"This is what I am worried about. The Xtar protected 14500 cell IS marginally longer than the NiMH cell that DOES work. I have tried screwing the tail cap down as hard as I dare. To me, it seems to screw all the way down. Anyhow, there is no switch in the tail cap. Is it not just a spring contact, or is there more to it than that?"
Look inside your tailcap. See that gold colored ring at the base? Now look at the end of the battery tube. See that silver shiny ring at its end? Those two surfaces have to touch to complete circuit.
You may think it's screwed all the way down, but with a longer cell the tailcap contact ring may NOT be making complete contact with the silver shiny battery tube contact. This is because a battery that is too long for the tube will not permit the tailcap ring to contact the tubes shiny ring.
The failure to work with protected 14500âs was reported quite a while back and is a known feature (I wouldnât even call it a defect since the light was built that way).
The threads are anodized black which is non-conductive.
When I started in this hobby I started with protected batteries but came to learn that you really donât need protected batteries in single cell flashlights. In real life when the battery gets low and the light gets dim you change it before it is fully depleted. I no longer use protected batteries in my multi cell lights either. I do date my batteries when I buy them and keep sets together for my multi battery lights.
I have two unprotected Efest 14500 batteries charged and waiting for my Utorch to come in.
Thanks everyone, I had a look at it last night and I realise what you are on about. The only point of contact between the tube and the tailcap contact is the unanodised end surface of the tube. If the battery is a fraction too long it wonât make contact.
So at this point in the story, the working hypothesis is that Xtar Protected 14500 cells are in fact too long.
Possibly I could get it to work with a ring of copper wire or paperclip made into a ring to fit between the battery tube and the tailcap contact. Or ideally a copper or brass washer of the right size, if I could find one, I guess.
Quote kzb:
I never use protected in a single AA/14500 setup. And I really donât see a need to. So, problem solved. I knew Iâd use non-protected before I even ordered UT01. Simple.
I cut a length of cable long enough to make a ring within the tailcap. Stripped off the insulation, twisted it a bit to keep the fibres in place and put it in the tailcap so that it makes contact with the battery tube end.
Result ! The flashlight does indeed function with Xtar 14500 cell with this bodge in place. The copper stays wedged in place also.
Anyhow I hope this is useful information for others considering buying this.
It seems all protected cells, *including those purporting to be âAA-sized*â are too long and wonât work in this flashlight. Unless anyone knows of a shorter cell than the Xtar of course.
It is verry hard to find a PROTECTED LiIon 14500. They are normaly longer than the nominal 50mm.
Xstar are short with arround 51mm others more on the 52mm side.
Are these definitely Protected? Itâs not clear from the FastTech site. In fact there is another Sanyo cell advertised, âSold Outâ, that is 50mm. Maybe that is the protected version, and how do we know the 50mm is not ânominalâ?
Reading the comments on the FastTech, I also think they are not protected.
Nominal:
14500 = are the dimension of a cell in milimeter 14 = 14mm diameter, 50 = 50mm long, End Zero = indicate its a round cell.
Same logic with a coin cell CR3230 : Round cell 32mm diameter, 3mm hight.
You MAY find that the protected variety of cells are not completely capable of putting out max amps that the driver needs for DD turbo. Thatâs why they call them protected. Itâs possible for their circuitry to prevent max amp flow.
I use the 14500 unprotected IMR WindyFireâs. Man, the UT01 is really scorching bright with that.
