In the last scenario of “Excessive Thermal Paste”, was any effort at all made to squeeze out the “Excessive” amount or was it just left as “Excessive”?
Nice info also, thanks for doing it as well as posting. :+1:
Never reuse thermal paste. Always apply new paste.
When you remove a led board en want to mount it again with the same thermal paste you have a big chance to have air bubbles underneath. And we all know that air is a good insulator.
Great tests TA! I’m surprised of how low the difference is between using thermal paste and using no thermal paste.
Not being a real modder, but every (MC)PCB that comes out of the bag takes a turn on the lapping-stone. A tiny bit of thermal paste and then some wiggling until the paste emerges on the side. The screws are used for positioning the led.
Nice job! Interesting to see how much AS5 actually helps.
The light I have in which I noticed the paste the most is my modded Sunwayman C10R . The light started as a 1xCR123 light with electronic side switch. I modded it to triple XPL HI and upped the battery to a much larger and longer 18500. I replaced the stock driver with an e-switch FET driver from Mountain Electronics.
To make room for the longer battery, I placed the driver above the LED shelf, then sat the triple copper Noctigon above the driver. I used a strip of copper bent into a c-ring to keep the star elevated at the right height.
Naturally in that configuration, heat is an issue. This is a triple with FET driver and at max power with an IMR 18500 it pulls serious amps. The only heatsinking is where the sides of the star touch the head and where the edge of the bottom rests on the copper c-ring. There is no heatsinking at all below the center of the star. Like a hollow-pill but worse, because there isn’t even a built in ledge for the star to rest on.
I found that without any thermal paste, the wires to the star in the modded light would desolder themselves in about a minute when turned on turbo even with 30 second rampdown to 50% power. To fix this I liberally spread AS5 between the C-ring and head, and where the star contacts the C-ring and edges of the head. Problem solved! The head gets hotter much faster and the wires to the star no longer desolder themselves no matter how long I run the light.
Well, to me, the reason to use thermal paste is many.
It will more or less help negate all but the worst non flat shelves and star boards.
If one sands the star and shelf flat, and uses a coarser grit sand paper/crocus cloth on glass, or better yet, a coarse flat stone, this makes for more surface area from the coarse sanded pits and crevices, for better heat transfer(only with thermal paste). The pits and crevices, thermal paste will fill in all those crevices/scratches and transfer heat well with more surface area to dissipate/absorb heat…
So don’t worry about getting a perfectly smooth glass like surface, not needed. Flat, yes, get it as flat as possible.
JFYI,
I’ve seen tests in other thermal applications, of perfectly machined flat smooth surfaces compared to coarse perfectly machined flat surfaces, both with thermal paste, and the coarse(scratched) surface wins out…
On the lights with 2 screws on opposite sides, imo be careful of over tightening the star board and warping it out of flat…
All thermal paste is not created equal, some works much better than others in my experience (in other heat transfer applications), but any paste is always better then none. The correct application of these thick expensive pastes is critical for best heat transfer. Not always true, but usually you get what you pay for with thermal pastes. The very cheap stuff not as good.
ARCTIC MX-4 is my favorite, not electrically conductive like arctic silver and its cheaper then AS5.
Correct me if I am wrong, but “IF” I am reading the T_A graphs & sac02’s summary table correctly, there is very little difference between “thermal paste clamped hard” and “thermal paste left loose”.
Great testing as always T/A! I hate thermal paste for the same reasons! I take the time to flatten and lap surfaces together whether it takes days,hours or minutes and use just a see thru ultra light swipe across the star surface of paste, then after centering and tweaking, heat cycling, lock the screws down or if I have enough clamping force between bezel, reflector and star, its good enough! Enough clamping force means I can smack the light against a thinly padded board and not loose focus!
Only 8 degrees difference between the very best-rated thermal compound, and lipstick toothpaste or diaper ointment. I don’t think the brand of thermal compound used matters that much.
Do note that this table itself does not say anything about boundary conditions, i.e. surface properties like roughness and presence of radius of curvature. It is interesting to see the difference between an arbitrary compound and not having any thermal compound (second from bottom); roughly 35 vs 62, which is quite a difference.
Aww…… :weary:
You did the test first!
Great job BTW :+1:
So Tex, our gut feeling was telling the truth. Not much different results from not usng any paste.
I still prefer the least amount of my trusted moly-graphite bearing grease and a fine lapped MCPCB (and base/heatsink whenever possible).
