chopper and it wouldn’t be cost effective anyway .
and we would have it a lot easier if we could have an M4 and a 45auto for self defence but alas we are not even
allowed to defend our selves without getting charged , I couldn’t believe what I was hearing on the news one night
when the top cop for the state said that even if you are getting car jacked if you fight back you will be charged
this place has lost the plot .
and yes on the other points as in the tint not throwing as far and the M3X being a good thrower .
cheers D
Ahh, I see, sounds like you’re over run with Kangaroo, just like we are with hogs…
What does one do with 150 Kangaroo carcasses…?
I got a ccw, so I feel your pain. Rather be judged by 12 then carried by 6…
Some liberal states here, have to run out your back door if a intruder breaks in, can’t stand your ground in some states. Not my state.
Our right to carry and stand your ground gun laws here in many states have made it a much more polite respectful society for the most part. Lots of bad guys getting what they deserve at the hands of a ccw, however that rarely make the headlines of the liberal anti gun msm.
Car jacking in Miami has gone to an all time low since the stand your ground laws went into effect a few years back. Now if someone trys to car jack you and you shoot them dead in self defense, you don’t get arrested, just detained on the spot for some questions and then let go. Before the new laws, any/all ccw self defense shooting and you were arrested immediately and brought downtown to jail/questioning and probably kept for an arraignment by a judge.
Biggest gun show in S FL this weekend, picked up a nice slightly used 270. Should be a good long range hog rifle for the big 400lb boars that are hard to get close too. Not sure what light to use on it. That Olight M3X you got might be the ticket, mod it with a nice XP-L2 HD V6 3B tint and fet driver.
How does your M3X take recoil on your 7mm…?
not much recoil in a 7mm rem mag especially when the rifle and scope come in at around 13lb
so far it’s good with around 75 rounds , not much use as the 7mm only comes out for deer culls
on crops . just bib the horn and when they stick their head up whack’em in the head or neck .
don’t much like shooting SAMBAR deer under a light but I have to do it as all the property’s
I shoot on I am the only one that shoots there so I have to do it .
Hey all. Simon has the remote pressure switch listed for sale in the Convoy store. It’s a universal style that will work with any light that has a 16mm switch boot. You just need to have $7.44 and the ability to solder two wires. Free epacket shipping. I’ll probably do an actual thread for it later but since it’s being talked about here I figured I’d let you know.
New Convoy universal remote switch
I don’t get this . so I still have to get a tail cap as well and the switch is way to big and blocky
No you use your tail cap, disassemble it and solder in the new wires/parts. Looks pretty basic/simple
JMO, but, not sold on maxing out a switch at its 3 amp max with most any high power stock light that draws 3 amps.
In my experience, a switch or relay should be sized well above its max projected power draw, for reliability and longevity.
Problem is, most/many of those little thin compact pressure switches have flexible thin aluminum foil or copper foil contacts separated by thin foam with a hole in it, that compresses when activated(pushed) to allow foil contact(switch activation). That thin foil is not capable of big continuous amp flow.
The new convoy switch looks to have actual micro switches, much better, hence its bulkier construction is needed.
Its a compromise. Add to that, 24” of coiled #20 wire for a nice voltage drop and the more bulky maybe in the way switch/wires, and you can see why I gave you the recommendation in my above previous post…
jmo
I still don’t see the problem with 3A at 5 seconds or less and I never had a problem with my olight ones
and with this I would be out with the soldering iron about 4 times a week as I use the light for more than
just to sit it on a scope .
Thanks!
I would like to talk to Simon. Does he speak/understand English?
How can I contact him? Email is my preferred means of communication.
I have something I would like to share with him. Directly.
If you can flash firmware what about using a remote electronic switch. Setup 2 modes, one max, the other below the moonlight trigger (toykeeper mentions levels that don’t even illuminate the LED in C8 thread).
Tailcap stays standard, turn it on when you go out shooting, turn it off when you return, jobs a goodun. Sure you get drain when electronically off but not a problem for a few hours shooting.
Allcool, it’s always been the case that nearly all the budget lights overdrive the tail switch, getting ones to do FET drivers with headroom is a real issue, let alone remote switches! Torches like the Olight M3X get off lighter because the 2 series voltage reduces the current. McClickies became popular for a while on modded lights iirc.
Can’t believe some US places can’t shoot out of a window, damn, we do that in one of the tightest controlled countries ever, the U.K.
It would be nice if there were spare tailcaps available so a guy could easily switch between normal usage and the remote switch.
+1 on that thought.
Your mentioning it may become reality.
Yes, I’ve been trying to source a tail switch that is rated over 1.5 amp, haven’t found one yet. Otten and that other one commonly sold are both 1.5amp iirr. And these weak switches passing 3+or 5+ amps thru them are usually the source of most light problems/failures, ime. Believe you’re on to something, 2 series voltage might be the answer, all mine that use that system seem to work the best, although it makes it hard to get tailcap amp draw meter readings…
Thought all guns were illegal in UK, or is that just handguns…? Is it true the Police don’t even carry…? So, you Brits can throw knifes out your window, ok…? lol
Pretty sure no where in the USA can anyone hunt/shoot out of a vehicle window. Or even from a atv/utv. Must be out of the vehicle on the ground when you shoot. One would get in much much more legal trouble hunting/shooting out of a window here in Florida then shooting a perp dead (out of any window) in self defense stand your ground situation. Hows that for USA logic…lol
Haha, no, we have to jump through hoops but it can be perfectly legal, little known but in the U.K. you can own most firearms even handguns however that is rare. Hunting rifles are very common in rural areas where I’m from, .243 common for deer/fox duties… Moderators are no problem here also.
Self defence here is insane, absolutely no self defence items, none! If you carried a pen for self defence you’d be breaking the law! Of course just carrying a writing pen is fine but as soon as it’s for defence you are in the wrong. Thankfully shooting of people is very rare.
Saturday nights out in a town has become more dangerous over the years, brutal attacks are getting more common, often gangs of men against one person, beaten with fists and boots to death. Normal one on one fists and a honourable end has ended but god forbid you defended yourself against a gang beating :frowning:
Oops, off topic, there, back too it……
I’ve been talking to Simon about this very thing since we started discussing remote switches. I don’t want to solder anything to change my C8 to an ideal mountable setup. I proposed a solution that would make this same switch available already soldered in place in a C8 tailcap so that you could just swap the tailcap at your convenience and go from handheld C8 to a remote pressure switch just by changing the tailcap. No promises, but that is what I’m trying to make happen.
Thanks J. I appreciate all the work you’re doing with Simon. I already love most of the Convoy products, and they just keep getting better :slight_smile:
Hey all. I had a nice conversation with Simon last night following up on my request to have a complete C8 pressure switch tail assembly and passing along many of the comments posted here. Bam! Done. We have a complete C8 pressure switch assembly listed in the Convoy store now and still under $10 shipped!
Just swap the tailcap and you’re done.
Convoy C8 pressure switch assembly
Slimmer designs and higher current designs will be considered for the future but as others have mentioned the reason this one can handle more current than many of the others out there now is that this uses heavier gauge wire, an Omten 1288 reverse clicky and a micro-switch. That stuff all takes up room…
I don’t expect everyone to be pleased with any single product as we all have different likes and dislikes but personally I’m just happy Convoy finally has a remote switch. :slight_smile: :+1:
Noice
Thanks Simon. Annnd J-Dub!
yep thanks
Very nice!
There are remote switches that are slim and can handle high current
Utilizing a FET
