This is my first light to break the 3k barrier for lumens
Really impressed on how it handles the heat. The spacer was a nice snug fit. Painted it with silver and the light can last almost 4-5 min before it gets too hot for me.
XPL HI V3-3C and Texas Avenger driver now inside
Narsil with full brightness when forward switch connects battery
a few days back I used my reverse lens adapter to make some nice makros
with a powerful flashlight light I got to F=18 16-35mm lens reversed on crop 1.6 DSLR
Made another Texas Avenger driver and reflo 3 Nichia leds from a Kaidomain triple to a Noctigon XP20 triple.
Before heating up. I like to see the small solder balls in the paste through microscope Fun to watch them melting together.
Anyone familiar with this driver? I took it out of the TrustFire ST-80 that is running SST-50 led. Goal is to change it to one mode only but I did not expected to bi so complicated.
Other part of the driver (not shown) has 2 mosfets K3638, sense resistors and a coil on it…
If it's got a sense resitor and a coil it sure sounds like a buck. Tow fets sounds like a synchronous buck, which is kind of cool if that's really the case. I'd be looking for an amp attached to the sense resistor (if it's not built into the buck controller) and then some circuit biasing the amp output. That would be the thing to hijack, the biasing circuit. But it might not work that way.
Here I added some better/more pics, maybe someone will be able to spot solution before I release the magic smoke that lives inside the driver
Interesting thing: on the eeprom chip there are 2 pins soldered together (modes were: hi-low-blinky-blinky-sos) when I removed bridge modes were: hi-mid-low-strobe-sos…
Some parts arrived from MtnE yesterday. Bought my first E-SW driver and installd it today. Seems to be some issues with the modes. Ordered it with ML+6 and there are only 5 modes after ML. There is an extra dead Off spot as I need to hit the SW 2X to get it into ML. Anyway the driver is installed and otherwise working and it’s not coming back out.
The second Solarstorm K2 has the E-SW Fet+1 driver piggybacked on the gutted original driver board. Yeah it ended up as a Triple XP-L HI V2 3C. Used a copper X6 spacer and 2 XP32 under the emitter as spacers and All stacked and soldered together.
